Question about Olympus m:robe MR-500i MP3 Player
Olympus m:robe 100 missing file
On my computer i formated stuppid idea now it displays missing file
  • Thomas Lim
    Thomas Lim May 11, 2010
    We got disconnected on the chat session. You will need the mtrip software to recover that missing file. Much like when you format an apple ipod it will search for the config softwar that the mtrip can give.
  • 51 Answers
Http://www.esnips.com/doc/b15238f2-5133-43e4-b8c4-353375b77088/System_Index
unzip it, drag the System Folder and the Index.mum filedirectly onto your m:robe. then pull it off the dock. you might have topush reset.
and then freshly install the m:trip software from
http://downloads.olympus-europa.com/consumer/mrobe/m-trip/ENG/mtrip_english.zip
aftertht install the firmwarehttp://www.olympusamerica.com/files/oima_cckb/MR100_FirmSysUp_213.exe..beforeinstalling the firmware make sure tht u reset the player ..afterfollowing all the instructions of the firmware try to synch the playerto check whether it detects music and finally restart your m:robe totake effect..!!
Posted on Feb 11, 2010
Hi. My name is Natalie. I got an m:robe for my 16th birthday at MTV'S TRL. Today, I just plugged this in to my computer and i deleted songs, put some in, and now, its saying INVALID/MISSING FILE. After you...
okey..try this..i got the same problem and i managed to rectify tht using this method..check it out anyway...first of all try to format your player in ntfs filesystem and http://www.esnips.com/doc/b15238f2-5133-43e4-b8c4-353375b77088/System_Index extract the files to your player and then
after tht install the firmware http://www.olympusamerica.com/files/oima_cckb/MR100_FirmSysUp_213.exe..before installing the firmware make sure tht u reset the player ..after following all the instructions of the firmware try to synch the player to check whether it detects music and finally restart your m:robe to take effect..!!
Dec 29, 2009 | Olympus m:robe MR-100 Digital Media Player
Hellooo im having m-robe and i formatted it and i need a music loader that can load music on it
This is the software that was provided with the player.
Jan 27, 2009 | Olympus m:robe MR-100 Digital Media Player
Plzz
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Nov 08, 2008 | Olympus WS-100 Digital Voice Recorder
M:robe error invalid/missing file
hello, i had the same problem. recently, i had deleted all the files off of my mr-100. i downloaded this file.
Once you unzip it, drag the System Folder and the Index.mum file directly onto your m:robe. then pull it off the dock. you might have to push reset.
i couldnt get the "invalid/missing file" screen to go away for a while. if you slide the hold button into the hold position and then push the little reset button on the bottom, it will remain off and you can put it on the dock, then it will connect to the PC.
Aug 15, 2008 | Olympus m:robe MR-100 Digital Media Player
hey.
just re sync the m:robe and it should work.
i had this problem with mine and it was saying that coz i had gone over that maximum capacity that it could hold.
hope this helps.
Mar 27, 2008 | Olympus m:robe MR-100 Digital Media Player
Help!!
upload the firmware again
Apr 13, 2007 | Olympus m:robe MR-100 Digital Media Player
HELP
Did you go to Olympus's m:robe site and download the firmware and install it again?
Feb 01, 2007 | Olympus m:robe MR-100 Digital Media Player
Olympus mr-100 mp3 player
This is a photo of the inside of the M-robe. I tried the suggestions you gave with no improvement. I did notice that the other end of the hdd lead where it connects to the mother board was not straight in the board socket
When you remove this lead from the motherboard, make sure you don’t bend it or stress it out of shape. before you attempt to put this lead back in, make sure the small plastic lock strip is lifted out of the way. Then press the lead firmly back onto the receptacle. Then lightly press the plastic lock strip back over where the connector is on the board here. If you have completed this connection correctly and no other damage has been done, your M-Robe should start up. Good luck
Graham Everson
gdprassem@gmail.com
Jan 25, 2007 | Olympus m:robe MR-100 Digital Media Player
M robe Window pop up
try to update the firmaware and then format it with the help of tht..!!
Sep 27, 2006 | Olympus m:robe MR-100 Digital Media Player
Olympus m:robe MR-500i MP3 Player Logo
351 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
