Olympus Camedia D-550 Zoom Digital Camera
Problem for Olympus Camedia D-550 Zoom Digital Camera
Why does my lens close automatically after i turn on my Olympus Digital Camera D-500???
By Laxgirl on May 03, 2006
When I turn my Olympus Digital Camera D-500 on my lens will come out but then quickly and automatically will close again. I just replaced the batteries with new ones (Panasonic Long Lasting Digital Electrons). Why does my camera keep turning off automatically??? please help me out!!!!
Same Problem
Dec 21, 2008
-   I wonder if its only the battery and memory problem, cas additionally in photo review mode the display goes off suddenly and goes back to the first photo in the list.
Anybody tried reparing the mechanical slide door cover ?-   kamlakarv
Dec 21, 2008
-   I have the same problem with my D 550 camera. Also the -   Guest
Nov 28, 2008
-   I have that same problem, but I believe it is related to the sliding window that activates the lens assy. If I pull the sliding cover farther away from the lens, it will come out and stay until I move it slightly towards lens, and I do mean slightly. It is annoying to say the least. Is there a cheap fix to this? -   sdclevenger
Oct 19, 2008
-   My problem is exactly what you describe but I do not know how to fix it or repair it. please could you help me out with this. my e-mail is mikecarrier@videotron.ca. Thank a lot for your help I really appreciate. Also could you tell me where to go to get it fix. Thank again.
Mike Carrier
-   Mazad
Best Solution
posted on May 06, 2006
Helpful)
BowerR64
Rank: Wiz
Rating: 80%, 973 votes
Does it beep or do anything other then turn off? what does it do in play mode? Does it have a good memory card in it? hold the memory door down tightly and try it. Akalines on these older smart media card type cameras just dont cut it they need ALOT more power then you think. NiMH rechargables are the only thing i would recomed using anymore. Dont listen to the tv NiMH are what you need.
If you notice on the memory door when it open, there is a little plastic tab that stick out. This tab goes into a little slot on the camera, that slot pushes a button that tells the camera when the door is open and closed. These buttons can sometimes cause problems. So make sure the batteries are NiMH and the door is fully closed with some pressure on it.
Also see what it does in playback mode. If it stays on fine in playback mode it may have a lens problem. The mechanism for the lens to move in and out could be jammed
Was this helpful?
Yes
No
Solution #2
posted on May 04, 2006
Somewhat Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3606 votes
Only thing I can suggest is to try different batteries again. maybe something more generic, regular aa's.
also note that the d-500 can use only mem cards that go up to 16 mb, 32 if you do an upgrade. If you're trying to use a newer card that might be the reason.
Good luck
Was this helpful?
Yes
No
Popular Solutions for Olympus Camedia D-550 Zoom
Questions and Unsolved Problems for Olympus Camedia D-550 Zoom
Do you recommend Olympus Camedia D-550 Zoom Digital Camera?
Answer
Answer
My Olympus D-550 keeps shutting itself off, or resetting. It does not matter if your just looking at... (More)
Answer
after taken a picture i wanted to see how picture came out so i slide the lense cover to retract the... (More)
Answer
The screen on my Olympus 550 just started to be white only when it is turned on. What can we do... (More)
Answer
Can a cracked LED screen be replaced on an Olympus D-550 and if so, how much? Pat
Answer
i recorded a small video with my camera but i can not seem to get it uploaded to my computer. When... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Olympus Camedia D-550 Zoom...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 756
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
