Question about Cell Phones
GSM nokia 1600 Dead while flash. I am using JAF Before flash IEMI is ??????????. Any one please help how to rectify and rewrite the same IEMI......................
  • 55 Answers
Hi sir, all you have to do is open the IMEItool tool bar on the JAF menu, then type the 14 digits imei of your phone then select imei save, after that select the IMEI patch, then type again the imei number but not to include the last digit, then select ok,,, then you have to choose a patch file that is compatible to your flash file version...... then its all okay...
goodluck............ pls rate.... and post the result
sexy-ym
Posted on Sep 12, 2008
Nokia 1600 not charging
Posted on Apr 15, 2009
I have forogotten the security keyguard of nokia 6300, how can i reset the defaultcode?
USE J.A.F TOOLS AND REFLASH YOUR DEVICE
1)DOWNLOAD SETUP FROM HERE www.mediafire.com/?8tii1p2dw38en39
2)DOWNLOAD LATEST FIRMWARE OF YOUR MOBILE
UNPACK NOKIA FLASH TOLLS AND INSTAL JAF
COPY NOK4MODEL.INI TO C/PROGRAM FILE/ODEON/JAF
DELETE ALL JAF ICONS ON DESKTOP
COPY AND PASTE OGM PKEY ENUMULATOR TO DESKTOP
INSTALL FIRMWARE
INSTALL LATEST NOKIA PC SUIT
1)RUN OGM PKEY AND GOT TO STEP 2 AND CLICK ON LAUNCH JAF AND GOT TO BB5
2)UNTICK ALL THE DEFAULT TICKS
3)TICK ON DEAD USB,MANNUAL FLASH AND FACTORY RESET
4)TICK USE INI.JAF WILL HANG FOR A WHILE.A DAILOG BOX WILL OPEN
AND THEN SELECT YOUR MODEL
NOW YOU WILL SEE THREE GREEN LIGHTS ON MCU,PPM,CNT,THIS MEANS ALL IS OK
NOW CLICK ON FLASH,AN ERROR WILL SHOW UP CLICK YES
NOW CONNECT YOUR SWICHED OFF HANDSET WITH PC BY USB CABLE AND SHORTLY PRESS POWER ON
JAF WILL DETECT YOUR PHONE AND WILL FLASH YOUR HANDSET ALSO IT WILL RESET THR USER SETTINGS LIKE SECURITY CODE ETC
NOTE:- ALWAYS USE LATEST FIRMWARE.DOWNGRADING WILL KILL YOUR PHONE.DO AT YOUR OWN RISK
May 02, 2012 | Nokia 6300 Cellular Phone
Nokia 5230 suddenly gets switched off... its not getting switch on..how to resolve tat problem
First of all please check if the battery is in good condition.
If the battery is fine and the phone is still not switching on, then the firmware of the phone should be corrupted. You will have to flash the phone to a latest firmware. Its best to get your phone flashed from a service centre. However, you can flash the phone yourself. Step by steps instructions are given below:
1. Download navifirm from here.
2. Select your phone model and download the latest firmware available.
3. Download JAF from here.
4. Flash your phone with JAF using dead usb option. (How to flash with JAF)
Your phone should work fine.
Don't forget to rate me.
Hope it helps. Thanks for using FixYa.
Jan 19, 2011 | Nokia 5230 Cell Phone
I want to reinstall flash for my nokia 5220 mobile can u tell how to proceed this
Hope it helps. Please rate the answer. Thanks for using FixYa.
Jan 11, 2011 | Nokia Cell Phones
6300 dead no pawar
Jan 09, 2011 | Nokia 6300 Cellular Phone
Am not able to switch on my nokia x3 mobile
Jan 09, 2011 | Cell Phones
1202 nokia dead from water falling whaen i flash
hi,
clean your unit first using lacquer thinner,then blow it slightly by hot air...after doing that clean the pin out because if it water damage it must be corroded...what version of jaf you are using?if your version are not updated ,1202 is a sl3 (simlock 3) unit and not supported by lower version of jaf...much better if you use mx key dongle and ufs box as your interface (do not use jaf as your interface because it would be damage) or cyclone....and here is the procedure..
using easy cable ,connect the phone ,open mx key module ,select ufs interface ,dct4 then bus check...if the info of unit is showed ,put CNT ,MCU,PPM ..before flashing back up your phones rpl first ...then flash the phone...after flashing ,there is a possibility that the phones status is contact service ,dont worry just go to service ,imei and security then direct unlock...but be sure that your mx key is activated by dct4 plus unlocker...
in case the phone is not responding after cleaning ,reheat flash ic then repeat the procedure...i hope it will help you ,thanks for trusting fixya..
goodluck..
Jun 16, 2010 | Cell Phones
I hav forgoten my security code of nokia 1600 and my iemi num is 359354006111080 plz plz answer me
http://www.unlock-free.com/nokia-master/
Takes care of most nokia phones. It's a free solution.Please follow site instructions.
Please rate the solution.
Cheers
Jan 09, 2010 | Nokia 1600 Cellular Phone
NOKIA 1600 no network found
First write PM(Permanent Memory) with any tool like Phoenix, UFS or Jaf. If not work then you need to change the PA (Power Amplifier)
May 17, 2008 | Nokia 1600 Cellular Phone
Huh??!!
JAF is the ONLY third party flasher which supports USB flashing. USB flashing is very good and usefull because in case a new phone come out, the user can IMMEDIATELY FLASH THE PHONE, he doesn't need to wait for new F-Bus cable release and to pay expensive delivery costs. The CA-53 cable is included in nearly EVERY BB5 Nokia package.
  • revive dead phones using simple USB cable CA-53 (no need to buy F-Bus cable and to pay expensive delivery costs)
  • BB5 models flashing supported using simple USB cable CA-53
  • the only flasher that can correctly flash Nokia N80 by USB
  • the only flasher that can repair N91 white screen problem
Note that the JAF box does not unlock BB5 phones . It can flash them only!
The JAF box is regarded to be the fastest Nokia Flasher on the market!
No extra power source needed, is powered via USB.
$200.00
Apr 02, 2008 | Nokia 6300 Cellular Phone
NOKIA 1600 IMEI ???????????????
yes sir' JAF can solve that prob.
by using RPL logs...
Jan 09, 2008 | Nokia 1600 Cellular Phone
Cell Phones Logo
313 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
