Question about Tascam 2488 Portastudio Multitrack Recorder System
US portastudio 2488: Can it play when connected with a transformer
This item made for US needs a 120V,60Hz currant.If I play it in France,using the 230V,50Hz with a transformer 230v/120V,is it sure that I obtain a good result,(the fréquency is not the same,in the output of the transformer).Thanks,if you can help me ,regards.
  • aceg47 Sep 15, 2008
    I don't anderstand:must I change the transformer which is in the box of the item or may I use an extern transformer which is connected on the 230V,50Hz of my house and to the item bought in US,and which is scheduled for 120V 60Hz : the informations writed on the transformer that I own are 230V/120V ,50Hz.Thanks if you can help me,regards.
    It's so much difficult to explain exactly what is the difficulty.I want to buy a 2488 which must be used exactly and only with 120V,60Hz currant.I am not sure if I can use it in France (where the currant is 230V,50Hz) with an ADDITIONAL,and EXTERNAL transformer,which can transform the french currant (230V,50Hz) in a suitable currant (120V,60Hz).Thanks.If I have explain my problem.
    Novelist:
  • 189 Answers
The 2488mkII manual specifies that the unit can operate with either 120VAC, 60Hz (USA/Canada), 230VAC, 50Hz (U.K./Europe), 240VAC, 50Hz (Australia) so you should be fine with a transformer which can accomodate 230VAC, 50Hz).
I have actually conversed with people who have been using the 2488 in France without any power problems.
Cheers,
bd.
Posted on Sep 15, 2008
  • Dave Hart Sep 15, 2008
    Sorry for the confusion ealier. I think I understand what you are asking now.
    I'm not in front of my unit and transformer so I can't verify the answer, but typically a device which supports either voltage and has no voltage switch means that the transformer is self-adjusting and you would therefore just use the transformer that came in the box. Usually the transformer will say 240/120 or 230/120 which means it will adjust to either. That's the part I can't verify, but if your transformer says that (or says nothing) then it should be the self adjusting type.
    Cheers.
    bd.
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
Tascam 2488 digital portastudio
Your HD risk to be corrupted, probably need to be removed and tested on a different device, I see if I can find the schematics
regards
Mar 08, 2008 | Tascam 2488 Portastudio Multitrack...
I need a service manual for a Tascam 2488 potastudio
Send your email address to me and get back a copy of it by return mail.
Oct 11, 2012 | Tascam 2488 Portastudio Multitrack...
MY PC wont recognize my Tascam Portastudio device2488, i have Vista
Tascam 2488:
I use Vista and my 2488 MK1.
When you plug in the USB cable from the 2488 into your Vista PC, Vista will always say 'not recognised'.
You do not need any PC drivers for the 2488. On the Tascam 2488, go to 'Menu', then 'Disk', then 'USB Open/Close', then click 'Yes'.
On your PC the 2488 will appear as a new hard drive in the 'Computer' folder, called HDR2488.
You'll see three folders in there: WAVE, SMF and BACKUP.
Use the WAVE folder to import and export WAV files, the SMF folder to import midi files to the 2488, and the BACKUP folder is where you can import and export Backup files to and from the 2488.
Hope this helps!
May 09, 2012 | Tascam 2488 Portastudio Multitrack...
Hi im new to using the effect send on my tascam 2488 neo. How do i set the connections? how dose it work?
I think if you had the manual you would know the answers.
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Jan 05, 2011 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
You'd plug the XLR connection into any of the first four inputs on the 2488 (labelled a to d). This is a dynamic mic so you don't need phantom power and should make sure your phantom power switch is off (out) on the 2488. You'd then assign the input you've chosen to a track, arm the track for recording, turn up the input level for that input to test the signal level, and record away by pressing record and play together.
Hope this helps.
bd.
Nov 02, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio screen.
You could add an HGR monitor interface module to display the 2488 on a PC monitor.
www.hgr2488.co.uk
That way you don't need to look at a damaged display and the 2488 (MK1, MKII and NEO) work just like before.
Aug 31, 2008 | Tascam 2488 Portastudio Multitrack...
2488 as an interface
yes if usb connection
yes if you can connect line in line out connection
yes pararlell port connecting
May 07, 2008 | Tascam 2488 Portastudio Multitrack...
Play and Record button not working
I have the same problem with all three of my Tascam 2488 MKII's.
It's a software problem and starts to show up when the harddisk gets full.
Backup your song files ( something you have to do anyway ) and then reformat the entire hard disk.
Then restore the songs you were working on lately.
Before doing this rather huge task, you can copy your latest song to another partition and go on with this copy.
This is only a provisional solution.
Hope this helps !
Best regards
Jan 24, 2008 | Tascam 2488 Portastudio Multitrack...
Instructions
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
Link to the Tascam 2488 application guide:
http://tascam.com/Products/2488/2488_AppGuide.pdf
Here's the link to the Tascam 2488 quick start guide:
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
Nov 10, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
116 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
