Question about Olivetti Computers & Internet
Power on failure
An old machine but it was free! I am trying to power it up but no go. I have plugged into mains supply. Under the main screen is a small LCD display which shows 4 batteries, each one lights up in succession, left to right. I presume that indicates charging ? When I press the power on button, there is a click and some power on noise and in the LCD display a little 2 pin plug symbol appears briefly but then machine goes off. Any ideas ?
  • sivadar Sep 12, 2008
    Olivetti echos P100D model 800 type 860, forgot that guys !!
    Scholar:
  • 135 Answers
Remove the battery. Plug the AC adapter. Then try to power on.
If it still fails to boot up, it is a no post issue, probably a systemboard failure.
Hope this helps...
Posted on Sep 12, 2008
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
Why does my mac desktop computer screen start to flicker then shut off?
Remove the main battery and try again, the power supply adapter may be breaking down under load, there is no reliable way of testing other than subbing another power supply.
Apr 17, 2012 | Computers & Internet
Power light flashing green. No other light or sound. Per directions I found here, I bought a new power supply board. No change at all. Any other ideas?
Ur tv still having the same result a flashing LED power light indication,after u change the tv power supply board.Mean only one thing the main logic Tuner signal board it is also dead too.The Tuner signal board that the board where the tv incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish main logic Tuner signal board for the replacement.Tries out the old power supply board with the new refurbish main logic Tuner signal board too 50/50 the old power supply could be still functioning.If ur old power supply board still good and functioning,than return ur new bought refurbish power supply to the vendor u bought it from to get some money back.
Sep 14, 2011 | Televison & Video
My whirlpool washing machine power supply not showinhg and when switched on it dost not switch on
Possible that you need to check from the main power switch. Check the power supply outlet, check the power plug to the mains wire to the washer's program controller unit. If there is power till the power supply on the washer then there is failure within the unit and needs a change. Estimate and Confirm
Feb 04, 2011 | Whirlpool Washing Machines
Dell Inspiron flashing amber power light, not charging
I would think the batteries need replacing. That happened to my Dell Latitude CPI. The batteries won't charge past about 3%, so I got new ones and that did the trick. If this is under a year old I would contact Dell about it, if it is under a year old they should replace the batteries.
Hope this helps.
Feb 23, 2009 | Dell Dimension 8400 power supply ** FREE...
Samsung LNS2641D 26-Inch LCD HDTV lost its picture
I'm afraid that while their intention was good, that most the posted solutions miss the mark. Let me guide you thru the diagnosis and possible cure. This is detailed and lengthy, since these points appear often in LCD TV/Monitor repair. You may wish to warm up your soldering iron and skip to Step (11) for the repair procedure.
(1) We know that much of the Main Power Supply is working since many of the audio, video and digital processing sections appear to be working (sound, remote control, tuner, and video out).
(2) We know that the Backlight Inverter is working. Even thought the screen appears to be dark, light from the backlight tubes can clearly be observed. Further, even thought the screen is dark, you *can* observe a small amount of the backlight thru the screen.
(3) When working on LCD TVs and Monitors, the typical problem is backlight failure. (Fortunately this is NOT the case here.) Backlight failure is most often due to Backlight Inverter failure, or Main Power Supply failure. Rarely do the bulbs fail outright (although occasionally thru abuse a CCFL tube is cracked or shattered).
(4) The typical failure mechanism on LCD TV/Monitors that have many in-service hours on them is CCFL tube aging. As the CCFL tubes get older they require increasingly higher voltages to maintain the proper regulated current thru them which in turn creates the correct light output. The higher voltage is often beyond the design limit of the Backlight Inverter leading to component failure. Typically discharge breakdown arcing on the output transformers (that drive the CCFL lamps), or drive transistor failure in the Backlight Inverter power supply. Alternatively, the Main Power Supply may fail. Typically the Main Power Supply supplies +12V, or +15V, or a higher voltage (+24V?) to the Backlight Inverter subsystem. Once again, as the lamps age, more current is drawn, and if the Backlight Inverter doesn't fail outright, it draws excessive current from the Main Power Supply leading to either Main Power Supply failure. Alternatively, the Main Power Supply protects itself by shutting down once the excessive current is detected. This can often be seen as "monitor cycling" where by a LCD Monitor will initially power up, but subsequently cycles every few seconds as the Backlight Inverter draws too much current causing the Main Power Supply to shut down. Then, after a brief recovery period, the cycle repeats.
(5) Another failure mechanism, that should not be overlooked, is Electrolytic Capacitor failure. The Internet has many sites documenting either manufacturing defects in Electrolytic Capacitors used in any of the subsystems (Backlight Inverter, Main Power Supply, Digital Signal Processor, etc.). However, more often than not, Capacitor failure is due to component stress-due to the high ripple currents present in inadequately designed switching power supply subsystems. Additionally, many inferior Electrolytic Capacitors of Chinese origin are inadequately designed-they lack trace chemicals in the Electrolyte necessary to assure long service life.
(6) If you suspect any of the mechanisms described which cause an absence of CCFL backlight, you can often use a small pocket flashlight, and observe the screen image *is* in fact present on the LCD panel, but in the absence of sufficient backlight, you mistakenly believed the LCD panel to be dead.
(7) This is not the case here. We can clearly see that the CCFL backlight *is* lit, but we also do *not* observe any image on the LCD panel, even with an external flashlight.
(8) Thru this diagnosis of exclusion we assume that either the LCD panel itself is defective, or that the LCD panel is not receiving the correct drive signals from the Digital Signal Processor subsystem.
(9) A cursory examination reveals that the Digital Signal Processor board is producing output activity, which-even if malfunctioning-would likely produce some sort of LCD display activity.
(10) The LCD panel is totally dark (backlight is on, but no image at all). This failure is so absolute, it leads one to suspect power related problems as opposed to logic or drive problems.
Nov 16, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
2 year old turned tv on/off several times - TV doesn't turn on
The main power supply is in the protect mode. Usually this is caused by the high voltage section, scan amplifiers, and or the main power supply failing. Many times, when there are failures in the scan amplifier output sections, the main power supply can also be damaged.
On rare occastions, the CRT electron-gun can have a short, and cause this type of failure condition.
An experienced TV tech should be able to service this for you.
Jerry G.
May 25, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Wont turn on
Sounds like a power supply failure... before it stopped working was there a tiny "pop"... or a power outage. If there isn't the red flashing circle of death... the power supply is shot needs to be replaced it is still under warranty.
May 02, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
80 people viewed this question
Top Olivetti Computers & Internet Experts
David Payne
David Payne
Are you an Olivetti Computer and Internet Expert? Answer questions, earn points and help others
