Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
HOTPOINT HSS25IFMCWW WATER DISPENSER IS NOT DISPENSING WATER. ALREADY CHECKED WATER SOURCE AND IT IS GOOD.
    Sergeant:
  • 409 Answers
Is the ice side working? it could just be the water paddle or actuator or you may have a frozen water line.
Posted on Sep 13, 2008
Hsm25gftsa
This problem is common and can be difficult to solve, first of all you have a air leak and because of this, your dispenser leaks. Check every connection for the water system, starting from the back of the unit at the valve. Disconnect the water to the tank first, put the water valve in a bucket and hit the dispenser switch to see if the valve leaks after dispensing water, if it does, replace valve, if not continue in to refer section behind crispers. (this is behind the veggie bins can you see any water at the bottom? If so, repair the leak and continue forward. Check under freezer door at the connection to assure not leaks of water. Again this is a process and after all of this is done or check, one of these solutions should solve your issue. I know not a simple answer but this will correct the issue when everything is checked.
Good Luck
Oct 29, 2013 | Hotpoint (HSM25IFTSA) Side by Side...
My hotpoint side by side is not dispensing water, ice is being made and dispensed but no water. Do you have any ideas? The filter was replaced 2 months ago. Water line isn't crimped or leaking. Any...
In this case the dual water control valve side that turns the water on for water dispenser found here as location 800 in photo=> HSM25GFRASA Motherboard and Compressor Components
I believe you replace this part=> WR57X10051 Water Valve - Dual Outlet
And you will be good to go for dispensing water! Click here for a Service manual that will work with your model=> Here Please rate this solution and If you have any questions please let me know, Thank You Sea Breeze
Oct 10, 2011 | Hotpoint HSM25GFRSA
I am not able to get water to dispense from the cold water spout. I have checked the water line and am get water to the source. I opened the line splice at he bottom of the freezer door and I have water...
The water line in your freezer door is frozen. Make sure the freezer setting isn't too high above midpoint. If you unplug the frig. and crack open the freezer door for a couple hours it will thaw out. Good job on posting description.
Sep 25, 2011 | Hotpoint HSS25GFP Side by Side...
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
Water dispenser is not working no water dispenser
If the light is dimming when you try to get ice (dimming then getting bright in cycles) then thisis a common problem and GE will fix it. The Main circuit board on the back goes bad causing the ice\water dispenser to quit working then eventually the fridge quits cooling. Call 800-386-1215 and tell them the problem. There is a recall for the board
Oct 13, 2009 | Hotpoint HSS25GFP Side by Side...
Ice dispenser not dispensing ice or water
Check the water filter - it should be at the bottom of the fridge - turn it 1/2 turn to the left. After several months of use (less if you use it a lot) the filter can clog.
Jun 24, 2009 | Hotpoint (HSM25IFTSA) Side by Side...
My Hotpoint refrigerator (HSS25GPJ) stopped dispensing water from the front. What is the problems and how can I fix it?
There are 2 water valves located on back of refrigerator. one controls the water to ice maker and the other sends water to the water dispenser. The valve could be bad or the dispenser control on front could be defective. The first thing to do is check the water valve on back. When pressing the dispenser does the valve click or make a noise? Let me know, Sea Breeze
Mar 27, 2009 | Refrigerators
Water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
Dec 24, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
194 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
