Operation could not be completed. The print spooler service is not running.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 23 Answers
** Operation could not completed Printer (solved) **
I got my problem solved help of this follwoing article please click below and follow there mentioned steps and get your problem
fixed.
Click here to open solved Solution for this problem Error: Printer operation could not be completed (Solved)
http://www.techsupportall.com/how-do-i-fix-unable-to-install-printer-operation-could-not-be-completed/
Posted on Mar 08, 2013
To fix the error message, in Windows XP, click on start, control panel, then administrative services. From here double click services and scroll down to print spooler and double click on the icon. Change startup type to automatic and click start below that and you are rolling. If the problem occurs repeatedly contact the manufacturer of your printer for best fixes.
Posted on Nov 22, 2008
Printer spooler service not running
The spooler is not on your printer it is in the Windows folder on your computer and is used to hold documents whilst preparing to print.
Normally this service is set to start automatically and there are a number of reasons why it may of stopped but try this:
Right click on "Computer" in your Menu and then left click on "Manage".
In the page that appears click "Services and applications" and Click "Services"
Navigate down to "Print Spooler" and double click on that line.
A box should appear showing properties of the Spooler.
It should show
"Startup Type = Automatic"
"Service Status = Running"
If neither of these are true then change the Startup type to Automatic
and click on the "Start Button"
The service will then either start or tell you why it cannot start.
Nov 21, 2013 | LG Computers & Internet
The operation cannot be completed. print spooler service is running
GOTO RUN
TYPE NET START SPOOLER
HIT ENTER
IT WILL BE DONE
SECONDARY CHECK IF ANTIVIRUS HAD NOT BLOCKED THE SERVICE.
Feb 04, 2011 | Office Equipment & Supplies
Operation could not br completed. The print spooler service is not running
Hi There,
If your print spooler service is not running, then follow the below steps to get it working :
Step 1 :
* Start > run > services.msc > ok
* Select the service name called print spooler from the list.
* Check the status on the print spooler service, if it is stopped, then right click and select start or restart.
* Then the spooler service will start working....
Step 2 : ( NOTE :USE THIS STEP ONLY WHEN YOUR STEP 1 DOESN'T WORK )
In this case, we assume that the print spooler service is gone bad and we would have to recreate the spooler service.
* Start > run > cmd > ok
* Type: sc delete spoolsv (this will delete the corrupted spooler for us to create a new print spooler)
* Reboot the system and after rebooting the computer back.
* Type: sc create spoolsv (this will create a new print spooler service)
* Reboot the system and this time the print spooler service is a new and fresh spooler and it should work normal and perfectly.
Enjoy printing !!
Oct 22, 2010 | Office Equipment & Supplies
Your operation could not be completed, the spooler system is no running. I cannot install the printer.
Hi there Spooler needs to be delited.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 30, 2010 | Brother HL 1440 Laser Printer
SPOOLER SERVICE IS NOT RUNNING
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
Pls Rate as Fixya if this helps, Thanks!!
Jun 26, 2008 | Dell A940 All-In-One InkJet Printer
Print spoole
has this been resolved?
Jan 10, 2008 | Dell A920 InkJet Printer
PRiNt SP00lER
1. Go to Start > Run and type in services.msc then press Enter. 2. In the window that opens find "Print Spooler" on the right 3. Right-click "Print Spooler" and select "Properties". 4. Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service". 5. Make sure the 2 text boxes underneath say "1" in them. 6. Click Ok until you are back at the Services window, close it and you're good to go. 7. Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
Jan 08, 2008 | Dell A960 All-In-One InkJet Printer
PRiNt SP00lER
Try this FixYa for Error 1068.
Let me know how it goes.
Jan 08, 2008 | Dell A920 InkJet Printer
Print spooler
HI ,
This is JISHKUMAR, U need to click on dependencies tab.this u will get it when u double click on print spooler.just look which are the services under dependencies..whatever services you will find just go to that services and start them and then start print spooler service. this will 101% solve your problem
Printers vanished and can't add printer
Your shell extensions have a software conflict. The offending piece of software will have to be determined and removed, or at least stopped, before re-booting the computer. You may be able to repair the problem using the System Restore option.
Oct 10, 2007 | Adobe Acrobat Distiller Server V6 for Win...
152 people viewed this question
jasbo
jasbo
