My LG 42LB9DF plasma TV worked just fine when I bought it a year ago, but the reception is now intermittently breaking up (pixellating) and the sound is will make a noise and cut in and out. We can't work out whether it's the antenna, or if it's the internal tuner?
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
  • 3 Answers
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
tvtek
  • 1284 Answers
SOURCE: no picture but sound on panasonic plasma
Unplug the TV and disconnect any HDMI cables to the set. If the issue goes away there is a possibility that your HDMI source is causing the problem. Anything on the HDMI can cause odd problems with the TV since the serial data and serail clock lines are routed on HDMI. Those are the 2 commmunication lines used throught the TV for operation so anything HDMI that might load down one of those can cause issues.
Posted on Mar 08, 2008
SOURCE: DVB not working on panasonic
Check the arial cable - not just the connections. Problem noted was due to an inferior cable that was not up to the job. It also ran alongside a central heating radiotor and pipes - not a good combination apparantly!
Posted on May 05, 2008
SOURCE: signal issues with my Insignia DTV converter box
As far as the antenna goes..NO. It is still an RF signal. The antenna just needs to be good for the frequency range of the stations you are receiving. The station numbers and frequency don't necessarily match like they use to. They are all over the place now.
Posted on Jun 23, 2008
Get sound and "invalid format" message displayed instead of picture
Could have still been hit by a surge. Take the back off of the TV and look at the main board were you connect your HDMI. See if it is scorched or components that blackened. Also check your DVD player on another set. Your DVD player could be the problem.
Apr 11, 2012 | LG Televison & Video
Pixelation
The problem is more or less with the LCD screen itself. The manufatcurer covers dead or burnt pixels.I would suggest contact Vizio Support on the following number
Technical Support
Toll-Free: 877.698.4946
Thanks
proton
Aug 09, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Hi, ihave a plasma TV, sometime ago and it has only been since we moved houses, our TV goes pixelated and then we get No signal on 1-2 channels, and now we have no signal full stop, i have a booster...
You have antenna issues. Try raising the antenna some more or relocating to another spot where the signal strength is greater. Pixelation is a sign of a weak signal -
Jul 02, 2017 | LG 42PC3RA 42 in. HD-Ready Plasma TV
My LG Plasma TV has sound problems on certain channels-mainly one
Get in touch with your cable operator and measure the strength of signals being received via the Cable. It can be boosted by the cable operator from their end or attach a booster on your line...............sodeep
Aug 19, 2009 | LG MU-42PM11 47 in. EDTV-Ready Plasma...
Plasma TV smell?
a smell from a plasma is usually a electrolytic capacitor leaking.  Luckily, replacing capacitors is very easy.  you can do it yourself if you have any skills at all, and if you can identify it.
just google what i am saying, you should be able to find the info you need to replace them.
Jan 31, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Samsung 42' plasma tv,screen keep flashing, blurry,no pics
I'm not really sure what causes this but I might be able to help.
I have an LG 42 plasma which had the same problem. In my case I removed the video and the tuner board (they both were mounted on the same frame which was screwed on the tv chassis) and installed them in a "wooden box" so that there would be no electrical contact with the rest of the chassis except from the cables connected to them. It now works fine.
Jan 11, 2009 | Televison & Video
Remote problems
Replace batteries of your LG remote.
Oct 11, 2008 | LG 50PC5DC 50 in. Plasma HDTV
Dec 31, 2007 | LG RU-42PX10 42 in. HD-Ready Plasma...
Digital tuner
if the signal breaks up and the picture looks like small squares with audio coming in and out its 99% of the time signal / reception how old is your ariel it may not be suitable for digital.
http://www.freeview.co.uk/help/reception-viewing/q2
Nov 17, 2007 | LG 42PB4D 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
