Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Akai Plasma PDP4247-FA No turn on only clicks 3 times
Hello:
I could use some help on this Akai 42inch plasma. Is their any
common part that goes bad on the power supply board (APS-173)
that will cause the VS voltage not to come up? I sure because when I
disconnect the out connector I still have no VS voltage (no 83.3Volt)
Thank You
  • GeneralKumar Jan 13, 2009
    i have the same problem. gonna call the tv repair place tomorrow
  • 395 Answers
SOURCE: AKAI PDP5006H Plasma tv
Have the SSB modual replaced. the problem is the talk back to the power supply shutting down the system. it may need prior authorization to order but best guess is SSB after that it 's the digital board. have a tech determine the ture problem. the best thing to do is call the akai for the nearest repair or go to the web sight. some of the akai products are made by Funia.
Posted on Jan 16, 2008
SOURCE: Akai Plasma TV's screen suddenly went blank -model PDP4294
MINE DID THE SAME, POWER SUPPLY WENT OUT, AKAI HAS NO REPLACEMENT PARTS, TV REPAIR PLACE SAID THROW IT IN THE GARBAGE, COMPLAINT TO AKAI AND THEY ARE SUPPOSE TO SEND ME A VOUCHER FOR A NEW TV...2 MONTHS AND NOTHING YET???
Posted on Jan 23, 2008
SOURCE: plasma tv screen has green pixelating into pictures
NO. Return for exchange. Green and Red Dots are Common with Akai/Viore. Google Viore 42 plasma and read. Same Company = Same TV = Same Problems
Posted on Mar 19, 2008
  • 2326 Answers
SOURCE: Need help finding an Akai LCT2701TD Power Supply Board Assembly
It seems like there are not many of these service parts available anymore. The only way to get your LCD working again will be to repair it.
The repair involves changing the defective parts to restore the LCD functionality.
If you need more info, you can write to jah2mil@hotmail.com
Posted on Jun 16, 2008
Same thing for me. TV just turned off one day and won't come back on. LED flashes red. Someone said it's because a cooling fan went out. If I can't find someone to fix it I'll take it apart and tinker myself. 32" with dvd built in was barely over a year old.
Posted on Aug 05, 2008
I have a pdp4247 plasma i have a 3" white line down the center /w
there are no bulbs in plasma tv's. the problem is most likely a bad video board (what converts the digital input to usable picture for the screen) it will need to be replaced, probably better to get a new tv.
May 21, 2010 | Akai PDP4225M 42 in. Plasma Television
Akai PDP4247-L PLASMA main power supply module
Please click on this link to get the main power unit on for your TV:
http://www.shopjimmy.com/showparts.cfm?item=075009&ps=750&pn=9
Good luck...
Sep 08, 2008 | Akai Televison & Video
1) Is the TV plugged directly into an outlet or is it plugged into another device, such as a cable box or audio receiver? If it is, try plugging directly into a wall outlet. Sometimes, devices like cable boxes don't provide enough current to power on more powerful newer TVs (like Plasma, LCD, etc) .
2) Check the manual to see if the flashing LED is a code for something you need to troubleshoot. The number and color of flashes may correspond to a problem that may or may not be easily fixed.
Hope that helps. Let me know how you make out.
Jan 15, 2008 | Akai PDP-5006HRB 50 in. Plasma Television
My akai pdp4225m 42inch plasma went out. when i turn it on i dont get the blue akai splash screen. just black. any ideas on what part to order?
You may have one or two problems, the power supply has failed or the Y-Sustain board has failed also. The more common problem is the Y-Substain board if fails the most in plasma television, next comes the power supply then the X-substain board, My best solution for you is to check the power supply first and consider ordering the Y-Board also, the PS is usually the center board and the Y-Board is to the left of it. The X- Board is on the right side..
Dec 03, 2009 | Akai PDP4225M 42 in. Plasma Television
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Orion 42inch plasma screen tv problem
most likely a bad Plasma Display Panel. Costs more than a new TV
Jul 22, 2009 | Televison & Video
Yes there two power supply unit one for the main power supply is used for the plasma screen which helps to display the image on the tv screen ,So you need to replace the main power board did they say they have it??
Sep 08, 2008 | Televison & Video
Plasma tv screen has green pixelating into pictures
I had the same problem and solved it with a factory reset. hold menu button dowm for 10 seconds and it will alow you to reset all the colors.
Feb 01, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
LG plasma tv 42 and 50 inch
probably you switch was sticking causing it to behave that way.just monitor you tv if it happen once more then it will be time to call the tech.standby my brother.
Apr 03, 2007 | LG 50PX4DR 50 in. Plasma TV
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
90 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
