Question about Creative Labs Inspire 4400 Computer Speakers
Not playing im missing the volume control cord that plugs up to the back of the woofer does this mean the speakers are not going to work or can i just control the volume from the task bar
    Problem Solver:
  • 7 Answers
The volume control does give you more control on the volume of the speakers but yea if you just get a cable going from one end to the other and it doesnt have a volume control it will work no problem just control the volume from the task bar, it will work i can guarantee that because i have the same speakers and i tried it out and works perfectly fine, you cant tell the difference because there isnt one just control from task bar!
Posted on Feb 11, 2009
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
MX6050D Subwoofer Issues
Hello, welcome to Fixya!
Fault is either from the main system or the sub-woofer itself.
You need to test both unit in order to detect which of the two is giving the fault, so that you can concentrate on the faulty unit.
Test the woofer with a AA battery or any other battery. Put your ears close to the woofer and observe if you will hear any sound. If the woofer makes sound, then it means the woofer is working, but if it doesn't make sound, then it means the woofer is defective. Or you can disconnect one of the working speakers and connect the woofer to that part. If there is no sound, then obviously, the woofer is defective.
If the woofer seem to be working, then the unit needs to be tested also.
Connect one of the working speakers to the sub-woofer's section of the main unit. If the speaker doesn't bring out sound, check the system's menu settings, check the volume and make sure the sub-woofer volume is raised to the highest level and not on mute. ( Note that most Theater systems has separate volumes for each speakers). If the volume is raised to the highest level and there is still not sound from the woofer part, then it means the woofer channel has burnt. It could be a fuse or a defective channel. At this point, I think you need help from a repairman.
I hope the above is clear.
Nov 17, 2011 | Audio Players & Recorders
Dell speaker connection color code needed
  • *Turn off your Dell laptop.
    *Connect speakers to the speaker control box. The speaker control box varies depending on the speaker system you have. Two-speaker systems will have a female jack on the back of one speaker that you plug the other into the second speaker. If your system has a sub-woofer, all of the other speakers will plug into it. The connecting cords are color-coded to the jacks on the back of the control box.
    *Plug an audio cable into the "Audio-In" port on the back of the control box. If the audio cable is color-coded, it will be green.
    *Plug the other end of the audio cable into the headphone jack on your laptop.
    *Plug the speakers' power cord into a surge protector to protect your system from power surges. *Plug the surge protector into a wall outlet.
    *Turn on your speakers and set the volume at a medium level. Be prepared to turn the volume up or down after you turn your laptop on.
    *Turn on your laptop and confirm that sound is coming from your speakers.
    Thanks for rating
    Good luck
  • Jan 25, 2011 | Dell Dimension 4600 PC Desktop
    My dog ate the cord for the volume control. How can I buy a new one?
    type in Logitech Z-2300 speakers volume cord that may help or check from where you bought them
    Jan 29, 2010 | Logitech Z-2300 Computer Speakers
    My speakers only work one at a time...
    Check you have plugged them into the correct socket on the back of the PC ..
    Chances are you have 3 sockets - first = 'front' (or pair), middle = 'back' (for 4+ speaker sets) and last = 'center & sub-woofer' ..
    Sounds like you have plugged into the 'center & sub-woofer' socket :-)
    Mar 13, 2009 | Dell A215 Computer Speakers
    Broken volume and tone remote cord for the SoundSource 3200 Seies
    I just need a new connector cord as described. I was hoping I could buy a new one.
    But it looks like I will have to take it to an electrical fix it shop somewhere to see if they can fix the pin connector.
    Thank you.
    Feb 02, 2009 | Manhattan (168670) Computer Speakers
    Control Pod for Bose Companion 5 speaker system
    I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
    First, unplug the power directly at the back of the woofer while the unit was on;
    Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
    Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
    It worked like a charm. I hope this is helpful!
    Jan 29, 2009 | Bose Companion 3 Computer Speakers
    I moved, and now my speakers won't work
    check for the power button is on behind the woofer or speaker,if ur speakers does not have switch hten select the volume control optin and click the properties and check the sounds by clicking the speaker images in that window.if u have problem again,askme through fixya again.
    Aug 16, 2008 | AOpen MS-810 Computer Speakers
    Subwoofer help
    hard to tell whats causing this .Just curious make sure speaker wires going to subs are POLARIZED meaning positive from amp is with positive at woofer and NEGATIVE is with negative at woofer.When these are crossed and when volume is raised you will hear the bass cancell each other out..
    Dec 06, 2007 | Car Audio & Video
    Creative Labs Inspire 4400 Computer Speakers Logo
    856 people viewed this question
    Top Creative Labs Audio Players & Recorders Experts
    Carlos L. Burgos
    Carlos L. Burgos
    Mohamed Ismail
    Mohamed Ismail
    Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
