Question about Canon PowerShot A530 Digital Camera
Lens won't deploy
The lens system seems stuck: Will not open when pressing the on button. Lights are coming up but lens still in off position.
For a meticulous individual, what are the chances that I could repair it by opening the casing. Could this lens mechanism require light lubrication?
Thanks for your help.
I bought an A530 with the same symptoms, thinking that I might be clever enough to fix it and get a cheap camera. Wrong ! If you don't have good eyesight for a start,you'll need a jewellers loop or an electronics technicians magnifying lens so that you can see what you are doing .
I had to get into the lens mechanism because that's where the problem obviously was.
I don't believe that you should try to fix it. The camera is probably not worth fixing.
I had a hard time getting the lens clear ,so that I could open it up for a start. It took me about an hour to get that far, and it was impossible to remember the sequence of operations I took, and there are some different size and shape screws that go in particular places that necesitates taking pictures or a video of your steps so you can try to put it back together again if you are able to solve the problem..
The odds of being able to solve a lens problem are very slim, because there is nothing in the mechanism that is prone to slight malfunction,-- ONLY due to breakage, and appparently small parts for the lens are not available. You can replace the lens as a whole unit , but the cost of replacing the lens and the labour cost of getting a trained and equiped technician to fit it, are more than a new camera..
I approached a technician from Canon and when I told him what I was doing and that I wanted to fix it myself , he said that would be a "major achievemnt" if I was successful.
 He took pity on me because of my enthusiasm and gave me another camera and told me not to take it apart.
There will probably be tiny teeny little teeth snapped off tiny little gears that drive the lens mechanism,and there's nothing you can do to fix them,(atleast nothing that is realistic or practical), let alone disassmbling and reassembling without damaging anything else in the process.
Apparently ,they are not supposed to be fixed, they have a life and then you throw them away when something goes wrong sooner or later. Sad but true. Now if you can get your hands on another camera that has a fault but a good lens, and if you are particularly methodical, inteligent and have good hands, and some luck you may be able to succeed,it's not impossible, but I took the technicians advice and accepted the gift graciously.
Posted on Oct 04, 2008
I have a minolta MD lens 35-70mm f3.5 that is stuck at 70mm. how do i get it unstuck?
Is your lens having a "macro 1:4 - 1:7" green sign near the "70"? If it does it may be stuck in the macro position... ? To put it back into the normal "35-70" zooming position just press the little black and greenish button on the lens, turning the zoom anti-clockwise.
Well... i'm Italian and tonight my english is particularly stuck.. But I hope this could help you!
Let me know, cheers :)
Feb 02, 2011 | Cameras
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
Camera stoped working and lens is in the out position, i can't get it on again
It seems your camera Lens got stuck in open condition, This will happens due to two reason.
1) Either your camera battery got died or need to be recharged or replace.
2) Your camera is malfunctioning and need service (repair).
To resolve the problem. first check battery indicator on your camera, If battery indicator shows battery low, than you need to charge it or you need to replace your battery.
Follow the instruction to retract camera lens:-
1) Turn on your camera.
2) Press the Playback button on the back of your camera. The lens on your camera should retract.
If problem still not resolved then your device need to be serviced (Repair).
Rating the solution is highly appreciated...Good Luck.
Feb 28, 2010 | Samsung Digimax S750 Digital Camera
V1253 Kodak Lens stuck open, will not power on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.
Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u rate me!!!
Feb 12, 2009 | Kodak EASYSHARE V1253 Digital Camera
Mirror is stuck down
if it its just a perticular lens then its because the body cannot comunicate with the lens to disable the lens lock Press and hold DRIVE MODE and AV buttons while turning on camera.
Jul 27, 2008 | Minolta Maxxum 400si 35mm SLR Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Lens retract problem
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Dec 30, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Jammed camera
A temporary fix to power up is to press the menu and power button at the same time. When the lens is extended and it beeps, on my camera , the lens is *stuck* Give it a gentle tug , then try the power button again
Oct 19, 2007 | Samsung Digimax S800 Digital Camera
Camera froze whilst taking pictures, lens stuck.
It happend to me also. I think it is caused by the lens mechanism. It is stuck and it disabled all other functions.
Jan 02, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot A530 Digital Camera Logo
56 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
