Question about Quinny Buzz Jogger
Gas-spring mechanism has stopped working on my 2006 quinny buzz :(
  • azah_310 Sep 21, 2008
    my gas spring quinny also has stopped working so i can't use the stroller anymore.help?
  • ellysmom919 Oct 26, 2008
    i hate my stroller at this point!!! Besides it occasionally TIPPING yes TIPPING b/c the front wheel gets stuck, now the darn thing wont open or close!!!!!! I cant believe i wasted so much money on this stroller!
  • 8 Answers
I sent my frame to dorel and they fixed the same problem quite cheap to do if you remove the wheels etc they were quick to send back too phone them on 01842763281
Posted on Oct 04, 2008
I had this problem while on vacation and needed to DIY because I was going to fly home and could not leave the frame in the open position.
The buzz has a locking pin which in my case was preventing me from collapsing the frame. If the button which you push down and up has fallen off you likely have this problem. The fix is relatively simple and requires a phillips head screwdriver (needle nose pliers would come in handy too).
The steps:
  1. Remove the seat or carseat/dreami posts so all you have left is the frame.
  2. On the side with the button you push down AND up, look inside the hole where you insert the seat/carseat posts. You should see a silver button. Pry it off with the screwdriver.
  3. This will expose a phillips screw head - unscrew it.
  4. Pry the mechanism apart. Inside the outer piece you should find a small enclosed cable. You will need to feed the end piece into the plastic button. Also make sure the brass fitting on the cable enclosure is fitted into the plastic outer piece properly.
  5. Put everything back together.
Sorry I can be more descriptive - but I hope this helps. It took me a good hour to get it figured out and back together.
Posted on Mar 14, 2009
2 Suggested Answers
  • 419 Answers
SOURCE: Closing mechanism on Quinny Buzz is not working
If you have the version that has a black nylon strap clasp to close this, then you can contact http://www.quinny.com/quinny/forms/contact.aspx?mode=contact&language=gb-en who will be able to advise on how to purchase this part.
I hope this helps.
Posted on Sep 20, 2009
Can a Maxi-Cosi Mico infant car seat fit on a Quinny Buzz 2006 frame?
The Mico is a USA model only so we are unable to advise from the UK team whether it is compatible with the older style Quinny Buzz.
We recommend you contact Dorel USA on crelations@djgusa.com
Nov 27, 2011 | Quinny Buzz Baby Gear
I just purchased a second hand Quinny buzz 3 and I believe I need a new front tire. When I go to turn the tire bumps on the cement and prevents me from turning with ease. Where can I find a new spare tire?...
hi you can get a new wheel unit from quinny direct or eBay
the folding is something else turn the buzz over and check the groove on the middle tube to see if it is clean try an oil like wd40
if that doesn't work it may need a re gas which can done by quinny
Feb 16, 2011 | Quinny Buzz Three Wheel Stroller
Trouble opening and collapsing a quinny stroller
The Quinny Buzz can only be folded/unfolded with the seat in the most upright position facing forward. If this is the case and it won't unfold, remove the seat first by pushing down the two grey release buttons either side of the frame. It may be the case that the gas strut (automatic close/opening mechanism) is seized and will need replacing. This can only be done by Dorel UK 01842 763 281 as it is a pressurised unit. Hope this helps
May 28, 2010 | Quinny Buzz Jogger
Hi, I have a Quinny Buzz pram that has an
HI,
This sounds like you need a replacement gas cylinder. This is not something that you can do yourself and would need to be undertaken by a qualified person. You need to contact either your retailier or www.dorel.co.uk
I hope this helps.
May 21, 2010 | Quinny Buzz 3 Sulphur Jogger
Not fully opening
This does sound like the gas spring needs replacing. This is something that the manufacturer needs to do for you though. I would suggest that you contact your retailer to get this rectified.
Hope this helps.
Mar 19, 2010 | Quinny Buzz Three Wheel Stroller
Quinny buzz handle won't extend and frame has started to collapse unexpectedly while baby in push chair
Sounds like the handle bar extender mechanism has broken internally and the Gas strut is faulty. This happened to mine. Both parts are readily available from Dorel UK 01842 763 281 (Mon – Fri, 8:30 am to 4:30 pm). They are the sole supplier of parts for Quinny. However, the Gas Strut is a pressurised mechanism and has to be replaced by Dorel. You will need to speak with them and arrange for the frame of the buggy to be sent to them (at your cost if out of warranty) and they will replace whatever parts you need plus do a full service.
Feb 07, 2010 | Quinny Buzz Three Wheel Stroller
I hope this helps.
Jul 09, 2009 | Baby Gear
Opening the Quinny Buzz
It sounds like your gas is running low. if you registered with Quinny when you bought it they will fill this up for you free of charge, best to contact them on their website.
Feb 04, 2009 | Quinny Buzz Jogger
Problem with unfolding of Quinny Buzz
Hello jenum71:
Sometimes the stroller does not automatically unfold easily if the seat is attached. If the seat is not attached, and the stroller is still not automatically unfolding properly, there is probably something wrong with the internal spring. have you had the stroller long? Quinny says that the spring will last "virtually forever", but we all know that there are always lemons. If you have not had the stroller for a very long time, contact quinny and ask for a replacement. They have been pretty good about getting them out to clients.
If you have any further questions, feel free to contact me anytime: strollerinfo@gmail.com
StrollerInfo
www.StrollerInfo.com
Mar 21, 2008 | Quinny Buzz Jogger
How to change seat covers on a quinny buzz stroller
Try this link
http://www.quinny.com/media/producthandleidingen/Quinny/08.08%20win1299_Buzz4_UK.pdf
The instructions & diagram are in section 6.2 on page 5 of this 7 page pdf document.
Hope it helps!
Nov 26, 2007 | Baby Gear
Quinny Buzz Jogger Logo
569 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Al Toledo
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
