Back to:
Tags:
RCA Lyra RD2315  MP3 Player
Mp3 player (by 3 users)
posted by Michelle on May 04, 2006
Why can't i put any music on my mp3 player? when i plug it into the computer it won't show up on the computer program Windows Media Player or MusicMatch Jukebox
Comment by Michelle, posted on May 10, 2006
I did this but it still didn't fix it! Thanx any ways
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Dec 27, 2007
My virgin Pulse Mp3 want show up either musicmatch or window Media player what should I do
Comment by roma628, posted on Nov 16, 2007
Whenever i try to turn my mp3 player on, it just turns right off. I thought it was the battery so i tried to charge it. It says transfer mode usb connected or what not but the bars do not move. I'm getting frustrated with this.
roma628
Best Solution
posted on Jan 20, 2007
FixYa! (100)
ohiostate
Rank:Apprentice Apprentice
Rating: 94%, 5 votes
Update to Win Media player version 11. IT WILL WORK!!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on mp3 player:
I don't want to Accept this solution
Solution #2
posted on May 04, 2006
Helpful (85)
techman
Rank:Guru Guru
Rating: 87%, 6806 votes
Michelle
Are you sure thet the usb port your using is setup and active?? Ive seen this before where the device wasent detected because the puter didnt see it. Make sure your usb software is installed . you could go to systems in control panel and then to device manager then scroll down to the usb ports and make sure there active and no yellow or red marks on them. The troubleshooter built into windows will assist you to repair them if they are not active,. Good Luck
Thank You!
Solution #3
Thanks for Trying (70)
dovi
Rank:Guru Guru
Rating: 88%, 2269 votes
Techman is right, you should check first that your USB port work properly.
You can see its status in the device manager. By right klicking and then properties you will find out USB port status. If it will say that you have a problem, go thru the troubleshoot process, in case it will tell you that the device is working properly,go to the driver tab and then to the uninstall and remove the drivers.
Now move back to the device manager main screen and on top klick on the action tab then on scan for hardware changes, it should install the drivers again and hopefully it will fix your problem. Good luck!
Thank You!
Solution #4
posted on Jan 22, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
iriver ifp-799 series are not plug and play devices. Even if your usb port is working, it cannot detect the portable media player. You cannot transfer music files thru the windows media player or musicmatch jukebox, it has its own Iriver Music Manager - you can download this on their website. If it did,nt work, burn your mp3 player.
dnomde
Thank You!
Solution #5
posted on Jan 21, 2007
Not Rated (0)
liddy
Rating: 0%, 0 votes
take the battery out and then put it back in
Thank You!
Solution #6
Not Rated (0)
ohiostate
Try updating Windows media player to v11. worked for me
Comment by ohiostate, posted on Jan 20, 2007
Trust me on this one. Update to Windows Media player v11. I was pulling my hair out for 3 hours with same issue until I read an obscure forum with same issues. Windows v11 will recognise usb as mass storage( whatever the manufacturer calls it) and you will be able to sync songs and libraries to it. I just wish the instruction book had told me to have latest version of media player and all would have been fine.
Thank You!
Solution #7
posted on Jan 15, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
HOLD DOWN THE FORWARD BUTTON WHILE PLUGING INTO THE COMPUTER. IT WORKED FOR ME. GO TO ASK DAVE TAYLOR.
Thank You!
Solution #8
posted on Jan 10, 2007
Not Rated (0)
dessie
Rating: 0%, 0 votes
apparently this is a well-known problem, i have also encountered it and cannot find a solution, if you have a look on the iriver enthusiast's forum, they explain how you could resolve the problem, but it was far too technical for me to understand,
it's not your computer that's at fault as far as I understand
good luck
Thank You!
Solution #9
Not Rated (0)
gilloz
Rank:Guide Guide
Rating: 84%, 8 votes
Try this. Download and install Powertoy TweakUI from Microsoft. After you install TweakUI, open it and click the + of My Computer, click on Drives and verify that you have additional drives checked besides the ones that are already installed on your computer. Even though they may have a Red circle with a White question mark, put a check in the box next to the drive. Repeat the above for Drives listed under AutoPlay. Click on Apply after your done, Restart your computer and see if your MP3 is listed. good luck.
Thank You!
Solution #10
posted on Jan 07, 2007
Not Rated (0)
Stonegrub
Rating: 0%, 0 votes
go into my computer and look for the external drive named lyra then minimize it. go into the music you want and right click it then click show location on computer then drag it into the minimized lyra external drive it should show a loading screen then your music is transferred. (this only works on microsoft os)
Thank You!
Solution #11
Not Rated (0)
megabyte67
Rating: 0%, 0 votes
I'm having the same problem. Other devices are working on the usb port.
Comment by megabyte67, posted on Jan 07, 2007
I think the problem is we have 1.0 usb ports. We nee high speed 2.0 usb ports. That is what my brother told me tonight, he is a computer analyst.
Thank You!
Solution #12
posted on May 21, 2006
Not Rated (0)
Yong
Rating: 90%, 2 votes
Basically, this should solve almost every firmware issue with the Aigo DIY MP3 Player - Unless it was run over by a bus. NB: Despite searching for this info for MONTHS, nobody has yet published this "How To Fix" information in english on the net.
If your pc "suddenly" does not recognise your player, or it displays an error message like this "Error: Reformat player" when you turn it on, then you need to load the firmware into your player again. To do this, you need to have your Digital Audio Manager program installed on your computer. You should have done it when you bought the player, but if you need it, then it's available here: http://www.aigo.com.sg/Download.cfm?DObj...
Follow these steps:
1. While holding down the play/pause key, plug your player into a computer's usb port.
2. Dependent on your operating system,(XP or Win2K) you may see a "New Device Found" dialogue come up. Let it install software, & press yes to all the certificates and stuff to install the software . - What it's doing, is your player is uploading it's firmware to your pc from its backup flash memory so that it can be reinstalled.
3. Unplug the player. Then plug it back in. Start the Digital Audio Manager. Then find in your computer (In the same folder as your Digital Audio Manager program: Default folder is c:\Mp3 Player) an executable file called stupdaterapp.exe double click on it to start and in the window, tick "format" and start the firmware update to your computer by pressing START.
4. Watch the progress bar until finished and That's it! :-)
All the best
Thank You!
Can you Help with these MP3 and Digital Media Players problems?
RCA Lyra RD2315 (512 MB) MP3 Player
I've deleted my entire playlist in order to create a new...
How do u add to my selections?
when I turn on my player it starts flashing RCA loading....
i have gotten the upgrade from musicmatch player the yahoo...
hi, i have an omni 2gb mp3 and i have downloaded lime...
Loading problems.
Repair Service
Find MP3 and Dig. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
