Question about Breville ESP8XL Espresso Machine
Just bought machine. Filter holder is different from one described in booklet. It talks about the filter holder has been replaced by a spring systems that holds the filter in place. I got the big holder, a pod insert and another insert that doesn't seem to fit the basic holder. I am assuming that if I want a double shot I put it in the basic holder. I won't use the pod so that is a non problem. But the additional holder doesn't fit snugly. What's up if this isn't too confusing? Thanks, M. Fleshman
    Problem Solver:
  • 18 Answers
Hi m.fleshman! in answer to your question, i paid $25 for mine's like a $25 paperweight. hold the coffee grinds basket up to a light-can you see light thru just one hole, or all of the holes? if just one, this passed quality control at the factory & shouldn't have passed. i imagine that details like this are rampant on this machine. if i had bought mine at the store instead of 2nd hand, i'd take it back for a full refund! otherwise, it may be that someone put the wrong filter in the package. it's also possible that you may need to take out the spring (if it's removable) from the bottom of the filter holder-i don't know b/c i bought mine used. hope this helps!
Posted on Jan 11, 2009
Cuisinart grind & brew - spring in the filter area popped out. not sure where it goes?
Yes, you place the spring into the tube at the back. When you replace the basket holder, make certain you reach in behind the holder and guide the spring into the proper place on the holder. (Otherwise the spring will be forced to a permanent bend and not work as well. Can't find replacements for this spring on Cuisinart's website).
As for why it pops out better now, when you removed the basket holder and cleaned it, you also cleaned the plastic guides on each side. In normal use, these guides acculuminate coffee and tend to get sticky or gummy. When the door pops open, the sticky rails grab the guides and slow the sliding action.
Cleaning them restores the clean guide rails to slide open on. (Next time you clean the basket holder, remember to reach in and wipe out all the inner parts, including the plastic rails that the basket holder slides out on. These get coated with coffee as well. And the place around where the grind basket fits over the ground basket. This area always gets sticky with old coffee. Just use a wet paper towel and clean everything. (But remember to be careful when you reinstall the basket holder so that the spring fits back properly.
Dec 04, 2017 | Cuisinart Grind and Brew 10 Cup Coffee...
I broke the peice that puts water through the coffee basket on a Keurig Elite B40 Coffee Maker where can I buy parts for this?
If you are talking about the K-cup holder that punches the bottom of the k-cups, they usually are not for sale, and you can only find them on ersale sites like Ebay.etc...
you could also go buy a "Keurig My K-Cup Reusable Coffee Filter"
and just use the main grey plastic filter holder... but you will have to puncture the bottom of the k-cups yourself before dropping them into the holder...
You wont need the filter basket or the lid if your using k-cups... just the filter holder...
dont forget to punch a hole in the k-cup first...
May 14, 2010 | Keurig Elite B40 Coffee Maker
Cleaning the pump
The filter is part of the screw cover, there is probably something stuck in the filter that is preventing it from pulling out.
Make sure you have unscrewed it as far as it will go anti-clockwise, and try pulling it at the same time to loosen it.
Apr 30, 2010 | Washing Machines
Spring out of Saeco Venezia Filter Holder
This is the best diagram that I have hope it helps.
Jan 23, 2010 | Saeco VIA Venezia
Are you talking about the handle?
Fit the spring in the indentation in the handle cup (just below the rim).
Then firmly push the filter inside the spring(you may need to give it a slap with the palm of your hand).
Apr 04, 2009 | Nuova Simonelli Program VIP Coffee Maker,...
Gaggia Deluxe - Excessive steam discharging into filter holder
your seal of non teturn valve of group, just above metal part where you put upper filter. open the valve and carefuly clean, check the seal and spring.
Mar 09, 2009 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Spring came out - where does it go?
That is from your dripp stop. If you can replace it it will be in the bottom of your filter holder. If not Please tkae out the valve on the bottom of this filter holder. You will have no dripp stop but it will work just fine.
Jun 01, 2008 | Krups Aroma Control 197 Coffee Maker
Pavoni Si - leak from above filter holder
Check your screws in the bottom of the portafilter, If they are too tight the spring mechanism inside can't do its job, adjust them and it should work. Also, don't over fill your portafilter, if you put too much coffee in then there is to much pressure and again the water will flow from the top. Hope this helps
Oct 09, 2007 | La Pavoni Espresso Si PAB-16 Espresso...
Breville ESP8XL Espresso Machine Logo
180 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
