Question about Panasonic Cameras
Panasonic camcorder NV-DS55B. When I put the tape in the compartment and try and close it it makes a different noise to normal and will not pull the tape in. It then ejects it. There is some text on the viewfinder which says F05 (is this a fault code).
SOURCE: Canon zr300 ejects tapes
There is a fix for this which was posted for either the ZR 200 or 400. They call it the "Fonzie" fix. Just hit the camcorder with your fist on the side where the tape goes in (with the door closed). Hit it lightly once, try inserting the tape. Repeat this process with increasing force each time until this works.
Surprisingly, this worked for me. Obviously, there must be something loose for this type of solution to work. I actually had it working once, then it acted up again. I tried the same solution and it's working again. No problems for several days now.
Posted on Mar 24, 2008
ginko
  • 19396 Answers
SOURCE: I have a dvd camcorder-
Did you try removing batteries to see if it clears error?
this is first thing to do.
Posted on Aug 09, 2008
marked
  • 6487 Answers
SOURCE: NV-DS55B panasonic digital video camera.
Cylinder error (F05) usally caused by poor/oxidised contacts on cylinder drive fpc cable to pcb, sometimes caused by seized cylinder or drive.
The cylinder is the round thing that the tape wraps around that has the heads to record to tape, just in case you didn't know.
Posted on Aug 19, 2008
Grubhead
  • 5309 Answers
SOURCE: Panasonic VCR has F06 code
You appear to have a K Mech model. F06 is the code for the mechanism locking after unload. The cause being something to do with the loading motor or the way the carriage is aligned.
Posted on Jun 16, 2009
Exactly the same problem as everyone else. There's bound to be someone who can offer advice on what to do. The camera obviously recognises the fault as F05, but where can you reference the remedy to this F05 code? It's not in the manual as far as I can see
Posted on Mar 22, 2010
Nv ds55b pause record button loose
The little silicone diaphragm spring, which carries a small graphite connector, will have split. There is no glue which will stick to the silicone, so you have to replace it with a new one.
May 23, 2012 | Panasonic NV-DS55B Mini DV Digital...
Aug 19, 2008 | Panasonic NV-DS55B Mini DV Digital...
Panasonic nv Ds30en
I have apanasonic NV DS30 play problem after capturing they could not play
Jan 29, 2009 | Panasonic NV-DS30B Mini DV Digital...
Playback problems with previous recorded miniDV
Just check your setting and make your camera in default setting try to use the recommended tapes only
May 05, 2008 | Panasonic NV-DS55B Mini DV Digital...
Panasonic NV-DS55
Try to restthe setting by default setting and try to take out tape if is there inside.
Apr 09, 2008 | Panasonic NV-DS55B Mini DV Digital...
Transferring video from panasonic nv-ds55b to pc
please try to first use in your friends win 98 then you think smething else.
Mar 15, 2008 | Panasonic NV-DS55B Mini DV Digital...
Feb 20, 2008 | Panasonic NV-DS55B Mini DV Digital...
Need help FAST!! Panasonic NV
remove battery for a while .put it again and try .if not works...remove battery agin then put it again by keeping power switch off. eject and remove cassette .take several eject operations. now try again.
Nov 04, 2007 | Panasonic NV-GS50 Mini DV Digital...
Panasonic nv-ds55
It sounds like the sensor is going bad. Here is the manual for the NV-DS 60, which is very similar to yours. You may need to take it to a repair shop. Good luck.
http://tda.panasonic-europe-service.com/docs/2z5a2cca0fz3z22232z656ez706466z21z1c8fc58f832b60282b1c88e0f0a7f11211283296/pgrp001/pcat008/nvds60eg/753316/IM-NVDS60-65ENG.PDF
Dec 10, 2017 | Panasonic NV-DS55B Mini DV Digital...
Cameras Logo
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
