Question about Dryers
Maytag mdg3000aww some times no heat
Thank You for the suggestion to replace the coils. I thought and hoped it would be them so I started to look for the part numbers of the coil kit earlier and plan on ordering them tomorrow.
Thank You Again
  • 943 Answers
Good that will solve the problem THE APPLIANCE DOC
Posted on Sep 13, 2008
  • john gagnon
    john gagnon Sep 26, 2008
    hi did you replace the coils if you did & it worked , leave a positive feed back thanks the appliance doc
Replace engine coil check engine light still on rx350 year 2007
Some sensor is erratic or need replaced; before to waste money, I suggest scanned the comouter to now what fault code is stored there, note this code number and come back again, with this information could start to look solutions.
Sometimes Autozone or Autoshop with OBD scanner reader make this job for free.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 29, 2012 | Cars & Trucks
Volvo 850gls 1994 starts and turns over normally but won't stay running, will start when car cools down
Hello and welcome to FixYa!
Looks like that the ignition coil is faulty. When the ignition coil is faulty the car tends to stall when engine is warmed up. I strongly suggest that you replace the ignition coil to resolve the problem. Not a big deal, it's common on all vehicle.
Hope this helps and thank you for using FixYa! Have a good one!
Apr 15, 2011 | 1994 Volvo 850
94 jeep wont start after trying for long time a few days gose by and it suddenly starts replaced lot of parts still wont start only when it wants to.
Have you replaced the coil pack? The coil pack supplies current to the plugs. If the coil pack is faulty it tends not to give current to the plugs. One good reason why it won't run most of the time. I strongly suggest that you replace the coil pack and observe how it goes.
Apr 14, 2011 | 1994 Jeep Cherokee
I am not getting a spark on the plugs and so the car does not start.I fitted a running engine in another body and the trouble started.
Hi and welcome to FixYa!
Only one thing that can cause the vehicle not to start. It's from a faulty coil pack. If the coil pack is faulty it tends not to give current to the plugs so I strongly suggest that you replace the coil pack. The coil pack is located on the side of the engine where the plug wires are attached. You will need to detach the cap to gain access to the coil pack.
Once you removed the cap you can start removing the coil pack. Once replaced you'll be good.
Mar 03, 2011 | 1995 Honda Odyssey
I have a 96 GMC Suburban that turns over with spark at the coil but has no spark at the plugs. I have replaced the coil and the ICM. What else could it be?
Have you replaced the distributor coil pack? If the coil pack is burnt or worn out there will be no spark to the plugs which may result to a no start issue. I strongly suggest that you have it replaced.
Jan 25, 2011 | 1996 GMC Suburban
Maytag gas dryer will heat for about one minute
The gas coils on the gas valve have gone bad. These are located on the gas valve and will be 2 solenoids. Replace them both and should be able to get as a set. 12001349 should be the number and cost less than 60.00 for the set. Good luck and thank you for using Fix Ya.
Feb 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
When started, the dryer works normally. Then the
Good day,
This is a common problem. The gas valve has 2 black coils mounted to the top. One has partially shorted.
You need to replace the coils as a kit.
Remove both wire plugs, remove the 2 screws holding the coils in place, and lift off.
The clip I've included does not apply to repairing the coil kit, but does show you how to access the area. It is a Whirlpool product.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Jan 19, 2010 | Kenmore Dryers
My Maytag LDG8200AAW does not stop automatically and does not sta
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 279834.
Disconnect power and turn off gas before working on this dryer.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
The disassembly procedure is covered beginning on page 3-11 of the manual listed at the link below. Operation and replacement of coils is covered at page 3-32. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Reverse process to re-assemble.
http://www.servicematters.com/maytag_library/docs/16008714.pdf
Sep 24, 2009 | Maytag Dryers
New Coils, does not start.
Check your wiring on the 2/3 coil also the gap seems a little excessive to me I run at .026 with a dyna 2000 and coils
Nov 20, 2008 | 1995 Suzuki GSX 1100 FS (Katana)
2001 hyundai santa fe 6 cylinder 2.7 spark plug wiring position from spark plug to ignition coil. 3 coils have the numbers 1-4 2-5 3-6. so what number goes to whst spark plug?
HI......
OK. just follow the number on the ignition coils.
And the number on the cylinders are.
The FIREWALL side are 1,3,5, Starting from the belts location.
The RADIATOR side are 2,4,6, Starting from the belts location.
The coil with number 1 go to cylinder 1. as the same way the rest of the coils and cylinders.
OK... I hope this solve your question .
THank you for use fixya.
Jul 25, 2008 | Hyundai Santa Fe Cars & Trucks
Dryers Logo
151 people viewed this question
Top Dryers Experts
