Question about Dell Inspiron B130 Notebook
Hai my laptop model is dell inspiron8130. iam facing the problem with lcd screen,it is very dim
    Guru:
  • 558 Answers
Have you tried going into the BIOS and setting the LCD brightness setting from there?
To go in Bios
Generally ESC, DEL, or F2 keys works.
If the BIOS setting is at the max then it could be a manufacturer defect.
Regards
Ellin
Posted on Sep 12, 2008
  • Puneet Jain
    Puneet Jain Oct 17, 2008
    Reply please if the soluton work for you.
    Give your rating to the solution either Helful or Fixya.
    If you dont fix the problem yet by the solution given then I would suggest you more options, let me
    know for it.
    Since your voting is precious to me in providing the help for others.
    Have a Nice day.
    Regards,
    Ellin
My screen is very dim
boot to the BIOS (F2 at boot) and ensure that the LCD brightness is set to 8 and then reboot, if LCD is still dim, then, check the Control point system manager display settings and see if the LCD is dimmed there.
If no change, run diags Power + D at boot to run the LCD BIST test , if the 4 colored screens are DIM during the test, then the LCD has failed and needs repplacement.
Jun 29, 2011 | Dell Latitude E6500 Laptop
Dell inspiron 1318 lcd screen completely dim
The backlight in your LCD has gone out. You will need to replace the entire LCD. You can look on ebay or here, you will be paying around $300 for it.
Good Luck!
Jesse
Jan 05, 2010 | Dell Inspiron 1318 Laptop Computer PC...
Dim screen dell precision m70 too dark screen
try this press and hold Fn then tap on arrow up key check if the display will become bright. if fails try connecting an external monitor to your laptop check if display is fine. if not then uninstall video driver then install a latest one. if fails replace the video card drive or motherboard if video is built-in. if display is fine from the external monitor then reseat the LCD cable if fails then replace the LCD panel with the LCD cable.
Oct 24, 2009 | Dell Precision M70 Notebook
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
I have a dell latitude c400 my screen is dim. However I am able to use an external monitor.
If the screen is dim and and external monitor works, then the LCD backlight has failed. Replacement LCDs for that model are around $100 on Ebay and take 30 minutes to an hour to install depending on your skill level
Jun 06, 2009 | Dell Computers & Internet
Black screen when I turn on my computer
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 02, 2009 | Toshiba Satellite A135-S2276 Notebook
Dim Screen when Power is Unpluged
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Mar 27, 2009 | Dell XPS M1330 Notebook
Dell Inspiron B130 Notebook Logo
53 people viewed this question
Alun Cox
