Question about Intel D101GGC Motherboard
Turn off with in 1 min.
Dear Sir.
I have problem in motherboard.
When I start the computer they have start properly but turn off with in 1 or 2 minutes. then no start. I also change RAM slot even I disconnect all attached drives and cards but the problem is still same.
Is this a BIOS problem or CPU or RAM?
Kindly guide me.
    Master:
  • 397 Answers
That is most likely the proccessor overheating and shutting down.
Remove the processor's heatsink and fan, clean off all the old thermal paste with alchohol and a cotton swab, you can use a piece of plastic like an old credit card to remove any stubbon thermal paste.
Reapply the thermal paste (about the size of a grain of rice is sufficient) and reattach the heatsink and fan then start the machine up again.
Posted on Sep 12, 2008
My sony vaio eb (e series) wont turn on, the power button flashes green! PLEASE HELP!
test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Sep 24, 2012 | Sony VAIO EB Series White Notebook...
Computer will not turn on.green light on but screen not lighting up.
Hello jaysmith362,
Your computer problem has 3 different cause:
1. VGA cable is not plug-in properly into the computer
2. Your System memory is not properly inserted.
3. BIOS problem
To solve your problem it.
1. Please ensure that your VGA is properly inserted into your VGA port of the computer. Or if you got an Videocard see to it that it is plug-in to your videocard.
2. You have to remove your system memory then return it properly into your memory slot.
3. Or by BIOS resetting, in your motherboard you will see an CMOS reset in it, try to remove the jumper then insert it in the other portion of it (it always has an 3 pins or 4 pins in the BIOS reset, if the BIOS jumper is located in the 1 and 2 pins try to insert it in the 3 and 4 pins). then restart your computer then turn it off after 3 seconds. Then bring it back the BIOS jumper into normal that is 1 and 2 pins.
I hope it will solve your problem
Thanks for using FIXYA...;-)
Aug 19, 2011 | Computers & Internet
Dear sir my computer motherboard is some time
Hi, we have ways why computer restart, 1. the power supply can not drive it, so replace your power supply, good if you have voltage regulator. 2. Swap memory chips from good one.3. Check if capacitor in *********** board is bloated.
Jun 16, 2011 | Intel Motherboard
Sir, My PC is starting problem, 1.Starting UPS - ON the system starts automatically without swith ON. 2.After Starting the keyboard & Mouse get stuck 3.after Restart the the keyboard & Mouse...
The UPS may not be sufficiently stable on power-on to run a PC immediately.
Try going into the BIOS setup after the restart and look for the option that has the computer "Start up automatically after power failure." Turn this off. That will take care of problem 1.
If this also takes care of problem 2, you may want to check whether the UPS has a problem. Start by plugging a couple of lamps with 100 Watt bulbs into the UPS outlets instead of the computer. Turn it on - the lamps should behave normally, not flicker or change brightness. With the lamps and UPS still on, unplug the UPS. The lamps should stay on with little or no change, and the battery warning light should not come on right away. If the UPS fails this test, its battery may need to be replaced or it has a regulator problem.
Apr 08, 2011 | Intel DG965RY Motherboard
Computer turns on but will not beep or nothing shows on display.
1.On plug the Ram
2.Turn on the System without Ram
if you here Beep Sounds then problem with Ram.
3.Turn Off The system
Fit the same Ram Properly.
3.Turn On .
4.If not Ok,the Buy a New Ram and fit it properly.
Feb 12, 2010 | Gateway (4000274) Motherboard
I added a Pentium P4 2.66Ghz cpu 533FSB, Bios appears and says the due to new cpu installed system has started at 64Mhz please select correct Frequency. I select 2667 Ghz and 133Mhz saved and restarted....
Turn the computer off.
Turn the computer on.
Wait a minute or two -- it may "time-out" and reset it to the "slowest" speed.
If that fails, look closely at the motherboard,
or read the manual for the motherboard, to find a "clear BIOS" jumper.
Turn the computer off. Move the jumper from "1-2" to "2-3".
Wait a few seconds. Move the jumper back to "1-2".
Turn the computer on, with the "default" settings.
Oct 28, 2009 | ASUS P4S533-MX Motherboard
Sir, I have Intel D485PEBT2 mother board.Whenever I do a cold start it does not boot.If I do CNTL+ALT+DEL it restart and boots.cmos battery is ok.date and time ok.I tried several times to change Boot...
I would suggest that you do a factory reset on your mobo. To do it, here are the steps you can follow.
1. make sure that computer is OFF and unplugged from the wall
2. locate the 3-pin jumper on the mobo that is near the cmos battery
3. once located, remove the cmos battery
4. then from the 3-pin jumper, if the jumper is connected to pins 1-2, switch it over to pins 2-3
5. return the cmos battery back
6. plug the computer back then turn it ON
7. you will probably get an option to reset or restore settings back to factory, it that's the case, continue with it
8. after doing so, turn the computer OFF again and unplug it
9 remove cmos battery then return the jumper to it's original position
10. put in the battery back then turn the computer on again
11. go to the bios and set it back to the setting that you have set it before
12. check and see if problem has been resolved
* I would suggest getting a new cmos battery if it's already old
Let me know if you need further assistance
Jon
Oct 16, 2009 | MSI MS-6547 Motherboard
Power failure & dell dimensions 5100 will not turn on
" Is there anything else that I can do before taking to a service person?"
Yes, you can unplug the computer for about one minute, then reconnect the power and attempt to turn it on. Do any of the fans come on? Any beeping from the motherboard? Any lights flash anywhere on the comupter when you do that? Answers to those questions will be helpful to the technician if you do have to take it in for service. If you have a spare power supply around I would try that too before resorting to a service call.
Jan 01, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
Problem in motherboard
remove the cover and check that the cpu and power supply fan are working. clean the cpu fan/heatsink of all the dust and dirt that has accomulated.
Robert
Sep 04, 2008 | Intel D101GGC Motherboard
Intel D101GGC Motherboard Logo
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
