Question about Pioneer VSX-D458 Receiver
Speaker connectors not holding
Receiver works great; speaker connectors for speakers A & B seem to have lost their "spring" and will not hold the speaker wires in place. Can these be replaced by a consumer? Can the new binding posts be used?
  • Wendy Feen May 06, 2006
    I have ordered the replacement parts as that seems to be the best long-term solution. Now I have my fingers crossed that I can replace the part without too much trouble!
    Novelist:
  • 130 Answers
I use to have that problem and what i did was to strip more wire. Then fold the bare wire over a few times and try poking it in there. Maybe you can wrap some foil around the wires also. Must be foil with metal on both sides, not a ciggerette pack. You may also try a pencil eraser. Cut it in the shape of a wedge and try and push it into where the springs are this could work similar to the spring.
Posted on May 06, 2006
    President:
  • 3,130 Answers
I you wanna rip out the old clips and make a mounting plate for the binding post or banna plugs then go for it BUT I would recomend to contact pioneer at the link below first to see what they cost as its always good to keep things with original parts.http://www.pioneerelectronics.com/pna/co... Good Luck
Posted on May 03, 2006
  • Larry  Dillon
    Larry Dillon May 06, 2006
    Thats trick with putting more on the wire is only a tempoary fix and wont last. once the springs start to give then its downhill from there. yopu could even take a soldering iron and jam it inside the connectop and let solder flow in and insert a wire and solder it in but that as well is not a way I would fix someting! If your gonna fix it fix it righ the first time.
  • Larry  Dillon
    Larry Dillon May 07, 2006
    Good Call Wenny!!! and shouldnt be any trouble as long as you dont cut off the wires to short as they assy that unit with the right lenth needed I would go in and cut the wire wraps and restrenths so you can pull the wires out a bit. Good Luck
4 Suggested Answers
SOURCE:
SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Posted on Jun 24, 2008
  • 30 Answers
SOURCE: pioneer receiver vsx d814 amp error
The Pioneer VSX-D814 has a couple of Power Hybrid bricks that do all the power amplification. These are the infamous PAC011A. You should have 2 of those in your receiver.
If the amp detects some unusual activities, it may shut down the unit to prevent damage. “Amp Err” usually means some DC in the output.
Disconnect all the speakers and turn on the unit; if it acts normal, reconnect speakers one set at a time very carefully. If the unit still shows the error message you can try to reset it. If the reset works, again carefully reconnect the speakers connections. If the reset does not recover the normal operation of the unit, you may have one of the PAC011A damaged, and the unit will need repair.
The reset can be done by disconnecting the unit power cord for a few minutes, then plug it in and press “FRONT ENTER key + ADVANCED SURROUND key” continuously for 2sec.
Good luck
Posted on Apr 02, 2009
  • 39 Answers
SOURCE: pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Posted on Sep 13, 2009
Hi, I bought a house with some Niles HD 6 speakers and need to move them down the wall to install a new cabinet. I can't work out how to remove them from the wall to install them lower?
First remove the wire mesh grill with a curved pin or lever it out with a sharp kitchen knife. Then you will notice four black screws very close the groove into which the grill fits.Using a correct size + screwdriver unscrew all the four screw anticlockwise till you feel the whole speaker panel shake loose. Make sure somebody is holding the outer frame while you are doing it or it might suddenly fall. The are red and black spring clip connectors for the speaker wires. Disconnect them foe removing the speakers completely.
Mar 10, 2011 | Niles HD6 Main / Stereo Speaker
Bose acoustimas double cube speaker
what the exact model # of the unit..?
Jun 17, 2008 | Bose Acoustimass 16 Speaker
Speakers are cutting out. Checked connections to receiver and they seem good. Wiggled ports on back of receiver and speakers worked, but cut off again as soon as I let go of them.
You might have bad solder connections where the speaker terminals attach to the circuit board inside the case. Mounting screws inside holding circuit boards in place may also have become loose. Often there are ground connections that depend on these screws being tight.
You may also want to check your speaker wires. The wire may be making a poor connection at the terminal. Try cutting a couple of inches off the end, stripping the wire and reconnecting.
Hope this helps. Thanks for using Fixya!
Mar 05, 2010 | Sony STR-DE685 Receiver
I have a yamaha htr 5890. I would like to hook up
You are probably connected to the pre-out jacks. These are not amplified. Connect them to the B speaker outputs(screw down connectors). If that won't work (and it should), you can connect to the "Presence" speaker connections(spring loaded connections).
Feb 02, 2010 | Yamaha HTR-5890 Receiver
How to remove amp from cabinet? reverb doesn't work.
SOMETIMES the handle screws must be removed as well.
I have taken a lot of these out and the key is to figure out which direction it comes out... MOST are out the back and sometimes a board across the back has to be taken off with four screws to clear a transformer.
FIGHTING getting the thing out when it catches on the Tolex covering is the USUAL problem. Takes patience and sometimes a blade to hold the Tolex back.
USUALLY the speaker baffle stays in place.
Nov 12, 2009 | Peavey Music
No signal to speakers
be sure that your speaker have its own amplifier. no amp will cause a very low audio output.
Aug 17, 2009 | Kenwood VR-307 Receiver
Only one speaker working on my str-de675 receiver
check your main board witch is under the powersupply. careful the caps hold charge and hurt really bad. check your digtal input board also.
Jun 02, 2009 | Sony STR-DE675 Receiver
Speaker wire tabs for neg/pos connections in rear of speaker
The usual spring-loaded speaker terminals can be bought from constructor supply catalogues or salvaged from broken or obsolete equipment.
It should be possible for anyone with a moderate practical aptitude to replace the terminal if the original is beyond repair. It is a largely intuitive process.
Mar 14, 2017 | AAD E-30 Main / Stereo Speaker
Onkyo receiver audio problem
Called Onkyo and here is the solution they gave me.
1. Turn on unit.
2. Press and hold VIDEO 1 button.
3. While pressing VIDEO 1 button, press Speaker A.
4. You should see "CLEAR" on the display for a second and the unit will go on stand-by mode.
5. Turn on the unit again and check if sound is back.
Hope this helps.
Mar 23, 2008 | Onkyo TX-DS575 Receiver
Remote lock on
This worked for me, but I'm sure tired of constantly searching for ways to fix the problems I encounter with my Denon DRA-397. When it works, it's great, but I don't have a degree in electrical engineering. Why can't they produce a user friendly trouble shooting guide?
Dec 14, 2007 | Denon DRA-397
Pioneer VSX-D458 Receiver Logo
380 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
