Pentax Optio S50 Digital Camera
Problem for Pentax Optio S50 Digital Camera
LCD Display Blank
By Zarir on May 03, 2006
When the camera is turned on, the LCD diaplay screen is blank (dark) and just displays various information icons for batterly level, megapixels, quality, flash-on, etc. When I try to take pictures, the same is not possible as LCD screen does not display anything. However, it does click and take pictures - which are nothing but black squares.
However, the LCD screen works fine when used in preview mode for the pictures taken before the problem started.
Thanks for your response.
Zarir Shroff
Same Problem
Apr 13, 2009
-   lcd of my laptop is not fuctioning properly becuase water has entered into the screen.
-   Guest
Dec 24, 2008
-   My Olympus FE340 turns on, functions properly and is able to flash when I take a picture. My battery is fine, the settings are all correct. However, when I turn the camera on, the screen is blank with all the settings showing on the screen; just no picture. When I click to take a picture, the screen is still blank.I can go to the playback menu to look and delete pictures that I previously took before the screen became blank. -   HWilkins
May 03, 2008
-   lcd screen is blank, trying to take a picture. menu is displayed-   Guest
Apr 09, 2008
-   Hi,
When the camera is turned on, the LCD diaplay screen is blank (dark) and just displays various information icons for batterly level, megapixels, quality, flash-on, etc. When I try to take pictures, I get nothing but black squares.
However, the LCD screen works fine when used in preview mode for the pictures taken before the problem started.-   Guest
Jan 02, 2008
-   I bought an SD750 two months back and I am experiencing similar problems. It all started with camera showing lens error later when I powered off and on LCD shows dark screen. i can preview the taken picture. To me it looks like some problem with the CCD or the lens part. LCD and teh memory card is intact as I can see the picture present there and also delete the pictures.-   joby aliyath
Best Solution
posted on Nov 05, 2007
Very Helpful)
excrescent
Rank: Apprentice
Rating: 100%, 1 votes
Canon's web site says:
Service Notice: CCD Image Sensor Advisory (Updated 10/31/2006)
This Service Notice will update Canon U.S.A., Inc.'s previous CCD Image Sensor Advisory, dated October 6, 2005.
It has come to our attention that the vendor-supplied CCD image sensor used in certain Canon digital cameras and digital video camcorders may cause the following malfunction: When the product is used in recording or playback mode, the LCD screen and/or electronic viewfinder may exhibit either a distorted image or no image at all. While reports of this malfunction have been rare in the United States, we have determined that it may occur if the product is exposed to hot and humid environments.
Notice of Additional Affected Products:
As a result of our continuing investigation of this malfunction, we have determined that the 11 models listed below, in addition to the 16 models listed in our Service Notice concerning this malfunction, dated October 6, 2005, may be affected.
Affected products:
- Camcorders: ZR60, ZR65 MC, ZR70 MC, ZR80, ZR85, ZR90, ELURA 40 MC, ELURA 50
- Digital Cameras A60, A70, A75, A300, A310, S230, SD100, SD110, A40(*), A80(*), A85(*), A95(*), S1 IS(*), S60(*), S200(*), S330(*), S400(*), S410(*), S500(*)
*Models added as of Oct.31, 2006
Malfunction:
It has been confirmed that the connecting parts of the internal wiring of the CCD used in affected products may become disconnected, especially if the affected products are stored or used in high-temperature and high-humidity environments. If this occurs, the signal is not output from the CCD normally in Shooting Mode, which may cause a distorted image or the absence of an image. This malfunction can be confirmed on the LCD monitor screen during shooting. The same malfunction also appears on the recorded image.
Canon's Response:
Effective immediately, and regardless of warranty status, Canon will repair, free of charge, the products listed above exhibiting the above-mentioned malfunction if Canon determines that the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
U.S. residents are kindly directed to contact the Canon Customer Support Center for further assistance at 1-800-828-4040. Support hours are Monday thru Friday - 8:00 AM to 12:00 midnight; and Saturday 10:00 AM to 8:00 PM (all times EST). Alternatively, if electronic support is preferred, please send your email to carecenter@cits.canon.com
This information is for residents of the United States of America and Puerto Rico only. If you do not reside in the USA or Puerto Rico, please contact the Canon Customer Support Center in your region.
We sincerely apologize for any inconvenience caused by this issue, and appreciate your understanding in this matter. Thank you for your support and patronage of Canon products.
Was this helpful?
Yes
No
Solution #2
posted on Aug 04, 2006
Very Helpful)
Ellil
Rank: Apprentice
Rating: 87%, 3 votes
ellil indicated that his solution for
Cyber-Shot DSC-F717... Problem
is valid for all Pentax Digital...
Found solution - fault with CCD chip!
Contact Sony call centre for free repair - 08705 143 480
Have a look at:-http://www.livingroom.org.au/photolog/news/sony_canon_and_nikon_advise_users_of_digital_camera_problems.php
Was this helpful?
Yes
No
Solution #3
posted on May 31, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
its the shutter. its stuck. look through the lens. try turning you cam on and off and observe the lens. i guess its bound to go to the service center.
Solution #4
posted on May 06, 2006
Somewhat Helpful)
BowerR64
Rank: Wiz
Rating: 80%, 975 votes
When the camera is in the record mode can you see the lens in the front? There is a little shutter looking thing that opens and closes to protect the lens but can sometimes bind up and not open. If it is opening make sure its set to "AUTO" mode. If its set to somthing else it may not be set to let in enough light and your images are being take so under exsposed they look black. Hold the camera to the bright light VERY close and see if anything changes. There may be a CCD problem with this camera but try those things first to trouble shoot the problem. A blank LCD could be a few different things so before you decide try these things. LCD could be switch off also, some cameras have buttons that get bumped easy and settings could be changed by accedent
Was this helpful?
Yes
No
Solution #5
posted on May 04, 2006
Somewhat Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3608 votes
Try reseating the mem card, and look for any bent pins in there.
It's a long shot, but who knows? ;]
Was this helpful?
Yes
No
Solution #6
posted on Nov 23, 2009
Not Rated)
bunts01
Rank: Apprentice
Rating: 0%, 0 votes
I reformatted the memory card and the problem was solved
Was this helpful?
Yes
No
Solution #7
posted on Mar 11, 2008
Not Rated)
stevie15
Rank: Apprentice
Rating: 0%, 0 votes
I tried this and it worked
Thanks....
Was this helpful?
Yes
No
Solution #8
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks....
Solution #9
posted on Jul 01, 2006
Not Rated)
Penman
Rank: Apprentice
Rating: 0%, 0 votes
Sorry not a solution for this but I have the same camera with with same problem. When trying to take a photo the shutter is open but the LCD just shows black, anypicture you take is black but the LCD will show the menu options and previous photos I have taken. I did try sending the camera to Fuji for a quote to repair it but they wanted £99 so I asked for the camera back.
Was this helpful?
Yes
No
Solution #10
Not Rated)
mattltate
Rank: Apprentice
Rating: 0%, 0 votes
Did anybody find a new solution for this? I have the same problem on my FX9 camera that is only a couple weeks old.
I purchased my camera approxamately one month ago to bring with me on a trip too Europe. I tested it and it worked fine, however now when I turn it on all I get is a black screen? All functions and menus seem too work fine and it even acts like it takes a picture but it also comes out black on the screen. I have pulled the battery out for over 10 minutes to try and discharge anything in the camera and this did not work additionally, I have changed memory sticks. Also this did not have any effect. I can view pictures that I have previously taken, I just can't seem too take any more.
Was this helpful?
Yes
No
Popular Solutions for Pentax Optio S50 Digital
Questions and Unsolved Problems for Pentax Optio S50 Digital
Do you recommend Pentax Optio S50 Digital Camera?
Answer
Answer
My camrea, won't turn on. I brought it to school, and my friend asked if she could take picture, but... (More)
Answer
the focus on the Optio s50 does not work. THe flash does not activate either
Answer
power source problem camera turns on the shuts down immediately
Answer
I thought the camera was broke. Went looking on this site this morning. I first pressed the reset... (More)
Answer
When I try to format the Memory card it gives the foll message: card did not format. What could be... (More)
8 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 08, 2007
My screen is blank. I can take a picture but of course it is blank. The camera will let me delete.
Comment by doyd, posted on Nov 20, 2007
the lens for my isonic snapbox DD77 does not open when it is on
Comment by excrescent, posted on Nov 05, 2007
Same symptoms but intermittent: LCD is blank but for icons and viewing of pictures already taken. A note: it's not the LCD because old pictures are viewable. It's not the shutter: it opens well and it's not a manually set small aperture. I did turn it on once and it worked for awhile.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pentax Optio S50 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 761
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
