Question about Brother DR-400 Replacement Drum - 20000 pages Printer
Hl1440 drum indicator flashing
Hi
My printer wont work and the drum light is flashing. I purchased a new toner and drun and it is still flashing and wont print. Any ideas??
  • kelly-ben Sep 12, 2008
    The drum light is still flashing and printer doesn't work.
    Thanks so much for your help. Wish I contacted you before wasting my money on a new toner and drum. Much appreciated!
    Sergeant:
    Champion:
  • 214 Answers
Turn of the power ,turn on the power holding the button ,wait, then when the "drum" light is burning wait a sec then press the button again ,the printer will "dump" whats in its tiny 0.5mb memory and start a self diagnosis and will begin to print the results of the test .. Dont ask . after a week of trying to get this fuser malfunction error to stop ,it now works well ,and ive printed more than 100 pages today.. think it has something to do with the capasitor suppling power to the memory and this memory needs to be cleared of errors before the printer can operate normally again.
Posted on Sep 12, 2008
    Genius:
  • 3,422 Answers
HI,
1. Open the front cover and leave open while completing the following steps.
2. Turn the printer off.
3. Hold the 'go' button while turning the printer on. All panel lights should be on.
4. Release the 'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7. Press the 'go' button 5 times.
  • 3 more comments
  • Priya darshan Sep 12, 2008
    Here is another home remedy you can try....Start with the white paper trick mentioned on below link. I used punches from my hole punch with a little glue from a
    glue stick.
    http://www.epiicenter.com/tips/toner.htm...
    Please don't forget to accept my solution as fixya.
    Can you please let me know whose solution helped you fix the problem.
    Master:
  • 726 Answers
Ok turn it off take the toner out clean all the terminals put them back in make sure everything is closed properly turn the machinie back on and let me no what happenes then
Lines on paper produced by lines on drums new
The link below will provide you with all the necessary information to fix issues related to the HP Laserjet 2420 Printer
HP Laserjet Troubleshooting
Also, try the steps below.
1. Turn the printer off, and turn it on again.
2. Force a calibration by selecting CALIBRATE NOW from the Print Quality Menu.
1. Press example (Select) to enter the MENUS.
2. Press example (Down Arrow) to highlight CONFIGURE DEVICE.
3. Press example (Select) to select CONFIGURE DEVICE.
4. Press example (Down Arrow) to highlight PRINT QUALITY.
5. Press example (Select) to select PRINT QUALITY.
6. Press example (Down Arrow) to highlight CALIBRATE NOW.
7. Press example (Select) to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
3. Perform a cold reset on the printer.
1. Turn the printer on.
2. Watch the control panel.
3. When the memory starts counting, press and hold the green example (Select) button.
4. Continue holding the green example (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
6. Press example (Down Arrow) button once. The control panel will display COLD RESET.
7. Press example (Select). The printer will perform a cold reset and then continue its power-on sequence.
If this issue persists, contact an HP-authorized service or support provider. ( 1-800-474-6836 )
If the Toner is newly purchased and it is because of faulty toner, HP will replace it for no charges.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 05, 2011 | HP LaserJet 2420 Printer
Hi, the drum light keeps flashing on my printer and won't print. I purchased a new drum and this fixed the problem for two weeks but now it is flashing agian, how can I sort this? thanks
Try this.
  • Take out the drum and toner.
  • Slid the tab on the top right from right to left 20 times.
  • Reinstall the drum and toner.
This should do it.
Jun 22, 2010 | Brother HL-2040 Laser Printer
Brother HL1440 has dirty lines on copy how can I clean. Is there something I can buy I am not mechanically inclined.
its the drum or the toner. if you have an old toner run a test with it. If it clears up its the toner cartridge. If not its the drum unit. I sell the toner cartridges for 40 and drum for 65. Steven 818-888-0006
Mar 10, 2010 | Brother HL 1440 Laser Printer
Low print quality
It depends upon the number of prints you have done since Feb and the toner cartridge capacity. Some toner cartridges have 2500 page capacity others have 5000 pages or more.
If you think you have not exceeded or reached the cartridge capacity, take it out of the printer and give it a shake in a horizontal position to distribute the toner evenly across the drum and place it back in the printer. This also works when the toner is nearly empty.
Sep 09, 2009 | Brother HL 1440 Laser Printer
CC and drum Icon will not go out after changing toner cartridge
This Machine needs a copy cartridge. Replacing the toner will not clear it. The copy cartridge is the drum unit which is why the drum light is on. With the new copy cartridge a chip on the cartridge will reset the counter and clear the "CC" and the drum light. If you cant find this I can send you one. I believe on this model it is user replaceable.
Oct 31, 2008 | Office Equipment & Supplies
I have a lexmark e250dn printer. Today the printer has stopped working. The help ! indicator on the printer is an orange color as well as the toner/and drum indicator is an orange color.The ready indicator...
Here is how to reset the photoconductor kit counter:
1. Make sure the new kit is installed and the printer is turned ON.
2. Open the front panel.
3. Hold the Cancel button in until the front panel LEDs flash.
4. Close the front panel
May 25, 2008 | Lexmark Office Equipment & Supplies
Flashing red light
On the alarm and data light blinking, it is saying the toner cartridge is empty. You will need to replace it. Once in a while you can remove the toner cartridge and shake it and have it work for a little while longer. This does not work all the time however.
If you can't get it to work by shaking it, you will need to purchase a new toner cartridge.
When you have the new cartridge, you will need to slide the blue corona wire cleaner back and forth. This is just in front of the toner cartridge in the drum unit on the top of the drum unit. There is a small light blue colored piece of plastic with an arrow in it that you will just push back and forth. This will help the drum unit do its job better.
May 06, 2008 | Brother HL 1440 Laser Printer
1700 Drum Error
hold cancel button down with door open, this should rest it
Mar 27, 2008 | Dell 1700n Laser Printer
Printer problems
All four lights flashing indicated a problem only a service center can repair.
Press the Go button and a new set of indicators will appear.
The yellow toner light only indicates a fuser unit failure.
The yellow drum light only indicates a laser unit failure.
The yellow toner light AND the red paper light indicates a main motor failure.
The red paper light only indicates a PCB failure (Printed Circuit Board).
The only thing you can do at this point is to actually UNPLUG the power cord for 24 hours and then retry or if that fails take it to a service center or better yet go pay the $89 for a new unit.
Hope this helps.
Dec 25, 2007 | Brother HL-2040 Laser Printer
153 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
