Question about Sampo Televison & Video
I have a 42" Sampo-PME42S6 plasma TV. Its been running perfect until yesterday when it started to show lines and picture degradation after approx 3 to 5 mins of running. I thought it was the cable box so I changed to a DVD player as the source, the same exact thing happens. Pls help.
  • kerwinrn Sep 13, 2008
    Nope, the hard reset did'nt make it go away.
  • 4,234 Answers
Typically the symptoms you describe can be either poor connection of the connectors and cables or some parts that are starting to break down because of heat. If the set is no longer under warranty, start with opening up the back and reseating all of the cables and connectors. Be careful with the flat ribbon cables coming from the panel itself. Update this with your results. If needed, we can look further.
Dan
Posted on Sep 22, 2008
    President:
  • 1,952 Answers
Change ur pIF you are saying that every thing is connected properly check your video cable it could be bad use a new one if that does not rectify your problem it is time to call in the tech you could be having problem in your video circuit but you did not mention if the screen light up with no picture but with sound or it does not light up blank with sound.however there could be two things 1 if the screen lightup with normal sound it could be a leaky ,open, or shorted, transistor or ic in the IF circuit.2 If the screen does not light up and has normal sound it could be a defective horizontal stage.so it is time you take the set to a tech for repairs.good luck.
Posted on Sep 12, 2008
  • 6,487 Answers
Did you try to unplug the TV from the power outlet for about half day to let it reset itself and also to cool down the unit, and that should do the trick for this problem..
Hope that helps............
    Genius:
  • 2,035 Answers
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works.. this not work check the cable try yo use another pair of cables ,even this did solve your problem then you need contact the company if under warranty ,if its out of warranty then you need get service from local TV repair center....
Good luck..
When I first turn on the tv I get a degraded
Hi did you ever solve this problem? i have the exact same issue, i think its the main-y pcb but want to be sure. green pixels, slow refresh rate on screen, after 5mins the picture is normal till next time i turn it on.
May 25, 2010 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Distorted picture on Sampo 42" monitor
This can occur due to many reasons...the simplest of those is...
Damaged monitor signal cable...results in improper signal transmission
Also check if ths is a problem with the monitor or VGA card...Just connect it to another computer...If it works then its VGA card problem otherwise its a monitor problem.If you are good in electronics then the problem is
1)You have the typical convergence failure of the convergence correction IC's which need to be replaced
2)Cpacitors on the CRT are damaged and need to be replaced..
If you are not familiar with electronics pls dont attempt a repair as it is a high voltage device and the risk of electric shock wil be high.Just drop into a service center if this is the case
Oct 12, 2007 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Need universal remote control code for maxent 42" plasma tv?
I hope that you have gotten this resolved, but if not, or if you have any other questions, here are the codes and some simple steps to run through.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
246
730
746
Becki Barned
DISH Network Customer Service
May 17, 2010 | Sampo PME-42V3 42 in. Plasma Television
Hello experts I recently came into ownership of a Sampo pme42s6. it powers up fine and has audio, but none of the video inputs are allowing a picture. I plugged in an S-video and Analog VHS signal,...
i don't know how much the new one cost but it is fixable. Check the components around flyback transformer , check bad connections, check the flyback it self. It ask some expertise . If you can't ask help for your neighbor technician if he is good you will pay little money. but not less than $80
Sep 18, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Tv only has top right corner showing picture
Hello the picture was good 2 days ago.I took a picture of the plasma ..could please help me with some ideas...thank you..
Mar 24, 2009 | Akai PDP42Z5TA 42 in. Plasma Television
Lost TV mount hooks/fasteners
I am getting rid of my sampo.  I am willing to sell the tv brackets or the stand or the wall mount as well.
Jan 22, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Blue and green lines. no color
I have the same exact tv this sounds like a previous problem that we experienced we resolved ours by plugging into a grand video console. Good luck! Tammy woodpros01@yahoo.com
Jul 23, 2008 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
"No Signal" floating notice on Blue Screen - No other picture
If all connections and the tuner have the same issue, you either have a power supply issue or a bad digital board.
Mar 29, 2007 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Screen blanks out
A digitalizing picture is most likly a bad connection on a screen driver cable or the driver itself is intermittant or the power supply has an intermittant filter on the substain B+ line. hope this hellps.
Oct 08, 2006 | Sampo PME-42S7 42 in. Plasma EDTV
Televison & Video Logo
85 people viewed this question
Top Sampo Televison & Video Experts
Lyle Siemens
Lyle Siemens
Starnley Johnwells
Starnley Johnwells
Are you a Sampo Televison and Video Expert? Answer questions, earn points and help others
