Cd is not running the program - Computers & Internet
    Sergeant:
  • 320 Answers
If cd is running properly then there are no issues. If program is not running which is present in cd then that cd may have corrupted. or Please login to administrator account and run the program. Hopefully it should work.. Thank you...
Posted on Sep 12, 2008
Can't install program
If it starts to install and then crashes try running the install program in Compatibility mode with a previous version of Windows. Most of the time when I run into this it is a compatibility issue. If your CD drive is not reading teh disk then the problem is the CD drive or CD itself.
Dec 03, 2011 | Vivendi Mastercook Cooking Light 4.0 Full...
I'm trying to install CD Label Maker (Data Becker)and can't install to windows 7 (64 bit). Is there an upgrade availabe? Installation CD is for Windows 95/98
Often old programs will install if you go to the CD and make install.exe or start.exe "run as administrator".
Some times you also then have to run the program, after it is installed, in compatibility mode. Again, right click on the program icon, select the compatibility tab, select an old OS like XP or what ever the program used to run in.
Aug 22, 2010 | Computers & Internet
CPU running at 100%. Computer very slow.
run task manger and try to end some of the programs that is run by you do not end the program that is given user name like this"system" and svst host try to end programs that take more than 10.000kb
Apr 25, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
WIN PRO 2000 RECOVERY DISK
BEFORE YOU DOWNLOAD THE PROGRAM ONTO THE CD-ROM DID YOU FORMAT IT TO MAKE IT BOOTABLE, IF NOT THAN IT WILL NOT WORK, YOU COPIED THE PROGRAM, THE COMPUTER SEES THE PROGRAM, BUT IT CANNOT DO ANYTHING UNLESS THE COMMAND ARE THERE TO TELL IT WHAT TO DO.
YOU CAN TRY ACCESSING THE PROGRAM FROM THE CD-ROM, WHILE YOU ARE IN THE PROGRAM FROM THE CD YOU CAN TRY AND TYPE SETUP, RUN,
Jan 20, 2009 | IBM (08K3261) for ThinkPad A20P, A20M,...
Need program to run educational software
You certainly meet the system requirements needed to run that software. I do not know much about Scott Foresman, but you are currently running at very least a 2.0 GHz machine, equivalent of 2000Mhz, more than enough speed needed to run that program.
In terms of installing the program, it seems you have the choice to either install whatever version is available on the disc, or the latest up-to-date version available online.
Jan 14, 2009 | Dell (UJDCD450) External 4x CD-ROM Drive
CD is still blank after running the burn program
Go into your burner settings and uncheck the box that says erase or format disk before use.I had the same problem in Vista and that is what I had to do to fix it.
Jan 07, 2009 | Gateway (5502216) CD-RW/DVD-ROM (Combo)...
CD/DVD drive will not recognize the CD
Try other CD's that you have and see if it read those or automatically run. If you tried other CDs and they can be read then it maybe you may have to inspect your Printmaster CD for scratches or clean it off if dirty. If your CD Rom doesnt read Any CD at all then maybe it may need a little cleaning inside or that you may need to replace it.
Jan 02, 2009 | Broderbund PrintMaster® Platinum 17 Full...
CD drive door won't open.
there is a very small hole near the push button of your drive, put a pin into it and press it along with the push button
Nov 08, 2008 | HP Pavilion Slimline S3123W Desktop PC -...
The setup wizard on the CD will not automatically run when inserted in the CD-ROM drive, what do i do?
  1. click on start
  2. My computer
  3. right click on CD/DVD Drive
  4. Left click auto run
selecting My Computer, right-clicking the drive that contained the CD-ROM, and selecting Properties. click the AutoPlay tab and select the Select an action to perform option, then double-click the program to use to run the CD-ROM. This action launched the program on the CD-ROM. Note that simply highlighting the program you want to use and clicking OK or Apply doesn't work; you must double-click the program and force it to launch on the CD-ROM or DVD in the drive. The CD-ROM then ran automatically, using the program associated with it on the AutoPlay tab.
Apr 15, 2008 | Computers & Internet
How to get a CD-ROM program to run?
You're probably going to have to set up an ActiveSync connection between your PC and your 2415, then run the program installer on your PC while you're connected to the iPaq.
Sep 11, 2005 | HP iPAQ HX2415 Pocket PC
Computers & Internet Logo
David Payne
David Payne
