posted by cableguy on May 02, 2006
I have a jenn air model number JES9800AAB that the glass top broke. How do I replace it and how hard is it to do?
1 Other User Has The Same Problem
Comment by Guest, posted on Jul 13, 2008
I too have the same problem with this very model and was wondering where I get the replacement stove top. I called Sears, which is where I purchased the range and they were not helpful AT ALL!!
Best Solution
posted on May 03, 2006
Replacing this top is not too difficult. It is secured by four screws on each side. You might have to remove some of the flanging in the back to pull it off. Make sure to unplug the the unit. I would think that the top might be pricy, but if you take your time replacing it should be no problem.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Jenn-Air JES9800A Electric Kitchen
Email this problem
Email this problem
Can you Help with these Kitchen Ranges problems?
Jenn-Air JES9800A Electric Kitchen Range
FC code on front pannel
FC code will not stop beeping Answer This...
left side venting
left side venting
Can a right side vent be... Answer This...
power loss
power loss
we just installed our jenn-air... Answer This...
error code
error code
My Jenn-Air keeps beeping with... Answer This...
Jenn Air slide in range...
Had continual beeping- touch... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
Find Parts
