Question about Mitsubishi VS-50111 50" Rear Projection Television
Mitsubishi va-50111 television
I have recently moved and can not locate the remote to my TV and can not turn it on. Is there a reset button so that I can? The buttons were turned off on the front of the TV so that my 9 month old daughter couldn't mess with them, now I can't even mess with them. Any assistance you can provide would be greatly appreciated. Thanks! Larry
You have to hold the menu button for about 8 seconds. You'll get a sign at the bottom of the screen that says "Front Panel Lock Disabled"
Posted on Oct 03, 2007
    President:
  • 3,130 Answers
Theres nothing you can do without the remoter but you can get the exact remote from 1-800-remotes or http://remotes.com for 59.95 + shipping Sorry this is the best I can do for ya Good luck
Posted on May 05, 2006
I locked the front button on me 50 inch tv its a mitsubishi 1080 hd series and dont have the remote i do i reset the thing
the only way to reset this thing is to bring new remote for this model & unlock with it. get the original remote from authorized service station.
Aug 19, 2011 | Mitsubishi VS-50111 50" Rear Projection...
Intermitent black screen with sound, blue screen-no sound, normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
I have a mitsubishi big screen hd1080 model 50111 how do i unlock the v chip to look at all movies, was given to me by a friend. what is the magic pass code.
On your remote press menu then 1 then 2 then 3. Go initialize option and press enter. Your TV will reset to brand new out of box conditions.
Apr 11, 2011 | Mitsubishi Televison & Video
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
VS-50111 and horizontal lines appear and shuts off
hello i have the service manual which i'll send for free along as you leave me a fair rating thanks
regards
shaun
May 31, 2010 | Mitsubishi VS-50111 50" Rear Projection...
I lost my remote during a move and can't change formats on my tv
You are going to need an original Mitsubishi remote--I do not think in the main menu there is a way to do this without the remote: PART NUMBER FOR THIS REMOTE IS: 290P111010
Almost any Mitsubishi remote that has the FORMAT button on it will work.
If this has helped you rate this solution as I do this here for free.
SD TECH
Nov 13, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Where are the fuses for mitsubishi 50111 located and what do they look like?
There is only one user serviceable fuse on the TV set on the PC board, near where the power cored enters the TV (you will need to remove the back to check this fuse (it is labeled F9D00).
The other five fuses look like small resistors and will require desoldering to replace -- I wouldn't recommend doing this without testing the fuses with a Ohmeter first, to determine if they are bad.
Jun 29, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi 50111
Run the diagnostics.
With the TV power cord plugged in, press the 'INPUT and 'MENU' buttons at the same time -- use the buttons on the front of the TV, NOT the buttons on the remote; a diagnostic Error Code Operational Check will begin, utilizing the 'POWER ON' LED (the green 'POWER ON' indicator light).
There will be a pattern of two sets of flashes, with a pause in bewteen flashes; this sequence of flashes will be repeated a total of five times.
The Error Code designations are listed below:
Error Code Description
12 No eror has occurred.
21 X-Ray Protect circuit.
22 Short Protect circuit.
23 Horizontal Deflection failure.
24 Vertical Deflection failure.
I hope this information helps.
Jun 17, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi WS-55807 television
this tvhas a built in safety feature, fuse, sometimes you can hear a faint popping noise when you turn the tv on and it shuts down. This feature was designed to prevent power surges from hurting your tv any more than it already is. You will have to have someone repair the small problem you have now and reset the tv. 10% of the time you can try holding doen the menu button for 10 seconds and/or unlpugging it for 4 hours to do a hard reset. This hardly ever works though. It will probably cost you about 200 to 500 to fix it. sorry
tom
Jun 05, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-50111 50" Rear Projection Television Logo
151 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
