Question about Sharp LL T17A4-B 17" Flat Panel LCD Monitor
Sharp LL T17A4-B (Black) 17 in.
When I power on my sharp monitor it has power going to it, but as soon as the I start to boot up the pc, nothing is displayed on the monitor (its just a black screen). I have tried the pc with another monitor and all is well (i can see it going through its boot up criteria). I have even tried to replace the graphics card. Any ideas ? Thanks Andy
  • Sten Nov 07, 2007
    When we start the computer and the monitor, there is a quick flash of the screen image, then it goes black. So far, we have managed to get it back to normal by shutting off the computer and the monitor in various orders. This does not always work though. (Tonight I was about to give up when I saw that the "no signal input" message was showing continuously. When I turned on the computer, the screen then worked fine.
    The monitor is connected by a cable. The connections seem solid. The green light (or yellow when the computer is off) does shine. We turn off both the computer and the screen each night.
    The monitor worked great until last night. I can't find a year on it but we have probably had it 2-3 years or so.
  • 513 Answers
Are you using the digital connection?? If so try using both the analog and digital connection then set the digital as the Main monitor in your graphics card interface. To check if the backlight is out, darken the room, and light a flash light into the screen. If you can see a picture, then you need to replace the backlight. Good luck
Posted on May 04, 2006
SOURCE:
The stand, attached at the back of the screen, has snapped and needs replacing. Can it be replaced and where can I get one. the screen is fine.
Try contacting Sharp. Places that sell them may have one laying around but I doubt it.
If you can't get one, check the middle of back of the monitor for 4 screw holes (empty) in the shape of a square, they're for attaching to a wall or desk mount.
An example of a desk mount:
http://www.google.co.uk/products/catalog?q=monitor+mount&cid=392981540399473061&ei=3uNbTciZNJe5-QaMn62VCQ&sa=title&ved=0CDQQ8wIwCTgA#p
Feb 16, 2011 | Sharp LL T17A4-B 17" Flat Panel LCD...
Sometimes the screen goes blank and today when I restarted the computer the screen is flickering very lightly.Does this means its going?
The picture board on your monitor is bad, since the power led or button is on and all connection are corrrect, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care
Jun 30, 2010 | Sharp LL T17A4-B 17" Flat Panel LCD...
I need to find drivers for a Sharp LL T17A4-B 17 in. Flat Panel LCD Monitor. I recently changed it to a different tower and cannot find the driver for it.
Hi
Thanks for using FixYa. You can download its drivers by clicking on any of these two links:
Sharp LL T17A4-B Drivers
Sharp LL T17A4-B Drivers-2
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 08, 2010 | Sharp LL T17A4-B 17" Flat Panel LCD...
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
LL-T17A4-B incompatibility with OS
go to the add a--- section under the control panel and right click on the monitor/s
click on the properties tab and then click on the compatibility tab
tick the box and click on the os you want for that computer
click apply and ok
in that properties you will also find a drivers tab , click on that and then the driver update line
it will search and download the latest drivers or come back with a message that the driver in use is the most appropriate one
Mar 27, 2017 | Sharp LL T17A4-B 17" Flat Panel LCD...
Lcd monitor will not stay on
First thing to try, is to check the cable from Monitor To PC Or Graphics Card.
If you have a loose-broken internal wire, this will be the problem. Dry-Solder Joint et,c.
If the cable, has a socket either end, from monitor to computer.
try to obtain a replacement cable. The second option is to test the output source. i.e Graphics card or output to the monitor.
Hope this helps Mike @ Compurepair.
Sep 16, 2008 | Sharp LL173C 17" Flat Panel LCD Monitor
Sharp ll-t17a4-b backlight
when ever i try to sign in the messanger says erorr code 80072efd how can i solve this matter
thanks
jem
Oct 21, 2007 | Sharp LL T17A4-B 17" Flat Panel LCD...
Problem with the monitor
Have you tried another monitor on the PC? If the cable and connector pins are okay, I would suspect a problemn with the video / signal board inside the monitor.
Jan 21, 2007 | Sharp LL T17A4-B 17" Flat Panel LCD...
Sharp LL T17A4-B 17" Flat Panel LCD Monitor Logo
715 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Siul Oyaratgam
Joe Negus
Joe Negus
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
