Question about Jenoptik JD C160 Digital Camera
Marscamera by bell
I downloaded the software, but camera does not work, it says driver open fail. I plugged in camera to usb port and my computer says device not recognized
  • crowbird Oct 20, 2008
    i can i take pictures with my mini camera
Plug in Camera, go to the Device Manager - Imaging Devices and “update” the camera’s driver the unzipped file location you chose.
Enjoy!
Posted on Apr 21, 2009
I have plugged it in and it my computer will not recognize that the USB is even plugged in, but it does charge the camera.
Try all the different USB Ports on your computer, sometimes certain ports can 'glitch' and not recognize the device that you've plugged in. If you've tried plugging it in all the ports and your computer still hasn't recognized the camera, re-install the driver software for the Olympus SP800UZ.
If all else fails, you can also contact Olympus customer service, they're quite prompt and helpful.
May 17, 2011 | Olympus SP800UZ Digital Camera
Help with my Bell and Howell BH-10
You should have had a cable come with your camera; one end would plug in to your camera with a small square end, and the other end would connect to your computer. The computer end would be a standard USB end. You should have also received a disc in your box that had software to load onto your computer. Once that software was loaded, you would plug the camera in. Your computer would recognize the camera and startup the software. A box would open and it owuld give you a choice of things to do. Usualy it would give you thumbnail views of all of the pictures in your camera and ask if you wanted to copy only some of the pictures over to the computer, or all of them. It would also allow you to delete all of the pictures from your camera.
ddddddddd
If you go to either of the following websites you can download the software you need.
http://www.bioticaindia.com/bh-10.html
http://members.driverguide.com/driver/detail.php?driverid=
76886&action=summary&from_ums=1
That should do it.
Apr 07, 2010 | Bell & Howell BH-10 Digital Camera
Why can't import my pictures into the computer?
Have you downloaded the Kodak Easyshare software? It will be easier to transfer picture from the camera to the computer also easyshare software has feature to enchance picture download not to mention that you can send picture thru email using the esayshare software. To download the software visit www.kodak.com/go/easysharesw.
Transferring pictures/videos with the USB cable
Turn off the camera.
2 Plug the labeled end of the USB cable into the USB port on your computer.
3 Plug the other end of the USB cable into the USB port on the camera.
4 Turn on the camera.
Note: EasyShare software opens on your computer. The software prompts you through the transfer process.
If still having issue importing picture from the camera to the computer call Kodak support line at 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z730 Digital Camera
Bison camera
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Sep 22, 2008 | Computers & Internet
Digital camera keychain by bell marscam
After you delete very thing you have installed on your computer that has anything to do with your camera,
Download this and don't have your camera plug into your computer then install this it works....
: MR97310c Mini Digital Camera Drivers Version 2.03 All Functions work.zip
* Turn on your computer or reboot.(this ensures consistent starting point)
* Connect your camera to the PC using USB 1.1 cable.
* When the found new hardware window opens install drivers automatically.
* * the found new hardware window may open up more than once. If so then click install drivers automatically for each time it opens up.
* Double click the "PCCam" shortcut in your "All Programs" menu and follow directions.
If this does does not work ...
* Check to make sure the USB port is working properly in device manager.
* Make sure your computer is running a fully updated version of supported Microsoft Windows platform. Check computer properties for version of OS.
* Try having the camera turned on before connecting it to your computer.
Jun 16, 2008 | Jenoptik JD C160 Digital Camera
Vivitar 3 in 1 Mini Digital Camera Error
Remove all Camera Software.
Assuming you have a Windows Computer when the camera is plugged in and in the upload mode
The computer will recognise it as a new device in My Computer.
Jun 07, 2008 | Vivitar ViviCam 35 Digital Camera
Pentax EI-100 not downloading pictures
Check the connecting usb cable that connects the camera with computer. Excessive usage causes cables breakages.
  1. Replace the usb cable with a new one available at a very low cost in market.
  2. Try other Usb ports on computer to plug in the camera
Hope it works. If not contact me again
Mar 28, 2008 | Samsung Digimax S730 Digital Camera
Downloading digital camera to computer
I'm not familiar with the Vivicam, but most cameras do not require any software. You just plug in the cable to a USB port on the computer and then look in Start - My Computer for the camera's memory. If that does not work, try some other USB device to make sure the computer's USB port is actually working. A memory stick would be perfect to try. If the port does not work, take the computer back to the store and have them fix it. Probably just a matter of the ports not being enabled in the computer setup or a loose connection. If you have ports on both the front and back of the computer, try them. If all else fails, you could use a card reader. Many all-in-one printer devices have card readers and you can buy a little card reader for perhaps $25 so you can take the memory card out of the camera and read it on the computer.
Sep 09, 2007 | Vivitar ViviCam 5100 Digital Camera
Canon sd600 trouble downloading images to computer
Did you checked that your existing camera's drivers are supported the Win Xp OS ?
Jun 24, 2007 | Canon PowerShot SD600 Digital Camera
Camedia software to see my camera via the USB port.
I'm assuming a Windows Machine (98 or 2000), and that you have (known to be) working USB ports. Boot your computer. Plug the computer end of the USB cable directly into the computer USB port (not a hub). Turn off the camera. Plug the camera end of the USB cable into the 3000. Then turn on the 3000. Windows should recognize new hardware. When Windows asks about drivers for the new hardware, direct it to your Camedia CD. Probably directory \USB\Win98 (or 2000) or something similar. Windows should then load the driver automatically. I *don't* think the 3000 will show up as a Drive device in My Computer. I think only the 2040/3040/E10 models will. But, Camedia should see it now. Toward the left-hand side (center) of the Camedia screen you should see a camera icon. Click it and it should open directories, drill down till your pix appear as thumbnail images. If Camedia says it can't find the camera, select Edit/Options/Download from the Camedia menu and ensure that USB is the selected choice.
Sep 07, 2005 | Olympus C-3000 Zoom Digital Camera
Jenoptik JD C160 Digital Camera Logo
205 people viewed this question
Top Jenoptik Cameras Experts
Are you a Jenoptik Camera Expert? Answer questions, earn points and help others
