Question about Lexmark E320 Laser Printer
Paperless paper jam
After clearing two paper jams today, the printer's paper jam light stays lit no matter what.  There's no paper in it anywhere, I'm sure.
Will replacing the cartridge help?  It's fairly new and bona fide Lexmark.
    President:
  • 2,712 Answers
Ok, the paper jam ERROR could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced or repaired under warranty.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Posted on Nov 13, 2008
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
Aug 21, 2014 | D-Link D LINK DELL B1260DN MONO LASER...
Paper jam light will not go off and there is not paper jam in the unit.
Over time paper dust and toner residue can build up around the drum and paper feeder rollers. Open your printer and remove the toner cartridge and Drum unit. Use a soft brush to clean any residue. Replace toner cartridge and drum unit.
A tiny bit of paper can cause the paper jam light to stay lit.
Jan 16, 2010 | Office Equipment & Supplies
After working perfectly all this time, our printer has stopped working. The light is lit that says power---paper out.
sounds like a paper jam. make sure no objects are jamming it. then unplug it for 5 minutes. when you power up if it still says paper jam, spray some BLOW OFF spray. That should clear any objects.
Nov 06, 2009 | Panasonic KX-P2130 Matrix Printer
My HP P2015 reports a Jam when there isn't one
Take the Tray 2 out and check if all the paper guides are moving freely if they are than remove the toner cartridge and check if any toner sensor is not align correctly.
If they are aligned correctly than next to the pickup roller there is a small piece of plastic make sure it should be hanging freely if it is than we need to perform cold reset of the printer.
Switch off the printer press and hold down the go button and switch the printer on keep holding down go button till the time three lights lit up on control panel, as soon as three lights lits up release the go button and let the printer initialise of it s own.
If that doesn't fix than Formatter Board of the printer is faulty.
Logic:
If there is no paper jam and printer rep[orts the jam means either any of the sensors is not aligned correctly and reporting the jam or formatter Board(Motherboard) of the printer is faulty and showing incorrect display.
Thanks and Regards
Jun 20, 2009 | HP LaserJet P2015d Printer
Paper jam error light on kodak esp 5
  1. Remove the paper tray.
  2. Disconnect the power cord, wait 5 seconds, then reconnect the power cord.
    NOTE: The printer will reset and eject the paper. If the paper does not eject, try to remove it manually.
  3. Replace the paper tray.
  4. Press the Print button on the printer to resume printing.
Apr 01, 2009 | Kodak ESP 5 Printer
HL 2040 paper jam light is blinking but there is no jam. the printer sounds like it dies out everytime it tries to print.
Often the paper jam light will stay on when the *back* paper jam door is not cleared.
Open up the back of your printer. There is a 2nd door behind this door that you can pull open. If there is a paper in this section, pull it out and it should clear your red light.
When clearing paper jams, clear the front first, and then if the red light is still on, you need to check the back hidden door for another piece of paper.
Dec 08, 2008 | Brother HL 1440 Laser Printer
D660 - Cleared paper jam, error message remains
may need to reset the printer, unplug it, plug it back in see what happens
Dec 04, 2008 | Canon imageCLASS D880 All-In-One Laser...
HP Photosmart 2610 - Paper Jam
I cleared the paper jam but i am still getting a paper jam message. I checked thoroughly and dont see any pieces of paper anywhere. I press ok and still get paper jam message. I turned the priner off and on serveral times and that did not work. Same message. I am feeling very frustrated. Its been a week today. Help!
Sep 16, 2008 | HP Photosmart 2610 All-In-One InkJet...
Clear Paper Jam error -- but there is no paper jam!
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Apr 16, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Lexmark E320 Laser Printer Logo
477 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
