Question about HP PSC 1610 All-In-One InkJet Printer
Print head after paper jam print head would not come in contact with paper
    Novelist:
    Scholar:
  • 111 Answers
The most likely cause is that when you cleared the paper jam, you did something to physically misalign the print carriage. The closest thing HP has on its web site that addresses this issue is the following:
Carriage Stall Solution
See if some of the steps on this page helps. Good luck.
Posted on Oct 07, 2008
Machine code 5a
a 5a error code means that The machine does not work due to a paper jam or some sensor problem. here is a list of error codes for the dcp-j125 printer.
Error Code Cause Solution 30,31,32,33,34,35,36
37,38,39,3C,3F The machine does not work due to a paper jam. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) 40,42,43,44 The internal temperature is too high. Unplug the machine from the AC outlet and if possible cool the room where the machine is located. 46 The ink absorber pad is full and needs replacing. Please contact Brother Customer Service from "Contact Us". 48 There is a problem on the print head, Please contact Brother Customer Service from "Contact Us". 49 The internal temperature is too low. Unplug the machine from the AC outlet and if possible warm the room where the machine is located. 4F There is a problem on the print head. Please contact Brother Customer Service from "Contact Us". 50,51,52,57,5A,5B,5C
5D,5E The machine does not work due to a paper jam or some sensor problem. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us". 8F There is a problem on the paper feed motor. Please contact Brother Customer Service from "Contact Us". A5,A6,A7,A8,AF There is a problem on the scanner. Please contact Brother Customer Service from "Contact Us". E2,E3 There is a problem on the main PCB. Please contact Brother Customer Service from "Contact Us".
Jan 07, 2014 | Office Equipment & Supplies
Had paper jammed - removed jammed paper - but nerror light still on
Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
Paper is jammed inside the paper tray:
  1. Pull the paper tray out of the machine.
  1. Pull out the jammed paper to remove it.
  1. Reload the paper in the paper tray.
  2. Reinstall the paper tray.
Paper is jammed inside the machine:
  1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
  1. Re-insert the jam clear cover.
  2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
  3. Remove the jammed paper.
  4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
  5. Gently move the print head to the center.
    Note Be careful to not force the print head to move.
    If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
  6. Examine under the print head. If anything is found, remove it.
    Note Use a flashlight if necessary to check thoroughly.
  7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
  8. Reconnect the power cord and telephone line.
Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
Thanks for using fixya......
Oct 26, 2010 | Brother Office Equipment & Supplies
My MP510 was just printing fine then went to rear feed and now all I get is a flashing green and yellow lights
review this to determine your problem.. If all else fails simply unplug your printer wait a minute and plug back in.
Handling Error Messages
When a printer error occurs, the POWER/ERROR lamp flashes.
The number of flashes indicates the type of error that has occurred.
Count the flashes and take the appropriate
action to correct the error.
Number of Flashes
Possible Cause
Try This
Two flashes Printer is out of
paper/Paper does
not feed
Reload paper in the Sheet Feeder or Cassette and press the RESUME/CANCEL
button.
Three flashes Paper jam/Paper
Output Tray is
closed
Clear the jammed paper, reload paper in the printer, then press the RESUME/
CANCEL button. If the Paper Output Tray is closed, open it.
See “Paper Jams” on page 72.
Four flashes Empty ink tank Press the RESUME/CANCEL button to resume printing with an empty ink tank.
Replace it with a new ink tank immediately after the printing. It may damage the
printer if you continue printing with an empty ink tank.
See “Replacing an Ink Tank” on page 42.
Five flashes Print Head not
installed/Print
Head not installed
correctly/Defective
Print Head
Install the Print Head. If the Print Head is already installed, remove the Print Head
and check the electrical contacts for foreign matter, then reinstall.
After reinstalling the Print Head, you may need to realign it.
If this error still remains, the Print Head may be damaged. Contact the Customer
Care Center.
Six flashes Inner Cover is open Close the Inner Cover and press the RESUME/CANCEL button.
Eight flashes Waste ink absorber
almost full
The printer has a built-in waste ink absorber for the ink used during Print Head
Cleaning.
Eight flashes indicates that the waste ink absorber is nearly full.
Press the RESUME/CANCEL button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact the Customer Care
Center.
Nine flashes A specified period
of time has elapsed
without receiving a
response from the
digital camera/The
digital camera or
digital video
camcorder
connected is not
compatible with
this printer
Disconnect the camera cable, press the RESUME/CANCEL button and reconnect
the cable.
If the error is still unresolved, there is a possibility that you are using a digital
camera or digital video camcorder that is not supported by this printer. Use a
digital cameras or digital video camcorder compatible with this printer
Mar 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
PAPER JAM CHANGE UNABLE 34
Usually when it does that, either there is just a small piece of shredded paper still jammed in the sensors, or the sensors are dirty. If you feel up to the task, take it apart and look for the sensors near the print head and near all the rollers and clean them up with either contact cleaner, VCR head cleaner or rubbing alcohol to get dirt and gunk off the sensors. If you don't wanna risk taking your printer apart, take it to you local technician to get it fixed.
Jul 07, 2009 | Brother DCP-130C InkJet Printer
Paper jam
This is bad news for these printers. Paper jams tend to ruin the print head. To get the paper out, first remove the print head and ink, if possible. Then go in back of the printer and at the bottom there's a piece that can be pulled out. That piece is hard to get in so take very careful not of how it looks as you pull it out so you can put it in the same way. The piece is sunk into the printer a bit and you got to pull by both ends of it. From there you should be able to pull the paper out. When done, put that piece back in and put the print head and ink back into the printer. The reason for removing it is to minimize any further damage it might get from pulling on the paper under it. Also be sure to put the print head on a paper towel and do not put the circuit board/contacts of it touching anything.
Mar 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Canon service 6000
Well... here it is :
The POWER Lamp Flashes Orange title-bar.gif An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
When a printer error occurs, the POWER lamp flashes. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error.
bullet.gif Two flashes: Printer is out of paper /Paper does not feed
Reload paper to the sheet feeder or cassette and press the RESUME button.
bullet.gif Three flashes: Paper jam/Paper output tray is closed
If paper is jammed, remove the jammed paper, reload paper in the printer, and then press the RESUME button. If the paper output tray is closed, open it.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
Press the RESUME button to resume printing with an empty ink tank. Replace it with a new ink tank immediately after the printing. It may damage the printer if you continue printing with an empty ink tank.
bullet.gif Five flashes: Print head not installed/Print head not installed correctly/Print head is defective
Install the Print Head. If the Print Head is already installed, remove the Print Head and check the electrical contacts for foreign matter, then reinstall.
If this error still remains, the Print Head may be damaged. Contact a Canon service representative.
bullet.gif Six flashes: Inner cover error
To print on paper:
Close the inner cover. Then press the RESUME button to start printing.
Do not move or close the inner cover during printing. It may damage the printer.
bullet.gif Seven flashes: The CD-R or DVD-R is not set on the CD-R tray
Reset the CD-R tray feeder with a CD-R tray containing a CD-R or DVD-R, and then press the RESUME button. Printing will resume.
This function only works with models that support CD-R printing.
bullet.gif Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during print head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible.
bullet.gif Nine flashes: A specified period of time has lapsed without receiving no response from the digital camera / The digital camera or digital video camcorder connected is not compatible with this printer
Disconnect the camera cable, press the printer's RESUME button and reconnect the cable.
If the error is still not solved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this printer. Use a digital camera or digital video camcorder compatible with this printer.
bullet.gif Ten Flashes: Cannot print on both sides of the page
The size of paper may not be compatible with automatic duplex printing. For information on the size of paper compatible with auto duplex printing, see "Automatically Printing on Both Sides of the Page." Pressing the RESUME button will discharge the paper, and restart printing from the front side of the next paper. The reverse side will not be printed when an error occurs.
bullet.gif Eleven flashes: Cannot perform automatic print head alignment correctly
Possible causes are as follows:
bullet_s.gif A4 or Letter-sized paper is not loaded on the sheet feeder.
bullet_s.gif Ink has run out or ink tanks are not installed correctly.
See Ensure that the ink tank is installed properly.
bullet_s.gif Ink level is low.
bullet_s.gif Print Head nozzles are clogged.
Press the RESUME button.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
bullet_s.gif The paper output slot has been exposed to a strong light source preventing correct print head alignment.
Press the RESUME button to resolve the error. Align the printer so the paper output slot will not be exposed directly to a strong light source.
After carrying out the above measures, if the problem continues after aligning the print head again, press the RESUME button to resolve the error, and then perform manual print head alignment. For details on manual print head alignment, see "Aligning the Print Head."
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Disconnect the printer cable from the printer, and then turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on after leaving it for a while.
If the problem remains, contact a Canon service representative.
Apr 21, 2008 | Canon PIXMA iP1600 Printer
Bogus paper jam
I had the SAME problem with my printer and after hours of searching on the web I found this solution on fixyourownprinter.com and it WORKED! I cleaned the contacts of both of the ink cartridges and then popped off the cover of the optical sensor on the side of the ink cartridges (black plastic cover over sensor assembly snaps off) there is a hole in the middle of the sensor, push it in with a thumb tack or toothpick and push up on sensor assembly and it will come off the side, clean the contacts on that and reassemble..the blue sensor light should come back on and you should be back in business.
Feb 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
80 people viewed this question
Ben Johnson
