Question about Panasonic PT-61G63 61 in. Rear Projection Television
PT-61G63 Convergance screen is out of alignment - can do convergance for center of screen but the outer edges are still mis-aligned - Top and bottom are curved toward center of the screen. (concave and convex) Any help is appreciated. thanks
  • ebrunk Sep 12, 2008
    Tim,
    I've done component level repairs on a number of electronic items, including repairing the foil on pc boards - should be no problem - just need to know what to look for...and which componants to replace.
    thanks
    Eric
    Novelist:
    Champion:
  • 203 Answers
Your convergence IC's most likely need to be changed, possibly some resistors as well.
Do you know how to solder and use a meter? If so you may be able to fix this yourself for under $100. If not you will need to repairman to repair it, this should cost around $300-$500 Let me know if you want to repair it so i can get you going.
Tim Nolan
Posted on Sep 12, 2008
  • experttv
    experttv Sep 12, 2008
    There are 2 large ic's mounted on a heat sink. Part numbers should start with STK-392. Change both of these and check all the resistors around them and make sure none of them are open. If you find an open resistor send me the location of it and I will get you a value for it. If you have any questions as to what parts to change or what resistors to check, post a picture on here and I will circle what you need. Let me know what I can do to help!
    Tim Nolan
I have a convergence problem in the bottom of the lower left quadrant pf the screen. It is like a parabolic semi circle that is at the very bottom edge of the screen. The front screen isn't damaged at...
Tv 100% have a convergence problems,if any parts of the tv picture colors lines R,G,B are mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board the 2 STK ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Yellow band on bottom of PT. Double image on news scroller at bottom of PT. Have tried convergence - no luck. Green will not align and will not come down.
Ur tv have any colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures.Ur tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.The parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 13, 2010 | Panasonic PT-47WX49 47" Rear Projection...
On one side of the screen the red projection doesn't line up with the others. It is about 1" off at teh edge of the screen and lessens to where they align about 11"-12" towards the center of the screen. ...
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis any alignment,have colors shadows or picture look like 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved tv convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 08, 2010 | Hitachi 60SDX88B 60" Rear Projection...
JVC AV56-WP74 Convergence problem
Hello saduchan,
I think that your ICs are ok, What you need to perform is what is called dynamic convergence, This involves using the internal convergence controls to align the outer edges of the screen. I am assuming that the center of the screen is ok? it's just the edges which are misaligned, right? Now for the bad news, this task is not easy in fact the job takes a pro about 6 to 12 hours to do it right. I think you should have a qualified TV technician attempt the static convergence setup followed by the dynamic convergence setup.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 29, 2008 | JVC AV-56WP74 56" Rear Projection...
Phillips 60in projection,rred/greenish 3d effect
the two resistors were likely burnt out with a convergence IC (chip). these are usually a stk392-120 on a philips, or simmilar. the alignments can be very tedious and difficult. what needs to be done is replace the ICs that control the colors that are mis-aligned. you might see that the green is square and straight, but the red or blue is off. in most cases, i would just change both convergence ICs plus the bad resistors. then go to your full re-alignment of convergence to fix the picture. hopefully the previous owner didn't mess anything up too much (if they changed anything on the CRTs ie yokes, lens focus, centering magnets it could counteract your electronic adjusments). before you put too much time into it, look to see that all 3 colors are atleast focused and it appears that the CRTs have been left untouched. once you get circuit repaired, you will probably want a service manual to help with alignment. this complexity may bring you to want to just pay for this repair, could run you anywhere from $200-400 depending on severity and local rates.
Dec 07, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Alignment issue - PT-47wx49 Panasonic PTV Tubes out of align
your convergence is off. u need to get in service mode to correct this problem. its pretty in depth and time assuming. u need to go to servicemanuals.net and for 15 bucks u can get a service manual. it has every thing u need to fix that tv. i had same problem but i had all 3 colors out of whak. i see alot of people on this forum changing the ic's and resistors to fix convergence problem, (me too)and nothing works. i got this manual and saved me alot of money. its been 3 months since i corrected it and i am still watching it. good luck.
Nov 24, 2008 | Panasonic PT-47WX49 47" Rear Projection...
51mp392h Blue Convergence Problem
Hello rogeuryder,
This is the one thing that even make TV repair persons shudder. You don't really have a convergence problem in the normal sense. The convergence works. What you have is a misaligned convergence situation which any documentation and or book on TV repair will tell you that at this point manual convergence adjustment is needed and the only thing you will have to do is keep trying to adjust the convergence until you get the center aligned, and then work towards the outer edges using both static (Center) and dynamic (outer edges) convergence techniques.
As this may sound it is; Very Very Tedious.
Here is something that may help you:
http://books.google.com/books?id=ttBofTJM7FEC&pg=PA112&lpg=PA112&dq=static+convergence&source=web&ots=hyUMeeY9s6&sig=DZm27q1aMbLiwKA__fyysBd2yUE&hl=en&sa=X&oi=book_result&resnum=9&ct=result#PPA112,M1
I have used this book when I use to teach TV repair. I hope you discover what I am tried to convey in my e-mail, this is no longer a question of can you fix a TV? It has become a question of do you have the patience to adjust a TV.
Good fortune in doing this, you will succeed if you just take your time and do static convergence first and then do the dynamic convergence with the manual controls. The procedure will be in the service manual.
I hope this helps
Thank you,
Shuttle83
Jul 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Hitachi 50fx20b
convergance iC needs to be replaced.
http://serviceman.site88.net
Jun 02, 2008 | Toshiba 55H70 55" Rear Projection...
Convergence problems
I would suggest the convergence ICs as well as a couple resistors right near the Convergence ICs mst likely. 90 % of the time thats the problem. They are not expensive, if you can solder you can handle it if your careful with your solder and use heat sink compound. The ICs will have a number stamped on them usually STK XXX-XXX on a huge heat sink. The following link will have replacement parts http://electronix.com/ Hope this helps you out
Jan 11, 2008 | Panasonic PT-47X54 47" Rear Projection...
Convergance/bowing
most like tes thats all your going to have to replace + the silicon as if you dont thet wil not last as long as they should. Also you may have blow fuseable resistors next to the ICs make sure you check them as well.
Aug 16, 2006 | Philips 9P6044C 60" Rear Projection...
Panasonic PT-61G63 61 in. Rear Projection Television Logo
67 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
