Question about HP PhotoSmart 7760 InkJet Printer
Error message Computer will not work unless this "Cartridge Service Station is stuck" is resolved.
  • Neville McManus Jul 21, 2008
    The red warning light flickers to indicate that there is a problem.The nmonitor states Cartridge Service Station is stuck:press OK
This is not a solution, but rather the cause.
The manual suggests that there is something blocking the cartridge station and to clear it out. Cannot see anything out of the ordinary. Had a bad paper jam (4x6 photo), close to 1/2 doz sheets stuck which had to be removed with pliers. Error msg has ocurred as a result?
HELP!
Posted on Oct 16, 2007
    Champion:
  • 277 Answers
Hi http://h10032.www1.hp.com/ctg/Manual/bpy21203.pdf good luck
Posted on May 08, 2006
SOURCE:
DISPLAY BUSSY
Remove printer covers, put small peace of papers in door sensor & cartridge sensor,plug in power see where carriage stuck? Might be carriage stuck in service station,disconnect power, rotate manually service station gears for un locking the carriage assm.Once carriage unlocks check why it's stuck? Is there any paper partials jammed in side or service station movement obstructed by waste ink.. Remove service station clean with forced water, allow it to dry, apply silicon grease for smooth movement, fix it back.. test it..I hope this exercise will resolves you issue.. but its too dirty work,...
Jul 20, 2012 | HP Designjet 110plus nr InkJet Printer
Printer hp 8150 messages says cartridge server station stuck
Technical skills required to do this process, remove top,side doors, un lock carriage from service station, remove service station, clean & lubricate it for free movement, fix it back. try for print.. this is only solution for this issue, but mind that its dirty work...
Jan 04, 2012 | HP Photosmart 8150 InkJet Printer
My design jet 500 says I am out of ink, when in fact 3 of 4 are full, why does this happen and is there a way around this issue
hi, for this issue to resolve power off the printer , remove all cartridges check the contacts in the ink station assy,try cleaning with a lint free cloth,try replacing cartridge and if the issue still persists conduct service test for ink station assy if the result is negative replace the ink station assembly. You could also get repetitive Ink Cartridge Error messages if the Ink Cartridge is leaking.
Venkateshwar, hp technologist, contact:+91 0086427911
Sep 21, 2011 | HP DesignJet 500 InkJet Printer
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
Cartridge Error 50C consult user guide. I
Cartridge Error
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Photosmart 7960 Q3020A CN411310FG Red light flashes. Displays: cartridge service station is stuck. Press OK Result: cartridge until moves freely but fault is still ...
unplug the power cord of the printer from the electric outlet and wait for 5 minutes then replug it.it should get resetted and start working.
Nov 20, 2008 | Office Equipment & Supplies
Print cartridge cradle is stuck
solution for...
" CARTRIDGE SEVICE STATION IS STUCK " with a blinking red light...
it's a bit difficult...just fixed it today....
first of all...u have to be sure that your service station is clear from any other old ink that maybe dried....that stuck the movement of the service station...
if it doesn't work again...folow the next step...
1. u have to pull out the service station... ( the difficult one ..!!! )
2. under the service station, there is a small motor....just find a new one and change it..
it works...
.....i found this new motor in an old hp printer's service station that i have...
thank u
Jul 04, 2008 | HP PhotoSmart 7760 InkJet Printer
Error light wont go out, and button wont work for sizes etc.
check the computer for the error code, most commonly a empty/faulty ink cartridge or a service error
to resolve either replace offending ink cartridge or note error message and take in for service,
Jun 03, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
Error message on photosmart 8150
Well, what you want to do is you will see a wire coming from your cartridge, pull that wire (not hard) just so that way you can move the cartridge and you should be able to fix that problem.
Apr 25, 2008 | HP Photosmart 8150 InkJet Printer
HP PhotoSmart 7760 InkJet Printer Logo
742 people viewed this question
Clive
Clive
Thomas F. Schneider
