Question about Performance Teknique ICBM-892 Car Audio Amplifier
Audio system set up
I have a Performance Teknique 1200 amp, 2 channel, bass alpine 12 inch speakers 300 peak and 100 rms and an i plug stereo, my question is will all this work together? would I need any thing else to make this work properly? Need help!
Turn ur gain allmost all the way down or u will blow ur subs
Posted on Dec 16, 2008
  • 35 Answers
Well one problem is you might need a smaller amp depending on how many speakers you have, 1200 watts is way overpowering for 300watt max speakers and could possibly blow them and even catch them on fire!!!! But everything else is compatable because all of your epuipment is of a newer products but if you dont have 4 guage wires or anything else make sure you get them heres a list: 4 gauge wires for power and ground, REM wire "blue is the normal color" RCA jacks, A compacitor, fuse for battery to amp to keep system from blowing up, 8 gauge speaker wire or even 12 guage to hook up from the amp to the speakers, That should be the common things you need to have a good thumpin system!!!!
Posted on Sep 17, 2008
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
What type of amp do I need for apair of rfdj1 12" dj 600w band speakers?
The 600 watt rating is FAKE like most of our advertising and will be either 600 watts PEAK or 600 watts PROGRAM. If it is Peak, use an amplifier with no more than 100 watts a side RMS... If it is program rating use an amp with no more than 150 watts a side RMS but that is pushing it for speaker safety. Also pay attention to the spec of the amp as to what it will output at the impedance of the speakers. I read the spec on the speakers... they are rated 150 watts RMS, NOT 600 watts... Use an amp rated at 150 watts RMS MAXIMUM at 4 ohms per side. Also don't turn up the bass excessively or you be buying new speakers. Twelve inch speakers would be adequate for a 20 by 20 room at SAFE listening levels. If you want driving bass, you need to get an 18 inch subwoofer.
Jul 14, 2011 | Rockford Fosgate Rfdj1 12" 2-way Passive...
My stereo in 1997 chevy caviler is turning off and on when turned up to a high volume. I have a sony xplod 52 watt by 4 channel radio. With two 6x9 sony xplod 50 watt rms and 300 watt peak power in the...
Most likely cause is heat. The clearances behind the radio are often not sufficient to provde the proper air coolling that the higher power radios need. The heat sinks on the rear of the radio require a certain amount of air flow to dissipate the heat generated under high load conditions. If you add summer heat to the equation, you can have the radio going into thermal cutout to protect it circuity.
May 27, 2011 | 1997 Chevrolet Cavalier
I am wondering about car amplifiers, I don't know what kind to get, I have Alpine 6.5" 2-Way Car Speakers (SPS-600), 80 watt as my front speakers, and Alpine 6 1/2" 2-Way Car Speakers (SPR-17C), 100 watt...
I would strongly recommend that you get a 5 channel amp that puts out 75watts rms per channel that will deliver between 200-300 watts to the sub channel. I use planet audio amps myself and they run strong all day every day-maybe you could look at a planet audio vrx 600.5(5-channel) it throws 100w x4 and 200 or 300 to the subs depending on the resistance of the sub. Good luck
Jan 27, 2010 | Car Audio & Video
I have 2 6x9 speakers up front 4 6 1/2 3-ways
Hello rjmiller4039,
Although amps with 5 channels are pretty rare, you can get one. Alpine, Boston Acoustics, Infinity, JL audio, MTX, and Polk all have 5-channels ranging in price from around $350 up to around $1,000. The Alpine PDX-5 will output 75X4 watts RMS for the front and rear stereo channels and 300 watts to the mono sub channel. It is priced at $599.99 at Crutchfield.
Hope this helps.
Sep 18, 2009 | Jl Audio 500/1 Car Audio Amplifier
I have 2 perfomance teknique 700wts and i dont know what kind of amplifier use
Hello perezmagdiel,
That 700 watts is maximum peak power, not RMS. If you're looking to not spend a lot of money for an amp, but want something that sends enough power to the Performance Teknique's, I'd recommend a 2-channel like the Boss Diablo D400.2. It's plently powerful enough and if you change out later, the amp can be bridged. And for inexpensive, it's got a lot of nice features, including a remote level control. It's 2ohm stable in stereo. Nice, for under $70.
Hope this helps.
Jul 17, 2009 | Performance Teknique ICBM-892 Car Audio...
Installing two amps
No, thats what you don't what to do. Even if you have 2 matching amps you don't do that. Every amp puts out different, and for 2 subs, you want to play at the the same time. If your only running 2 10's, I personal would just run the alpine (it's a mono amp made especially for subs) thats plenty for what you have. make sure you bridge them to get the full response. And your other amp i would use for your highs or mids, but run it @ stereo , which is 300 w @ 4 ohms. (Note: 600w @ 2ohms would be bridged and would play in Mono)
Building Competition stereo's is a big hobby of mine.
May 04, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
Logic alx1280 2 ch amp
Amps can be rated based on their RMS power or their peak power. In this case, the amp's rated RMS power is 300x2 at 2 ohms (total 600W RMS) with a peak power rating of 600x2 (1200W peak). For the most part, peak power means almost nothing.
If your head unit didn't have RCA preamp outputs, you would used the standard speaker outputs from the head unit and connect them to the hi input plug of the amp.
Mar 17, 2008 | Logic Soundlab ALX1280 Car Audio Amplifier
Not enough power delivered
This sounds like a gain setting problem on your amp. The best way to adjust is to set your volume on the head unit to about 75% volume and then adjust the gain up until it sounds distorted a little. Back it off jst enough for the distortion to go away and you are set. Only other thing to try is use a multimeter set on Ohms to test the resistance of your speaker configuration. Looks like 2000 is th peak power (not RMS) and is only possible at high current configurations. You are probably running at 4 Ohms, but this amp only puts out rated power at 1 ohm stereo or 2 ohm bridged. Many people say Performance Technique are overrated, so maybe not even what it is rated at - 350 x 2 @ 2 ohms bridged (probably only about 175 x 2 at 4 ohms bridged)
Feb 06, 2008 | Performance Teknique ICBM-9540 Car Audio...
Speakers
Hi Trim God,
I do not reccommend that you push the Pioneer speakers over 100 watts.  The jenson will already drown the car with bass through your pioneers so much you will want to turn off the bass boost when playing some low bass hip hop songs. It changes from one venue of song to another, so I just keep the jenson bass boost off and use my head unit to adjsut the sound to fit my listening prefences. I am telling you man, you will be blown away .  Hook up the pioneers straight to the Channels,. do not bridge.  I put Subs in my truck though.  I used the Pass output to send the audio to me Jenson 2 Channel 600W amp. I drive one 10 inch enclosed JBL Class A/B Sub. I bridged the output of the 600 W amp to the 10 inch sub  in my Z28.  The pioneers never get drowned out.  I did smoke my 2 channel Amp one time. and also took out a MTD 10inch sub. I am talk shooting flames and smoked the whole car up. I think if you bride the XA4150 to the pioneers, you will have the flaming smoke problem in no time.
Oct 02, 2007 | Jensen XA4150 Car Audio Amplifier
Performance Teknique ICBM-892 Car Audio Amplifier Logo
122 people viewed this question
Top Performance Teknique Car Audio & Video Experts
hoyzee1
Joe Alexander
Joe Alexander
George Nalley
Level 1 Expert
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
