Question about E-Machines T5048 (7136) PC Desktop
EMACHINE T5048 I need to use my function keys but there are not any on the keyboard, how can I access there functions?
  • Dave Thompson
    Dave Thompson May 11, 2010
    Is it missing or just don't have one? The function key is indicated by "Fn".
I have a dvd/rw,in my emachine, the device manager says it's working properly,yet it will not read any disc i put in it, accept a disc cleaner cd and i have cleaned the drive three or four times, when i put in a cd or dvd, the light comes on like it's trying to read it, but it doesn't, please help me, thanks
Posted on Sep 21, 2008
    Sergeant:
  • 320 Answers
One thing for sure that No keyboard comes without functional keys. If that is the case then there are two solutions for this problem. Purchase a new multimedia keyboard and plug-in to your system. otherwise download and install Desktop keyboard and you can use it by using your mouse or arrow keys of the keyboard... Thank you.....
Posted on Sep 12, 2008
My Samsung laptop's (np-r430-jb01ae) function keys are not working. how could i solve it?
Step 1:
Function keys are special keys used for assigning program shortcuts and specialty tasks to the keyboard. They are located at the top of most keyboards and labeled "F1" through "F12." Some keyboards may only feature 10 function keys, while others may have as many as 18. These keys often go unutilized by the average computer user, but they may have very important tasks for some users, which can lead to problems when the keys do not respond. Fixing nonresponsive or malfunctioning function keys is quite simple, and should only take a few minutes.
Connect your keyboard to your computer, and power it up. Open a program that uses the function keys such as Microsoft Word or Microsoft Excel. Check your keyboard for an "F-Lock" or "Function Lock" key. This key is used to toggle function-key support; when it is toggled on, the function keys will not work. Press the "F-Lock" key and then try using a function key in the selected program. "F1" is a good key to test, because it is set to open a "Help" document in all Microsoft software. If the key does not work, press the "F-Lock" key a second time, and test the keys again. If the keys still do not work and you are running the Windows 7 operating system, you may need to install a "hotfix" from Microsoft to fix the key functionality. Navigate to the link entitled "Microsoft Support: Some Function Keys do not Work Correctly." (See Below.) Some function keys or keyboard shortcuts do not work correctly on a computer that is running Windows 7 http://support.microsoft.com/kb/975741 Resolve unexpected Function (F1 - F12) or other special key behavior on a Microsoft keyboard http://support.microsoft.com/kb/894513 Click on "View and request hotfix downloads" located beneath the title of the article to access the Microsoft Hotfix database. Agree to the terms and conditions, then download the hotfix. When the download is finished, run the downloaded file and follow the on-screen instructions. You may need to restart your computer after the installation is complete. Your function keys should now work properly.
Feb 25, 2013 | Computers & Internet
I am trying to reload my operateing system w. disc that came with emachine t 5048,its not recignizing the dics,wiill read any disk but that 1???It came w. computer when i bought it. disk is perfect,no...
At power on, enter the bios (usually by tapping a function key like Tab or Del or F2) and change the boot device order to have the CD drive first. Put the disc in the disc drive. Save and continue. Now, you may get a message asking you to "press any key to boot to the CD". Touch any key, and the reload should start.
See...
http://pcsupport.about.com/od/fixtheproblem/a/biosaccess_pc.htm
Feb 07, 2013 | E-Machines T5048 (7136) PC Desktop
No signal to moniter emachine t5048
DID YOU TRY A DIFFERENT MONITOR TO SEE IF THATS IT OR IT THE COMPUTER. SETTING COUSE THAT PROBLEM TO. THIS MAY HELP.
May 20, 2012 | eMachines T5048 PC Desktop
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
What do all the key functions do ?
Because you have a multimedia keyboard, there are additional functions for those special function keys. The icons on the keys will tell you if they do something special (like play sounds, increase the volume, etc) This kind of keyboard is designed for those who play DVDs and CDs and don't want to have to open a menu on the screen to quickly play music, etc.
Nov 13, 2011 | Belkin Multimedia (f8e820-blk-usb)...
What do the f keys mean
On each keyboard there are additional sets of keys delineated as "Function" Keys. These keys are used for additional programmed functions, such as "F8" or "Function 8" which will allow a Windows user to access a boot menu when Windows first starts up. On a regular 102 key keyboard, such as those on a desktop computer, the function keys are located at the top of the keyboard with the letter "F" preceding the number of the key. On a laptop, generally the function keys are accessed by holding down a blue "Fn" down at the bottom of the keyboard and the specific number on the numeric portion of the keyboard. So in the above example of "F8" the combination of holding down "Fn + 8" would accomplish the same action.
I hope this help and if you require additional assistance, please do not hesitate to ask.
May 21, 2011 | Computers & Internet
I have a emachine 4010. Monitor display sideways
hold alt+ctrl then click the up arrow while holding alt+ ctrl
May 08, 2009 | E-Machines T5048 (7136) PC Desktop
Enabling my Emachine keyboard functions
Sounds the The F lock is on when your computers starts up, You should see a number or F lock on top or your key board just press that button to disable and let you f keys work again, It must be on in your bios if some one there is computer savoy enough to go into your bios and change the setting so when you boot up next time that won't happen anymore, Ok if thats don't work just write back here and we will try another easy task, Let me Know. We try to keep it a simple as possible, Ok Thanks so much and Happy New Year
Dec 25, 2007 | E-Machines eMachines Desktop PC
E-Machines T5048 (7136) PC Desktop Logo
353 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
