Volume not working on television set
I have a 27" Symphonic television with a cable box hook up. The volume does not work. I can put the volume up all the way and still no sound can you help with this.
  • j_dorcelus Jan 03, 2009
    i was poking around the speakers the day before but not enough to break the speakers i think what can i do no sound at all
    symphonic tv with cable
  • Anonymous Feb 27, 2009
    same symphonic 27" with inexplicably no volume even after all the cords and wires were rechecked and tightened.
Speaker problem must be open...or theirs a problem with the sound section
try to replace first the speaker...
Posted on Sep 12, 2008
Volume display at zero but volume still loud
If you are using a cable box it has volume controls as well--if so turn sound down there.
If that does not work try hooking a DVD etc to a rear input to see if volume on that input works normally.
The box can malfunction and if unplugged (set is not likely but possible also) and then plugged back in both the set and box if used will reboot.
Apr 02, 2012 | Televison & Video
No picture (all snow).
Try hooking a DVD etc to one of the rear inputs to see if it works that way--if so you may have a bad tuner in the set but there are ways around that.
Apr 01, 2012 | Sony FD Trinitron WEGA KV-27FV300 27" TV
Attenna hook up
Yes, This set does not have a digital tuner built in. All over the air signals are now digital. This set will work without a converter if hooked up to standard cable,DVD,VCR or Video game console. If you purchase a DVD with a digital tuner built in you can skip the converter box and hook your HDTV antenna directly to it.
May 06, 2010 | Symphonic ST4919 19" TV
Wii hook up to time warner cable box with a dvd
I needed another part... an RCA cable splitter to put two cables into the same TV connection.
Nov 09, 2009 | RCA Televison & Video
Do I need a dtv digital converter box for my Symphonic SC313D 13 inch tv?
Pretty much a hoax on those diverter boxes. People ran out and bought them thinking that won't have reception. I have many years in maintenance and several years in nursing homes with different tv's in every room. Not once have I needed a box to pick up channels with or without cable. I myself get 16 channels with rabbit ears and thats enough for me. And I do own a combo as well and it has simple antenna and does me just fine. Depending on your location, the old tv antennas we use to put on our houses...they work amazing! Might be able to snag one on a freecycle or craigslist site. Good luck! :)
Jun 05, 2008 | Symphonic SC313D 13 in. TV/VCR Combo
TV volume suddenly low
I had the same problem and had to fix with a work around. I take the audio directly from my cable box and pipe it in to an external 'theater in a box' system.
Do you have a universal remote code?
Jan 19, 2008 | Olevia LT27HVX 27 in. LCD Television
Volume won't work in satelite mode
A few possibilities - try volume + on satellite box itself/reset satellite box
Are you using coax or RGB cables? unplug and replug composite or component audio cables if using those
Aug 19, 2007 | Hitachi 51F59 51" HDTV Projection...
Tv remote dosn"t work
Check with new battries, and if you have a camera phone you could see the front IR bulb lighting up when seen through the phone display. Patrick
Jun 16, 2007 | Symphonic ST419E TV
Audio sound but no video
if you had hooked up everything correctly check your wires probably they are defected.if you had done that check your tv the video circuit maybe defected.you can also try another tv or dvd and see what they do good luck
May 13, 2007 | Symphonic ST419E TV
Volume is not working correctly...getting lower
Is your set connected to a cable box? If so then the box itself could be causing your problem. Some of the boxes have their own volume controls. Otherwise you could have a problem anywhere from the rf input to the audio amplifier section. A tuned circuit could be drifting off frequency in the tuned part of the audio circuits. You'd need to have it checked out by a technician. Stargazer
Mar 14, 2007 | Emerson EWF2703 27" TV
Televison & Video Logo
863 people viewed this question
Top Televison & Video Experts
Electro Med Services...
