Question about Samsung HLP4663W 46" Rear Projection HDTV
Samsung 1080i compatible tv 42 inch
My tv keeps turning off evey so often but now does it alot
This is very common with Samsung and is considered a overheating or lamp issue. cheapest fix before changing out the lamp is to unplug the unit after it has shut off its fans and open the back up and blow all the vents and circuit boards off with can of compressed air. Then remove the lamp to get to the larger fan that is behind the lamp, be carefull to not let the fans to spin when you hit it with the air because it will spin the fans faster than they are ment to spin, so gently place a finger on the blades just enough to keep the fan still and clean off any dust you see on the blades and area. Put everything together and give it a test run. If it stays on longer you know it was just to dusty to stay cool , if no change then try the lamp.
Posted on Sep 27, 2008
My samsung 42" 1080i will not turn on
Posted on Apr 23, 2010
Samsung 32 "lcd has pwer but wont turn on
To begin someone needs to open and look at the power board for signs of any damaged parts or puffed up filter caps, this is where to begin, if you are not able to do that consider getting it looked at by a tech or a shop.
Dec 14, 2012 | Samsung HL-S4266W 42" HDTV
MY TV HAS NO POWER I CHECKED THE FUSE IT SEEMS
hello have you checked the glass fuse inside the tv it will be in the power supply beware if replace the and blows again the you have a dead short circuit
regards
shaun
Apr 09, 2010 | Samsung HCN4226W 42" Rear Projection...
My tv sumsung hcn4226w 42 inch rear projection will not turn on
either the lamp is burned out or the ballast and power supply board need to be replaced. can call 1-800-samsung for nearest service center.
Dec 11, 2009 | Samsung HCN4226W 42" Rear Projection...
Red pixel cloud in plasma black
THIS IS THE START OF THE PLASMA GAS RUNNING OUT...PLASMA TVS ONLY LAST 4 TO 5 YEARS THE GAS JUST BURNS OUT....LCD TVS LAST ALOT LONGER UP TO 10 YEARS..
Dec 29, 2008 | Samsung PS42P2S 42 in. Plasma Television
Samsung 1080i
ic chips are no good if u can open it up get fan on it blow dust out for super bowl keep it cold
Feb 03, 2008 | Televison & Video
Daenyx Lcd tv 42"
i Bought one looks good but i hear they break
Dec 24, 2007 | Televison & Video
Black Lines
yea my 50 inch hdtv is the same. i contacted the samsung number since its still under warranty and they said i need a new engine or something for my tv that they would come out next week to fix it. i guess it happens alot. but they said once itf fixed it probably wont happen again. so u should call them
May 11, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HLP4663W 46" Rear Projection HDTV Logo
341 people viewed this question
Henry  Thomas
Henry Thomas
