Question about ASUS P5B-E Motherboard
Slow boot suddently what happen is that I boot the os, there 's a long wait with asus screenshot . hard disk is not working , it can last 1 or 2 minutes then the boot start. usually that screenshot last a couple of seconds. already reinstalled oll drivers.thanks
  • alberto_bern Sep 12, 2008
    it's already set to boot from hd
I'm glad for your excellent rating , if I did not give you enough info is because I don't know what kind of info can useful for your answer. I'll try with batteries .thanks very much.I'll let you know.
Posted on Sep 13, 2008
  • 781 Answers
You could have a USB device connected and switched on and when you boot its trying to find it and boot from it
You could set BIOS to boot from hard drive to see if it fixes it
Posted on Sep 12, 2008
  • David
    David Sep 12, 2008
    try changing M/board battery
    If that is flat it may require waiting until enough power there to start and by the way I was not trying I answered according to your question. if you do not give enough info do not blame me In 80% of cases my answer would have fixed it *********
Why my acer aspire say system not found
The system cannot detect the hard disk drive. Before you start up, re insert the hard disk. Remove the memory card and clean it with soft cloth or tissue paper. After doing these..Start up your computer and see the results. If nothing happens, restart your laptop, hit F12 key & set the hard disk drive to first boot device then press the Enter key. wait till the OS comes up.
Aug 19, 2014 | Acer Aspire 4720 Notebook
Asus m2nse
Is it slow or does it not boot?
Apr 12, 2014 | ASUS Computers & Internet
No Hard drive found
I am in agreement William.
What do the Radial Aluminum Electrolytic Capacitors look like?
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://support.asus.com/Download.aspx?SLanguage=en&m=P4SP-MX&p=1&os=
Post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | ASUS P4SP-MX Motherboard
Windows XP starts then restarts over and over
Heaps of things can cause this - corrupt software, corrupt OS, virus, hard disk error. etc
First of all, I'd try turning the pc on, press the F8 key repeatedly until you get a list of options in dos mode text.
The first one listed will be safe mode.
use the arrow keys to select Last Known Good Configuration.
press enter, and, if you are in luck, your system will boot up just like normal.
This has fixed numerous pcs in the past.
If it works, I'd advise doing a checkdisk on the hard disk and running an AV scan, just to make sure.
If that fails, I'd again press F* repeatedly on boot, then select safe mode.
Wait ages, until you get a prompt with heaps of text, with yes to go to safe mode, no to go to system restore.
Select NO, and the system restore wizard will start... select a date previous to when the issue started, wait a while, and then test. if that goes thru, but the system still wont boot, i'd rerun system restore, but choose an earlier restore point.
If that fails, you'll need to boot from an XP disk, home or pro - the one that matches your OS - home or pro... boot from the cd, at first screen press r to repair via the recovery console.
select your os partition ( usually just press 1)
put in your admin password (usually just press enter, unless one is set)
and, when you can see the command line...
type in
chkdsk /r c:
and press enter.
this will check and repair, if possible, any faults on the hard disk.
once this completes, reboot and retest.
If that fails, you'll need to again boot from an XP disk, at the first screen press enter to install OS, press F8 to accept the licence agreement... then, if and ONLY if you get the option to press "r" to repair, press R, and allow it to repair the OS.
DO NOT CONTINUE PAST THIS SCREEN OR CHOOSE ANY OTHER OPTION OTHER THAN R, as you will OVERWRITE YOUR DATA.
To reiterate, if you don't get the option to press R to repair STOP, or otherwise say goodbye to your files.
you will not get the option to repair if you either are using the wrong xp disk, ie home disk with pro OS, or vice versa, or if the hard disk is corrupt, or the OS is too badly damaged to be recognised...
Hope this info helps.
May 21, 2012 | Toshiba Satellite 2435-S255 Notebook
Booting issue with intel D865GSA
First remove the hard disk and see whether you have boot error if you have boot error insert the os cd in to drive and boot from the cd if it works fine you have a problem with the hard disk to clear the hard disk problem use a desktop computer and insert the hard disk as slave in the desk top and boot the desktop with the original drive then right click my computer click mange then disk management and find the laptop hard disk the delete all the part ion in the laptop disk then switch off the desk top and insert the hard disk in the laptop and reload the OS
Feb 14, 2012 | Intel D865GSA (BOXD865GSAL) Motherboard
My Asus Eee pc 900 is very slow booting. I disconceted the cmos battery and this helped for a few weeks but am now back to taking a good 20 mins to boot, Now the cmos trick wont work. Anyone got any ideas...
Sounds like you disconnecting the cmos and it helping was just coincidence.The hard drive may be bad or your OS needs to be repaired or reinstalled.Alot of times when it does as you indicated the boot sector maybe corrupt or your hard drive has bad sectors where the boot info was written on the hard disk
Jan 21, 2011 | ASUS Eee PC 900 PC Notebook
No operating system found
just try to repair your OS if you are using windows xp. use that repair option after F8 during installation of XP.
Jan 07, 2010 | Compaq Presario Notebook
Speed of harddisk
Run A disk Defragmentation By going to
My Computer -> Right click on C: -> Properties -> Defragamtion
Nov 27, 2008 | Computers & Internet
Sume time not booting os.then windows opening very slow
Hi there
you might have a failing hard disk or motherboard, try clear c-mos battery and try again . Also replace any faulty ram and other hardware that may cause the problem , unplug FDD, CD ROM and other devices , replace keyboard and mouse
Regards
Roger
Nov 12, 2008 | Intel D101GGC Motherboard
ASUS P5B-E Motherboard Logo
149 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
