Question about Gaggia Titanium Espresso Machine
Menu I cannot access the menu. When I press the menu/OK button,  only 2 options show - energy saver, and then self test. can someone tell me how I can access the menu? Thanks Frank Frank.oberklaid@rch.org.au
  • Gaggia Expert
  • 109 Answers
Let the unit complete it's self test mode.
When "select product ready for use" is displayed then you press the menu button to access the menu function.
Posted on Oct 08, 2008
Print command appears to being received, but printing is not occurring
Perform Tap 41 PRINTHEAD Health Diagnostics Test, along with supporting service level/diagnostic tests (service menu access procedures do vary by HP printer model, refer to HP printer diagnostics document, pages 45-47, to view normal display messages, http://inkjet411.com/?page_id=1813 )
Tap 41 PRINTHEAD Health Diagnostics (NOTE: applies to touchscreen printer models only):
1.Press 'Return' button (lower left side) four (4) times until 'Support' menu is displayed.
2.At 'Support' Menu, using the arrow key, navigate to the 'Service Menu', press Ok.
3.Use arrow keys to advance to the 'Special Reports' Menu. Select OK.
4.Use arrow keys to advance to the 'print mech button tap' menu. Select Ok.
5.'code = 0' will be displayed. Use arrows keys to change value to '41' (i.e. press and hold right arrow key).
6.When 'Code = 41', select 'OK'. The diagnostic test pattern will print.
7.Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced. Re-seat PRINTHEAD and/or clean rear electrical contacts and repeat 'Tap 41' test to verify connectivity is not the issue.
Nozzle test (use to determine if all ink cartridge nozzles/printhead is firing all colors properly)
Press return arrow 4 times
2.Press support menu
3.Press right arrow 5 times to print diagnostic menu and press ok
4.At nozzle test press ok
Self test/printer status (use to print internal printer settings)
3.Press right hand arrow 7 times to reports menu and press ok
4.At self test report press ok
Extended self test (use to evaluate color performance and obtain total page count)
4.Press right hand arrow 1 time to extended self-test and press ok
Print Quality Diagnostic Page (use to determine if printing alignment is correct)
4.Press right hand arrow 2 times to Print Quality diagnostic report and press ok
Print head recovery (runs 'intensive' printhead service cleaning routines, i.e. for a clogged printhead)
1.Press home key twice
2.Then return key
3.Then home key twice
4.Then return key
5.Then home key twice...............this will gain access to the Engineering Menu
6.Press the 'service menu'
7.Press right arrow 4 times to 'service test' and press ok
8.Press right arrow:
a.16 times to 'print head rec level 1' (basic recovery)
b.17 times to 'print head rec level 2' (medium recovery)
c.18 times to 'print head rec level 3' (thorough recovery)....suggested for severe streaking
9.Press 'ok' to activate either of the 3 selections above.
Semi full reset (can be used to help address intermittent or incorrect printer behavior issues)
1.Press return arrow 4 times
3.Press right hand arrow 2 times to Resets menu and press ok
4.Press right hand arrow 2 times to semi full reset and press ok (Note: this will return printer to factory default condition; regional setup will be required following this action)
* Failure of the PRINTHEAD has nothing to do with refilled ink cartridges; the PRINTHEAD assembly is a separate electronic unit in which the cartridges plug into and feed ink into. Refer to NOTE below.
4) To rule out printer/cartridge connectivity (assembly interface/connection) issues please ensure you have followed all steps on HP's support page - this includes PRINTHEAD removal and thorough cleaning of the electrical surfaces on the PRINTHEAD and on the CARRIAGE ASSEMBLY:
http://www8.hp.com/h22157/video-gallery/us/en/customer-care/printers-and-all-in-ones/replace-ink-and-toner/2286857593001/replacing-the-printhead---hp-officejet-pro-8600-e-all-in-one-printer/video/
Apr 07, 2015 | HP LaserJet Office Equipment & Supplies
HP Calibration Error
    For HP Officejet 6600 / 6700 printer models which suffer a calibration error, more than likely either the PRINTHEAD has connectivity issues (i.e. remove, clean all contact points, and reinstall), compatible/clone ink cartridge chips are causing the issue, the PRINTHEAD is approaching end of life, or not all ink nozzles are firing and therefore the printer is unable to calibration. Perform the following diagnostic checks to help make a determination:
    Tap 41 PRINTHEAD Health Diagnostics (NOTE: applies to touchscreen 6600/6700/8600/8700 printer models only):
        2.Then return key
        4.Then return key
          For more information on inkjet printer recovery tips, or solutions for a different printer model, please visit http://www.inkjet411.com
          -Thank you
Nov 22, 2013 | HP OfficeJet Office Equipment & Supplies
How to disable energy saving on KitchenAid Range
The Energy Saver Mode deactivates the display to reduce energy
consumption.
To Activate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver on."
will appear in the upper text area.
2. The setting will be activated after 5 minutes.
Any cooking function may be used with the range in Energy
Saver Mode by simply selecting the desired function.
To Deactivate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver off."
2. The clock will reappear in the display, and the range can be
operated as usua
Oct 10, 2012 | KitchenAid Ovens
HI tech, I have this HP LJ1600 and I have this mark on the right hand side from top to bottom just as a roller mark the page. When I do a self test page there is a colour band on the right and it is split...
If the band is one particular color then it is quite possible that you have a bad toner cartridge of the color that matches the band. You can also try printing a test page from the secondary service menu. Access the menu as follows:
To enter the secondary service menu, use the following procedure:
1. Confirm that the device is in a Ready state.
2. Press the button (Select) to enter the main menu system.
3. Press the button (Left arrow) and the button (Cancel Job) simultaneously.
4. Press the button (Select) to confirm 2ndary Service.
5. Press the (Left arrow) button and button (Right arrow) to navigate to the secondary
service menu.
Find the option for test print.
May 28, 2011 | HP LaserJet 1600 Printer
Remove screensaver from TV
Hello
You are refering about energy saving function I thinks. To energise this function, surf through its menu and come towards energy saver.
This power saving feature reduces the backlight
brightness level. The options are:
OFF-the feature is off and the power consumption
is normal.
LOW-power saving level is low and the backlight
brightness level is lower than normal.
HIGH-power saving level is high and the backlight
brightness is set to the lowest level.
1 Use the CURSOR Up or Down keys to highlight
Energy Saver. Press ENTER.
2 Use the CURSOR Up or Down keys to select Off, Low,
or High.
NOTE:The Energy Saver settings level varies with
the Picture / Sound mode.
OK.
Feb 20, 2011 | Sanyo 42 in. LCD TV
Goes to self test and says there!
You may have a bad system board, but try this first.
Press
Unplug power cord in the rear of the machine
While holding down the ENERGY SAVER key, plug in power cord
Scroll down to SHIPMENT SET
Press SET
Press 2
Wait for the machine to initialize.
Nov 24, 2009 | Kyocera Office Equipment & Supplies
Using timer
Kodak EasyShare C613
Changing picture-taking settings
You can change settings to get the best results from your camera.
1Press the Menu button.
2Press to highlight a setting, then press OK.
3Choose an option, then press OK.
■Press the Menu button to exit the menu.
NOTE: To better understand each menu option, use camera Help. Highlight a menu choice, then press the button. Some settings remain until you change them; others, until you change modes or turn off the camera. Some modes offer limited settings.Press Menu, , and OK to access settings
Options
Self-timer
10 seconds (default)—
so you have time to get into the scene.
2 seconds—
for a steady, auto-shutter release on a tripod.
2-shot—
one picture is taken after a 10-second delay. A second picture is taken 8 seconds later.
Exposure Compensation
Increase or decrease brightness before taking a picture. (Also see page 27.)
0.0, -0.5, -1.0, -1.5, -2.0, +0.5, +1.0, +1.5, +2.0
From: http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00711/C613_UG_GLB_en.pdf
If this helps, please post a rating for me. Thanks!
OpenSource13
Apr 19, 2009 | Kodak EasyShare C613 Digital Camera
CLEANS ITSELF TOO FREQUENTLY- 2-3 TIMES EACH DAY
Try maxing out your power save timers. Here are the instructions. I suspect the machine is going into power save mode to quickly. Here is how you do that.
NOTE: To save energy, the printer enters a power saver, low-energy consumption mode after a predefined period of time since its last activity. In this mode, most printer electrical systems are shut down. When a print job is sent to the printer, the printer enters the Warm-up Mode. You can also warm up the printer by pressing the [OK] button on the Control Panel.
If the printer is going into Power Saver mode too often and you do not want to wait while the printer warms up, increase the length of time before the printer goes into the Power Saver mode.
Modify the timeout value:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Printer Controls], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Power Saver Timeout], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select the required timeout value (30 - 240 minutes), and then press the [OK] button.
    NOTE: Select a larger timeout value to extend the length of time before the printer goes into the Power Saver mode.
  5. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
Feb 02, 2009 | Xerox Phaser 8500/DN Printer
My phaser 8560 won't say on, so it prints out the cleaner page and info pages daily after the very long warm up session. How can I keep it running so I don't burn through this very expensive ink.
Here you go.
To enable or disable the Power Saver (Energy Star) mode:
NOTE: The printer will only have the Power Saver menu selection if the printer was sold as an Energy Star machine.The Power Saver mode can only be enabled or disabled from the Control Panel.
  3. Press the [Up] or [Down] arrow button to select [Power Saver], and then press the [OK] button.
  4. Press the [OK] button until the required option is displayed; either 'On' or 'Off'.
  5. Press the [Down] arrow button to select [Exit], and then press the [OK] button to return to the main screen.
Oct 28, 2008 | Xerox Office Equipment & Supplies
Disabling Power Save mode
If you enter the config menu, you can turn off energy conserve. You enter the config menu by turning off the printer, holding the center and right arrow, and powering the printer on. Continue to hold the buttons until you see Performing self test. Then you will see config menu. If you scroll down to energy conserve and select it. You can change the option to off. This will disable power saver.
Jul 01, 2008 | IBM Infoprint 1532 Laser Printer
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
481 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
