Question about Nikai DV8500 Camcorder
NIKAI DV8500 CAME WITH INCORRECT CHARGER
BATTERY CHARGER ACP-12E THAT CAME WITH THIS CAMERA DOES NOT FIT. I CAN NOT CHARGE THE BATTERY I NEED THE CORRECT CHARGER.
SOURCE: new nikai DV925 video cam
go buy a new camera..
Posted on Oct 30, 2009
I need to know what the charger looks like. does it take batterys? where do they go? how do I charge the camara?
You can purchase a charger for this camera at http://www.amazon.com/Wall-Charger-Adapter-Vivitar-Vivicam/dp/B003M6BXBO/ref=pd_sim_e_1
Feb 28, 2011 | Vivitar ViviCam 8025 Digital Camera
Wh put my battery int he charger provided with the camera, the ligth blinks instead of being a steady light. My battery will not charge. Waht is wrong? Is it my battery or the charger?
If the [CHARGE] lamp flashes red
The battery is faulty or the battery is loaded in the charger
incorrectly. Remove the battery from the charger and check if its
contacts are dirty. If they are, wipe them off with dry cloth and
then reload the battery into the charger. When experiencing
charging problems, also check to make sure that the power cord
is not disconnected [CHARGE] lamp from the power outlet or charger.
If an error still continues to occur after you perform the above
steps, it could mean that the battery is faulty. Contact your
nearest CASIO authorized service center.
I hope this information helps you out and good luck!
Nov 20, 2009 | Casio Exilim EXZ75 Digital Camera
Does it use battery only or charger
It depends on the Model of the camera. Few camera's do have that function and few don't.
However, most models do not have this feature as this would require a built in charge circuit, which would complicate the design and definitely increase the size of the camera. Even large cameras don't (usually) have built in charging circuits.
The thing to remember is that in order to charge the battery you must have the same voltage as the original charger. USB ports only supply 5volts... typically at 500mah or less. If your camera does not allow for the battery to be charged in the camera then it won't matter because you will need an external charger.
Be careful about he type of external charger you buy because lithium batteries are dangerous if charged incorrectly.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 23, 2009 | Samsung Digimax 4010 Digital Camera
I cant get my Vivitar digital battery to charge
You may need to buy a new battery or charger. Make sure your battery is fitted properly within the charger, and same goes for the charger in the wall.
Apr 10, 2009 | Casio Exilim EX-Z750 Digital Camera
Can't take pictures or video
this sounds like it doesn't make sense, and I don't know why it started working ok, but all I did was switch the position on the memory card to ''locked'', put it in the camcorder and of course it told me the card was locked. So I reinstalled it after ''unlocking'' it, and now it seems to work ok. Can't explain why this worked and still don't know what a "Directory Index" is...
Dec 22, 2008 | Nikai DV8500 Camcorder
Charging
If there is a flashing red light it could mean the battery is faulty or loaded in the charger incorrectly. Remove the battery from the charger and wipe off with dry cloth for it could be dirty and then reload into charger. It worked for me also i made sure none of the prongs on the charger were bent where the battery fits in. Hope that helps : )
Sep 02, 2008 | Casio Exilim EX-Z120 Digital Camera
Drivers
HELP!!!!!!!! I'M HAVING THE SAME PROBLEM
MARCYN64@YAHOO.COM
Dec 20, 2007 | Nikai DV8500 Camcorder
Nikai DV8500 Camcorder Logo
53 people viewed this question
Top Nikai Video Cameras Experts
Are you a Nikai Video Camera Expert? Answer questions, earn points and help others
