Hello, I have a hotpoint ultima silent, When i went to put it on this morn, it flashes up h2o with a tap, What does this mean?
Check inlet valve is leting water in
Posted on Sep 12, 2008
Set wash program ,wont start ,there is a tap on display plus it flashes up H2O
H20 means a water inlet problem.
Check the inlet pipe/s are not restricted or kinked.
Ensure that the pressure is adequate.
This cold weather has caused some washer hoses to freeze up.
Hope this helps.
Jan 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint ultima wt940 washing machine,, which is displaying a tap symbol,, when it fills up at the start of the cycle,, h2o flashes on the screen,, then the machine stops. Any advice? Thanks.
H20 is indicating a problem with the water supply.
Check tap/s are turned on fully, no restriction in hose/s, and make sure that there is sufficient water pressure.
Another possibility is that the inlet valve/s are faulty inside the washer.
Please rate my solution.
Thanks.
Nov 07, 2009 | Washing Machines
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Flashing tap icon and h2o
Might be a kink in the hose. Turn off water disconnect from machine then make sure water comes out of hose when waterturned on.( Put into bucket or similar to test) If water is flowing ok then you need a new inlet valve.
May 19, 2009 | Hotpoint Ultima WF860 Front Load Washer
Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
Thanks.
May 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt960
this m,eans the water is not entering the machine it iseither the inlet valve or water off at tap
Dec 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT960
its either a fill valve or you water taps are faulty ie; rounded off knobs easey fix please leave feedback good luck
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
H2o error
I checked everything I posssibly can and ended up booking an engineer who will be here Monday. I'll post what he says and whether or not it's DIY fixable.
Apr 03, 2008 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT ULTIMA WF860
image_bubbleanswer_04.gif I recently had the same problem with my Hotpoint Ultima WF860P and after some investigations, I found a disconnected tube linked to the pressure switch beneath the top cover was the cause of the problem. In short, this tube forces air to the pressure switch and cuts off the valve feeds.
Andrew Algar - Brighton
Feb 16, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
