2001 Chevrolet Tahoe Logo
Posted on Sep 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changed rear pads. Brake indicator on dash is still blinking and chiming. How do you reset
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 87 Answers
  • Posted on Sep 05, 2011
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
87
Questions
Helped
31318
Points
270
Is it the "brake"repair light blinking & chiming?? Or is it the "ABS" brake light blinking/chiming. Brake light should be red, ABS amber
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 13, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
940
Points
The brake light is blinking and chiming and the abs light is. On also
I just changed the brake pads in the front wheel, and left the rear wheel unchaged, the brakes where good for a while, after a week the antilock and brake indicator on the dash boar came on with a static...
two things, re check job done on front brakes mybe improper fittings on pads and sensor,next is check rear brake pads and sensor condition, mybe need to replace too...
1helpful
Brake pad wear indicator light does not go off at the dash after changing rotors brake pads and the sensor in the front wheels all pads and rotors and the sensor is ok at rear. the vehicle has only 30000...
Did you change the sensor? if you did, do a battery reset (disconnect for 10 to 20 min.).
Obviously the wear sensor has made contact with the rotor and is already damaged. You're not even suppose to resuse the wear pad sensor if its worn or damaged anyways.The way how the sensor works is that it must make contact to the rotor to complete the wear pad light indicator circuit. There is no mentioning that he replaced the the wear pad sensor with a new one.
But if one did replaced the wear pad sensor and the wear pad indicator is lit up, the way to reset it is to leave the key on in ignition switch #2 or #1 for about 30sec. turn it off and its reset.
Its possible that you forgot to replace the brake light sensors. They are about 15 bucks, and have to be replaced in order for that light to turn off. You can either get them from the dealer where they'll likely charge you 3 times as much, or you can go to http://www.turnermotorsport.com and get them there.
You have to reset the light by leaving the ignition switch on position #2 for about 30 sec. turn off the ignition and start the engine up and see if it goes out. I recommend buying a new wear pad sensor as well because now light will lit up when you're way below spec (less than 3mm)
Also, you could try with this procedure for one E39: Turning off the Check Brake Linings warning on the Instrument Cluster...
- so you've just changed the brake pads on your E39, along with the wear sensors. The old sensor(s) needed replacement cause you waited a bit too long before changing the pads, and wore through the sensor(s), turning on the BRAKE light on the dash. But wait, the light is still on? But there's a new sensor installed... what gives?!
- there is a procedure required in order to turn off the light/warning. With the ignition off, step on and hold the brake pedal. Now, while holding the brake pedal down, turn on the ignition switch to position 2 (just before cranking). Hold the brake pedal until the BRAKE light is off. Tada, the warning is gone and reset.
NOTE: This procedure worked on a 2001 E46 325i. It took about 15-20 seconds, but it cleared out w/o having to unhook the battery.
Other details find in the Owners Manual 2006-BMW-Z4m-Roadster-Owner-Manual
Keep us updated.
8helpful
3answers
How to shut off Brake wear sensor after pad change
If the brake pads were worn enough to activate the warning light the sensor or sensors must be replaced. There is no reset for this.
2helpful
Brake light is on and chime is on
No the light and chime does not indicate worn out brake pads or shoes.
However, you were correct to add fluid to the correct level.
Just to be clear, you are talking about the red brake indicator light on the dash and is not accompanied by the amber ABS brake light.
If the ABS light is not involved, there is a magnetic switch located in the brake master cylinder. When the fluid level is low, it triggers a switch in the master cylinder and causes the light to come on.
Some times a "gentle" tap on the master cylinder reservoir will loosen the stuck float and turn the light off. One way to verify the switch is causing the issue, you can disconnect the harness connector at the master cylinder and the light should go out.
Start there and let me know.
Regards,
5helpful
Check brake pads light on dash
There is a sensor on each of the front (not sure about the rear) brake calipers that indicate via the dash light when brake pads are worn down and need replacing. The wire is probably broken on one or both of the front wheel calipers. If there is enough slack in the wire you can just splice it back together with **** splice connectors and seal with heat shrink insulation. My '02 Passat has had it happen twice, first on the drivers side, repaired wire and light went out, then the other side broke, repaired the same way and haven't had any problems since.
8helpful
3answers
Brake Pad Sensor
i have replaced both front/ rear pads, and no matter what the dash light will not go off. I have disconnected both front/rear sensors, and light is still on , any suggestions?
1helpful
03 Yukon denali park brake warning wont turn off
hi for info the brakes warning light on dash is also an indication that brake fluid level is low? or there may be a leak resulting in fluid level drop ? also considering age of car you may need to inspect brake pads wear ? if your car has low brake pads wear indicators attached to pads ? or the hand brake switch req's checking to ensure it is being pushed to off position when h/brak is down ? so fluid level low is the obviouse 1st check as fluid will displace from reservoir as pads wear low hence the level indicator on fill cap trips on may i suggest if it is low level b4 you top up? check your b/pads if you have not done so recently? or replaced since new ? hope this helps you locate problem best wishes from the uk
1helpful
How to reset the brake lamp warning indicator and chime
The light will go off as soon as the light or the circuit to the light is repaired, if it is still on and the brake lights work correctly, meaning bright normal not dim looking then the monitor for the lamp out warning is defective, they are very pricey would take the bulbs out if i where you.
7helpful
4answers
Brake Pad Sensor
On my bmw 325i front pads changed,indicator on dash still on,help!!
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
