Question about Samsung SHR-2082 8 Channel Stand Alone Dvr with Cdrw
I have a Samsung Real Time DVR Model SHR2082 and it will not do a backup to a cd. I have the manual and was able to do this once, but now it will not let me do it. In the backup menu the box at the bottom left showed USB Memory the first time I did a backup. Now it shows Internal CD and will not allow me to move to the start box to begin the backup.
Hi
had the same problem you have to select your backup period to fit the cd capacity
you cant backup everything as it will not fit
hope this is of help
Posted on Oct 02, 2008
How to reset Admin password on Samsung SDR-C5300N Digitalvideo recorder
If you have forgotten your admin password on a Samsung Security DVR, most experts would suggest that you have to contact Samsung and/or send it back to Samsung to have the administrator password reset. While this is true in some cases, it is not always necessary.
Many Samsung Security DVRs have a built-in reset that will allow you to wipe the settings of the device and reset the configuration, including the administrator password. Note that if you perform one of these resets, all settings will be erased and you will have to setup the DVR again. So you should only do this as a last resort - but to reset an admin password, the last resort is the only option.
Reset Procedures for Samsung Security DVRs
There is more than one reset procedure for Samsung Security DVRs, depending on the series and model. But in total, this only amounts to a handful. Since one reset can apply to several different models, I'll provide the resets here so you can try them on yours - I won't associate any one reset with a single model because a complete list of which reset works with what model Security DVR simply doesn't exist. Some of these won't make sense based on the buttons available on your unit or your remote. In those cases, just skip that reset procedure.
If you can perform a reset (in other words, if the instructions match what you have available on your Samsung Security DVR and/or Samsung Security DVR Remote), try it, and let us know in the comments if it works and on what model. If you tell us which model Samsung Security DVR you have, along with your results of each reset procedure, we can compile a complete list of reset procedures by model so that it will be easier for those seeking this information in the future to reset their Samsung Security DVR. Also, if you have a reset that you have used and you know works, let us know and we will add it here. I will update the list of Samsung Security DVR resets/recoveries as I encounter them.
So if one of these doesn't work for you, you may want to check back occasionally. In fact, if you leave your model number in the comments and any specifics about your problem, I'll try to get that specific reset for you. For any of these comments, just use the comment section at the bottom of this page - it is checked regularly.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
Then enter the 4321.
Samsung Security DVR Reset Procedure #2
Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3
This reset will work on Android based DVRs only. All steps are performed on the device itself.
Turn the device Off
Wait 2 minutes
Press and hold the following buttons
POWER,
HOME
VOLUME UP
The unit should power on. Once it does, you can release power.
Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
Activate the reset using the HOME button.
When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4
This reset will work on SDR models. It may also work on other models.
With just the cameras showing, press the following in quick succession using the remote:
Freeze
Alarm
Freeze
Alarm
Freeze
Menu
Enter
Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5
This reset will work on SDR models where procedure #4 failed. It may also work on other models.
Press the DVR Button to place the system in DVR Mode
Press:
Freeze
View
Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6
Courtesy Sergio Ayala
To factory reset the SDR-B74301
Reboot the DVR
Once the DVR has rebooted, enter the following sequence on the remote:
UP, RIGHT, 5, 3, 3
You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
These reset procedures cover many Samsung Security DVRs, but not all.
CCTV Networking Technical Support
Oct 07, 2017 | Samsung Home Security
My Samsung dvr model SDR75300n can't not reset my passwood.
you need to do on the dvr .remolt settings you cant do needs to be done by the dvr
Jun 15, 2017 | Samsung Cameras
How to start my Samsung SDR for remote view
please read your owner manual and start to using. If you do not have it download from www.fitness.manualsonline.com
God bless you
Sep 19, 2012 | Samsung Televison & Video
When I buy they give me a blank CD so I got no derection Do I have to pay?
You need to contact the people you bought it from or look on the internet for the brand or model that you have. The people selling the product should have given you the whole package of goods or it might be stolen from somebodie's house.
Sep 19, 2012 | Audio Players & Recorders
I need a march networks 4316c dvr installation and service manual
Everything that you require is on the CD that comes with the DVR. You just have to set the IP thru hyper-terminal if the DVR is not set to DHCP, but if it is, and you have DHCP server on your network, then just connect it, then install Administrator Console from the CD.
Administrator Console is used for almost everything. Investigator Console is for picture retrieval. Once again, manuals are also on the CD.
May 28, 2010 | Archos DVR Station MP3 Player
I have recorded footage from 9channel samsung DVR
Normally the recordings are in MP4 format and a lot of players cannot play it. You would need divx plus player. Its free.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 19, 2010 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Backup from Samsung DVR to CD
what type of media are you using?
Note
SHR-2040 supports the internal CD-R/W.
follow this process carefully
Backup
● If there is a device, the free space and the backup device is displayed.
● Select a date, time, and camera No. to backup, and press “Start”.
● When you change Start Date/Time or End Date/Time, free space keeps updated in
the Free Space zone.
● Afile name is composed of Folder/File Name. Afolder is composed of the backup
date(YYYYMMDD) while a file name is composed of the time(HHMM).
Afile may be renamed by the virtual keyboard. Afile name can composed of the
maximum 5 letters.
● In case that more than one backup device is connected, click the box in the
bottom of left corner to select a backup device.
● If there is no backup device, Warning sign pops up. Select and connect Backup
Device in 5-8.HDD Setup and proceed the backup.
● Press the “Stop” to stop the backup.
● Pressing Cancel during the Backup returns to the upper menu but this does not
affect the backup process.
● In case of USB HDD, the AVI check is impossible.
Caution
[In Backup Process]
Pressing THE “Cancel” returns to the upper menu but this does not affect Backup process.
Press “Stop” to stop the backup.
The speed of the set may down during the backup
mj
Sep 07, 2008 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
Samsung SHR-2082 8 Channel Stand Alone Dvr with Cdrw Logo
146 people viewed this question
Top Samsung Home Security Experts
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
