Question about RCA 27F500TDV 27 in. TV/VCR/DVD Combo
TV turns on and plays normally and then just shuts off
The TV and/or the DVD mode will play for 5-30 minutes then suddenly shut off. It varies. Once it does this any repeated attempts to turn it back on has it sutting off within seconds. If I wait a few minutes before turning back on, it will play again longer before shutting off, although not as long as the first time it was turned on and shut off on its own. It will play a VCR from start to finish without this occurring.
I have had this TV for 4 1/2 years primarily in a secondary room. I have never had any trouble until now. It does not get constant or even frequent play time in the entire time of ownership.
  • 4 more comments
  • shannnnnnn Sep 13, 2008
    RCA 27F500 TDW 27" TV/DVD/VCR COMBO
    The TV and/or the DVD mode will play for 15-20 minutes then suddenly shut off. It varies as to time. Once it does this, any repeated attempts to turn it right back on has it sutting off within seconds.
    If I wait a few minutes before turning it back on, it will play again longer before shutting off, although, not as long as the first time it was turned on and shut off on its own.
    This happens in either the TV or DVD mode.
    It will play a VCR from start to finish without this problem occurring.
    I have had this TV for 4 1/2 years primarily in a secondary room. I have never had any trouble until now. The unit was regularly used, although it definitely did not get constant or frequent use.
  • shannnnnnn Sep 14, 2008
    Thank you. I thought of that and attempted to reset the timer using the remote. Obviously I did not do it correctly... :) I took the batteries out of the remote to see if it would reset and even programed another remote to the tv to see if it changed things. Nothing I did worked. How would I go about it another way?
    I read on the internet on a trouble shooting web site that it could be a controller problem. The controller thinks it is supossed to turn off when it shouldn't. Is that something that sounds true? Is it easy to fix or replace?
    Any thoughts?
    Is this something I could do myself or should I find a local repair person do do that? I am pretty handy if I had a diagram I could probaly do it.
    I live in Las Vegas and there are no reputable repair shops that I know of.
  • shannnnnnn Sep 15, 2008
    There is no reset button on this unit.
    I attempted the remedy suggested. The set obviously re-set after the manuver because all of the saved settings for the unit were now gone(everything was zeroed out).
    The TV still shuts off in about 10-14 minutes in Tv or DVD mode.
    This makes no sense to me.
  • shannnnnnn Sep 16, 2008
    It turns out that I bought this unit at Costco back in Dec of 2003. The sales person said I should just return it. So I returned it for the full amount I paid for it back then and got a brand new 32" Samsung flat screen High def LTD for about the same amount of $$ that I would have spent to repair the RCA combo set I have been asking about....
    Thanks anyway!
  • 185 Answers
Hai,
you have the problem in  you ICs and capacitors(3 legs),As you are using the the TV for la long time the ICs are loosed,so u have to send your TV to nearby service engineer or sauldrin by ur own.
Thank You
Posted on Sep 15, 2008
  • 118 Answers
Possible Causes:
  1. Timer problem, hense it turning off after a certian amount of time
  2. Defective Copmponent (Capacitator or Timer)
Try:
  1. Resetting the TV hopefully will reset the timer
  2. Change the timer settings, mabe you accidently set it up to shut down around that time
  3. Bunnydawgs Idea (he other method is to buy a can of compressed air and run the dvd.... use the compressed air to cool different components most likely in the power supply section of the dvd ... when it comes back on you have found the defective component.)
  4. Get out the manual and check how to reset the time
The problem is that you have tried these. I reccomend changing the timer settings instead of resetting, in the hope that it works :D Good luck
    President:
  • 1,952 Answers
The reason that resistor failed, is because it was designed undersized. Duh, like a 1/2w resistor costs more than a 1/3w resistor. The real culprit is a picture tube arch, but not to worry, as the set gets more playing time, these minor archs will decrease and the 1/2w resistor will usually handle the surge.
Connecting several appliances to the same rc plug might provide efficiency; depends on the combined standby power usage of the devices compared to the plug.
I get it. The device covers the on/off switch of the tv. When activated, it physically presses the switch and *truly* switches the tv off, as opposed to putting it in standby. Nice. If it's true about saving up to £43 a year, then I'd buy one. Bun to you. 6
    Brigadier General:
  • 5,158 Answers
A bad capactor will do that... dissasemble and inspect for rounded tops on them.. when you replace them be sure to get the proper value and be sure to orient them as per the stripe on the side of the can. the other method is to buy a can of compressed air and run the dvd.... use the compressed air to cool different components most likely in the power supply section of the dvd ... when it comes back on you have found the defective component.
Robert
Posted on Sep 13, 2008
    Genius:
  • 1,239 Answers
Hi  there is a timer problem.. where u need to reset it..or change it thank u.. if anya assist post it..
    Sergeant:
    Champion:
  • 214 Answers
Plaese give the model no. and name
Posted on Sep 12, 2008
  • 2,071 Answers
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Acer shuts down
i was told to put a fan at the back so i got a usb fan it hasnt switched of since been running all day playing games etc i hope this works for you (got fan from amazon )
Aug 16, 2012 | Acer Aspire Z5700 PC Desktop
My LC320SS8 tv/dvd combo shuts set off while playing DVD
your dvd mech assy will need to be replaced , but could be just a missed aligned deck I would have a tech give you and estimate
Jan 03, 2010 | Sylvania LC320SS8 32 in. LCD Television
My lg dvd player model no. DS 9581 shuts off and on
check if u have set or automaticall timer
Oct 23, 2009 | Televison & Video
Receiver shuts off when trying to play a dvd in the dvd player.
Just a hunch - what's drawing power from the two convenience outlets on the back of the receiver. They're only rated for 120watts, that is, nothing like a TV.
I doubt this has anything to do with the source you're playing (unless you have it cranked to "11"). If I understand you correctly you said turning the TV on and off causes the problem. There's a clue.
Apr 07, 2009 | Denon AVR-1803 Receiver
The dvr is not interacting with my tv
:: Remote Control Overview
1 POWER Press to power the DVD+VCR on or off.
2 TRK+/- While a tape is playing, press to manually adjust tracking
(i.e., to remove white lines from the screen).
3 0-9 Use to select channels and set menu items.
4 SKIP/F.ADV Press to skip ahead in one-minute increments, up to 5
minutes, during VCR playback. Press to advance one frame at a time in
Pause mode.
5 SHUTTLE <</>> Press the 4 and 6 buttons to scan forward and
backward at variable speeds.
6 MODE/REPEAT Press to set the Play Mode to Random or Programmed
Play. Also press to set the Repeat Mode to Title, Chapter/
Track, or A/B Repeat (DVD only).
7 ZOOM Press to zoom in at 2 or 4 times normal magnification (DVD
only).
8 100+/3D SOUND Press to select cable channels 100 and above.
Also press to activate the 3D Sound feature, which creates the illusion of
surround sound with only two speakers (DVD only).
9 DVD Press to set the remote control to operate the DVD deck.
10 MUTE Press to turn audio on or off.
11 VOL +/- Press to adjust the volume.
12 STOP J Press to stop playback.
13 REW AA In DVD mode, press to skip to the previous track. In VCR
mode, press to rewind the tape. Press and hold to scan backward during
playback.
14 REC F Press once to start recording in the VCR deck. Press repeatedly
to add recording time in 30-minute increments.
15 ARROW KEYS Y/B/A/" Press to navigate in the menu system, see
page 15.
16 SETUP/ENTER Press to display the DVD+VCR menu system and
confirm menu settings.
17 SP/SLP/TITLE Press to set the VCR record speed to SP (Standard
Play) or SLP (Super Long Play). SLP is three times longer than SP. Also
press to display DVD title menus (for discs with multiple titles only)
May 29, 2008 | GoVideo DVR4300 DVD Player/VCR
Cannot remove progressive scan mode
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
Mar 29, 2008 | Sanyo DVW-7100A DVD Player/VCR
Plays for a minute or two - then just shuts itself off
Mine will intermittently record only the first minute or two of a tv show I have queued up to regularly record. It seems to happen anywhere from every show to every 5-10.
Mar 04, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
System switches itself off
The HT-DB120 has an automatic shut down that should turn off after 20 min of idle mode, it seems yours is malfunctioning. try disconecting the DVD from power for a few minutes.
Jan 07, 2006 | Samsung HT-DB120 System
RCA 27F500TDV 27 in. TV/VCR/DVD Combo Logo
566 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
