Question about Funai F3813D 13 in. Combo
Attach new antenna wire to tuner (Funai TV VCR combo )
Model F9TRF1, looks very similar to F3813D. Assuming my tuner UTUNNTUAL005, is same or similar. Given to me with plug or plate that had screw terminals or F59 connector already ripped out of tuner. Just VERY thin VERY short green wire. Tried to solder another wire onto green wire, it broke off. No idea where to solder new wire onto.
  • John Boone
    John Boone May 04, 2006
    Wow! Here I am creating an avatar... upload it... go back to check my problem... response already! Thanx! I had already removed the tuner cover, but the green wire broke off so cleanly and was so thin, impossable to see where it was originally soldered onto PCB. Would you (or anybody else) happen to have a photo of the inside of the tuner showing the wire attached to the PCB? Many thanx!
    President:
  • 3,130 Answers
If you take off the tuner cover you should see where another wire was attached to the PCB as there will be a small hole with nothing connected and a piece of wire at board level or broken level with the Printed curcuit board. If you dont see it then the best thing for you to do is to send the tuner to a tuner repair place like PTS tuner service and they have a flat rate to overhaul tuners and assy's or see how inexpensive a new tuner assy is. Its available at pts electronics for 49.95 along with many many more items like rebuilt printed curcuit boards ect ect ..www.ptscorp.com Good mluck
Posted on May 04, 2006
  • Larry  Dillon
    Larry Dillon May 04, 2006
    another hint is to open the bottom side and see wheres theres a wirein the solder but nothings up on the top hit that spot you suspect with a small wattage soldering iron and see if the wire comes off You know now something was there before. good luck
I have a 32" Coby with built in vcr can i hook tv to it with an antenna
if the TV is a newer digital model, installing a regular antenna should give you local stations to watch.
Oct 10, 2014 | Coby TFDVD3297 32"" TV/DVD Combo"
Find code for symphonic tv remote
very few if any universal remotes will work on Symphonic which is also Funai and some other brands.
Look on Ebay or Google the model number of the set with the word remote, remember not a universal.
Mar 10, 2012 | Symphonic SC313D 13 in. TV/VCR Combo
Hook up to digital TV antenna indoor passive
Please check if the antennae is connected with right cable and the dipole is good. If so search the channels avaiilable and if there is no signal then it is possible that the TUNER is faulty. check using another TV with the same antennae or check the RF input using a VCR or TUNER.
Oct 30, 2011 | TruTech KLV3112 10 in. LCD TV/DVD Combo
Message says see first page of manual
Do you have a coaxial cable attached to the antenna in on the TV? The TV has an ATSC (digital OTA) tuner and a NTSC (analog OTA or CATV) tuner. The initial setup wants the incoming antenna in signal to be present (this is the only message on the front of the TV manual).
This TV was built by Funai and the manual is available from Funai's support page: http://www.funai-corp.com/support/manuals.aspx . Since Funai makes TVs for a number of brands, the best option is to search for the model number (leave off the brand name) in their search box. The direct link to the IWT3206 manual is http://www.funai-corp.com/6pdf/om/IWT3206.pdf .
I hope this helps.
Sep 17, 2011 | iLO IWT3206 TV
I have a Magnavox ZV427MG9 DVD Recorder VCR Combo. Do I need a separate tuner? If so what kind? Thanks
Hello
Ofcourse you need an external tuner to receive any RF signals. Your Magnavox is not equipped with internal tuner with it. OK.
Apr 21, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Vcr/dvd combo recording problems
You can use a normal set top box, plugged into the AV inputs on the combo, you could even use a seperate VCR for this, as long as it's recieving the signal you want to record.
Apr 21, 2009 | Toshiba SD-V295
Can't record from lcd to vcr
On any VCR/TV setup, the television does not send signals to the VCR, the VCR has to send the signal to the television and then the show can be recorded. Attach the antenna input to the VCR and then your other cables (they may be RCA jacks or another coaxial, like the antenna cable) to the TV. You would have to change the channels using the VCR's TV tuner (if it has one).
If it does not have one, then you would need a new digital TV converter, and you hook this up to the VCR, then to the TV set. Hope this helps!
Mar 14, 2009 | LG Televison & Video
DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Jul 17, 2008 | Philips Magnavox DVD/VCR Dual Player
Connecting VCR/DVD combo
If you are able to you can connect to the RF connector (F Type Conncetor) on the TV. This should work. The layout is from the VCR (RF to TV) to the TV antenna F type connector from your Cable box to the Antenna in of the VCR that way you have cable through the VCR, and access to you VCR and DVD all controlled by the Cable and VCR remotes (set TV to Channel 3, set VCR to Channel 3) and use the Cable box as the tuner, Use the TV remote to switch between Cable and VCR inputs then use the VCR remote to switch between the VCR and DVD input.
Sep 20, 2007 | GE 25GT516 TV
How to hookup dvd.vcr to tv
first of all the the VCR has two connection from the tuner at the back one has out to tv the other has in from antenna you connect the wire from the cable company to the in from antenna.you connect another from the out to tv to the tuner connnection of your tv.and you are on.to connect the dvd to your tv.the tv has either at the front three female connector basic colors red white and yellow.the red and white is for audio in, left and right, and the yellow is for video in.the dvd has similar connections but they are output just connect them matching them color to color.there are some female connectors on the back of the dvd if you want to use surround sound.or play it through a reciever.good luck.
Mar 26, 2007 | Symphonic WF803 DVD Player/VCR
Televison & Video Logo
192 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
