1998 Ford Escort Logo
Posted on Sep 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1999 Ford Escort idle problems
I have a 1999 Ford Escort. It started idling fast a few weeks ago with an engine code. The code said something about the idle air contro valve. I replaced it. It worked good for about two weeks. The check engine light came back on with the same code. I called Advance Auto to see if they would replace the idle air control valve. Advance Auto replaced it and it worked fine for a couple of days. It started idling fast again w/no engine code this time. It starts idling fast usually after going up a mountain. Once it starts idling fast it won't quit now for about one minute after you stop. It idles between two and three thousand rpms when idling fast. Any help would be appreciated. Thanks.
  • Anonymous Sep 14, 2008
    My 1997 Escort 1800 16v has an erratic idle when warm/hot and sometimes cuts out when cold. Could this be the idle speed control valve?
  • Anonymous Mar 23, 2014
    could it be the idle air control valve
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jun 01, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
2714
Points
5
PVC valve is not metering air correctly, it will appear ok shaking it but looses it ability to maintain proper position causing a medium to gross vacuum leak.
Anonymous
Level 3:
Guru:
  • Master 674 Answers
  • Posted on Sep 12, 2008
Anonymous
Master
Level 3:
Guru:
Answers
674
Questions
9
Helped
395057
Points
2113
You need to look for a vacume leak thsi would also make your IAC valve go beyond range.good luck
1996 ford escort lx engine runs to fast
If it idles high, with it in park, block off mouth of throttle body with something, it should kill the engine. If very little or no effect on idle, you have false air getting in there from somewhere.
Make sure throttle valve is closing, where applicable, take throttle cable loose, see if idle returns to normal. Check and clean idle air system. Any applicable trouble codes?
2answers
Low idle, engine vibration
I see this is an older question, but in case someone is having the same problem, here goes.
Besides the things above, I'd pull a spark plug, check it. Could just need a tune up, or you could have just a single cracked plug. One bad plug or bad spark cable will cause what you described. I always like to start with the simplest/cheapest solution. A tune up with new cables won't hurt anyway.
2answers
What can cause a Fast idle on 1999 Ford Escort?
Try cleaning the throttle body and check the gap on all the spark plugs also all electrical sensor plugs and battery terminals this could be related to engine temperature also if to hot rpms stay up longer to cool off but maybe your idle air control valve is bad when did it start?
1helpful
Replace the fuel pump, car start idle fasts for 10 sec. then die
did you replace the line filter,it may be cloged.
Idling issues
the first thing u need to do is run a key on engine on self self test to see if the problem is with the idle speed control motor. any shop with a good scanner can preform this test, let me know the code they get.
2helpful
Why is my 1994 Chevy S10 Blazer lugging? motor shakes and lugs.
Could be vacuum leak or bad ignition wire(s).
I had a similar problem on my "93 Ford probe. The engine idled pretty rough with shakes, Turned out to be a head gasket leaking engine coolant into the cylinder during low rpm's. At fast rpm's it was fine becuase the internal cylinder pressure was greater than the hot coolant pressure & would prevent the coolant from leaking in.
A friend has the same problem with his "94 Blazer 4.3 L, throttle body injection, manual tranny. He hasn't fixed it yet, It started a few weeks ago & is getting worse. His gets a fast idle with hiccups which causes the engine shake. He already checked the EGR valve. He also has a severe exhaust problem, Not oilly but very gray & terrible smelly, but only when the fast idle problem happens. THis fast idle hiccup problem starts when the engine is warmed up.
1995 ford escort idle problem
The IAC valve is usually the problem with the 1.9 Escorts ,causing a very poor engine idle at a stop. It is located on the side of the throttle body .
Engine idles lumpy - why?
1.6 zetec surely ,for this year
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
