Laptop charger gets very hot(50
Laptop charger gets very hot(45 cent) and charging extremely slowly. Is it a battery or charger problem.Both 18 months old.
  • nikki31069 Apr 01, 2009
    My Acer charger gets so hot, it would give you 3rd degree burns if you touched it long enough. WTH???
    Sergeant:
  • 320 Answers
Its absolutely a charger problem. This is not a big issue. If its charging perfectly then neglect it. or else replace it with new charger. Thank you...
Posted on Sep 12, 2008
Why is my Samsung Galaxy Note 10.1" charging very slow.
There are a several reasons why the Galaxy Note 10.1 is not charging as much.
1. Too many application are turned on (check the task manager)
2. Too many notifications icon are turned on ( bluetooth, gps, wifi, etc.)
3. Plugging your charger using a computer
Are you using the original charger and plugging it into a wall charger?
How long did you use the Note 10.1 previous to noticing the damage? and was it extremely hot at the back?
If so, then maybe the battery isn't picking up from the charger. I've watched back to back movies while still using the charger but this can prove very devastating on the charger's outlet which became extremely hot after 4-5 hours or so of charging continuously. It turns out, the galaxy note 10.1 can withstand 8+ hours of ongoing movies but the charger outlet cannot. *If I didn't unplug it after 4-5 hours, the plug what have fried.
In this case, i believe the charger is more likely damaged than the Galaxy Note 10.1, which is more of a better scenario. Especially, since you charged it for over 24 hours, meaning it's charging something, but very slowly. Operating Galaxy Note while charging can prove detrimental in the charger's outlet and can in fact burn out.
I hope this info is helful,
Jason Chan
Jul 01, 2014 | Samsung Galaxy Note 10.1"
How do I charge the battery on a 1990 xlh sportster 1200
The voltmeter test provides general indicator of battery condition. Check the voltage of the battery to verify that it is in a 100 per cent fully charged condition. If the open circuit or disconnected voltage reading is below 12.6 V, charge the battery and then recheck the voltage after the battery has set for one to two hours. If the voltage reading is 12.8 V or above, perform the load test described below.
The load test measures battery performance under full current load and is the best indicator of battery condition. Load testing a battery tat is not FULLY CHARGED i.e. at 12.8 VDC can permanently damage it. Fully charge it first and then let it stand for at least an hour before the load test is done. You also need a load tester AND you should know how to perform a load test. Often the best way to load test a battery will be to take it to a battery shop and have it done there.
VOLTAGE and STATE OF CHARGE FOR AGM BATTERIES IS:
12.8 VDC is 100 per cent
12.6 VDC is 75 per cent
12.3 VDC is 50 per cent
12.0 VDC is 25 per cent
11.8 VDC is 0 per cent
COLD CRANKING AMPERAGE (CCA) for a DYNA battery is 270
Battery Charging Rates/Times (Approximate)
FOR A 19 AMP HOUR DYNA AGM BATTERY
BATTERY STATE OF CHARGE is 12.8 VDC is 100 per cent Charge; Rate of Charge is N/A
BATTERY STATE OF CHARGE is 12.6 VDC is 75 per cent Charge; Rate of Charge at 3 AMP is 1.75 hours at 6 AMP is 50 minutes at 10 AMP is 30 minutes at 20 AMP is 15 minutes
BATTERY STATE OF CHARGE is 12.3 VDC is 50 per cent Charge; Rate of Charge at 3 AMP is 3.5 hours at 6 AMP is 1.75 hours at 10 AMP is 1 hour at 20 AMP is 30 minutes
BATTERY STATE OF CHARGE is 12.0 VDC is 25 per cent Charge; Rate of Charge at 3 AMP is 5 hours at 6 AMP is 2.5 hours at 10 AMP is 1.5 hours at 20 AMP is 45 minutes
BATTERY STATE OF CHARGE is 11.8 VDC is 0 per cent Charge; Rate of Charge at 3 AMP is 6 hours, 40 minutes at 6 AMP is 3 hours, 20 minutes at 10 AMP is 2 hours at 20 AMP is 1 hour
The figures listed above assume that the battery is charging at room temperature. If warmer than room temperature, use a slightly shorter charging time. If colder, use a slightly longer charging time.
The use of constant current chargers to charge maintenance free batteries is not recommended. Any overcharge will cause dry out and premature battery failure. If a constant current charger is the only type available, do not exceed the charge times listed above and do not continue charging the battery if it gets hot. When charging, never exceed 15 volts for more than 30 minutes.
If the battery gets hotter than 110 degrees F or 43 degrees C during charging, discontinue charger and allow the battery to cool. Overheating may result in plate distortion, internal shorting, dry out and/or other damage.
Apr 22, 2014 | Harley Davidson XL 1200 S Sportster Sport...
Getting no lights
first only charge the chair prior to using it, constant charging will dry out the batteries. though not likely the batteries now sounds like a loose connection somewhere, batteries just don't stop they fade out slowly. look for loose connector
Dec 03, 2012 | Health & Beauty
The whole camera and battery gets hot when charging
Charger is faulty. Check your charger by technician.
Aug 07, 2012 | Kodak EASYSHARE M763 Digital Camera
Toshiba satellite battery won't charge
DID YOU NOTICE ANY OVER HEAT IN BOTH,THE PC OR CHARGER? IF SO THE CAN BE 2 ISSUES.
1-THE CHARGER
2-THE BAT
IF YOU TRY TO CONNECT THE CHARGER WITHOUT THE BATT,THE CHARGER GET HOT? (1) ,DO THE CHARGER IS OK (2)
Apr 26, 2012 | Toshiba Satellite A65-S126 Notebook
Htc wildfire a333 battery hot software
Htc wildfire a333 batterynot getting anyware
Apr 21, 2012 | Cell Phones
Acer Aspire 4520 laptop: Battery not charging
If your adapter /charger has low voltage it will not properly charge the battery, any battery. Go that route and try another adapter..
Sep 06, 2017 | Acer Aspire 4520-5582 Notebook
WHILE CHARGING THE LAPTOP IT IS NOT GETTING CHARGED . as well as service centers in mumbai
That is the usual sign that your battery needs replacement. If the battery is over about 18 months old or you either use it a lot and to a low charge state or leave it on the charger most of the time then it has most likely reached its service life.
Can't help you with a source for a new one there.
Apr 20, 2010 | Computers & Internet
When using laptop, battery and charger become extremly hot during use. So I unplug charger until battery runs low then recharge? Unit is still under extended warranty
Those chargers, especially newer ones, shouldn't be getting that hot. Definitely have it replaced by them free while it's still under warranty.
Feb 18, 2010 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
489 people viewed this question
David Payne
David Payne
