Question about GPX DV7500 System
Wont turn on
My gpx dv7500 will not turn on how can i get it to turn on.thank you
  • fowler12 Jan 02, 2009
    my gpx dv7500 will come on but it will not do anything else
The on button has a short it connects when it feels like it. A parts list did not come with it. Where can I get a parts list?
Posted on Feb 19, 2008
    President:
  • 3,130 Answers
Sounds like you gotta power supply problem in the main unit. to repair this your gonna need a service manual most likely or you have to take it in to a repair shop to estimate for you .. if you post a schematic we will assist you in trouble shooting if you have any previous experience. Good luck.
Posted on May 02, 2006
Only two speakers work when a CD is being played...either MP3 or regular CD's. Why are the other speakers and subwoofer not playing sounds. Model DV7500
You mean a GPX DV7500? I can't find the manual. Do YOU have it? Do all the speakers work during setup or on real multichannel sources?
If you're using analog inputs and NOT selecting any of the DSP modes you will hear just stereo.
May 20, 2011 | Audio Players & Recorders
Player door does not Eject easily nor closes properly, causing door to Jamm.
There is a small strap that looks like a black rubber band that actionate the door mecanism. open the cab and clean it with qtip and alcohol, otherwise replace it, you'll find some at local electronics parts shop...
Oct 07, 2009 | GPX DV7500 System
Instruction manuel needed for GPX dv7500 system please
You can get a user manual from http://manualfox.com
Just send them a search request.
Feb 18, 2009 | GPX DV7500 System
Hook up to tv
hello there. name is ryan lets see if this helps.
typically in a combination unit there is no rca audio ouputs on the tv. reason being is it is a combo unit not meant to be a item within a home theater system. it has the whole home theater built in it. ;) however if there is any audio output jacks on the tv you should be able to wire the surround sound unit up via rca cable output from tv to input on reciever for surround sound
Feb 13, 2009 | GPX DV7500 System
THANK YOU
Im having the same problem
Jan 12, 2008 | GPX MW3836 MP3 Player
Freezing
sounds like a bad solder joint that is cracked...as GPX heats up, the crack starts to get bigger and cutting off electric circuit, then cool down closes the gap and current resumes. First try breaking and then making all possible connections outside then inside unit. Then, if no success, remove the circuit board and clean it with alcohol and brush then carefully look at each solder joint with a magnifying glass. If one found, simply re-solder it.
Nov 27, 2007 | GPX DV7500 System
Gpx dv7500 dvd player will not power on
I've seen this problem before with devices that have audio amplification circuitry.
In the cases I've seen, the connections to the speakers were the culprits.
First of all, you should only use the GPX speakers that came with the device. I don't know what their impedance is, but if it was 8ohms, you should only use 8ohm speakers. The same for 4 ohm, 6 ohm, etc. The safe bet is to use the speakers that came with the system.
If you are using the intended GPX speakers, and they're hooked up correctly, (only one speaker per output) then I would suspect a short in at least one of the speaker wires.
Amplification circuits apply fluctuating power to the speakers which correlate the sound wave. The power reaches the speaker, has an electromagnetic effect on the speaker cone, which pushes it out or pulls it in. This produces sound. The speakers job is to be affected by the amplifier, and convert the electric power into a mechanical movement. Speakers of different impedances respond to different levels of power. Ideally, your amplifier will supply power to speakers that will use it all up and return none.
An amplifier designed to drive 8 ohm speakers will get too much kickback from little 4 ohm speakers. When I've seen this sympton before, the amplifier had another circuit designed to monitor dangerous conditions such as this and shut down to prevent permanenet damage. Another dangerous condition might be a short in one or more of the speaker wires. Inspect each and make sure none got stuck under the table, or slammed in a drawer or pinch by a staple or whatever.
--Matt
Dec 12, 2006 | GPX DV7500 System
The volume is way to high even on the lowest setting
Sorry I don't have a solution. We have this model and ours is loud also, at the very lowest setting. I disconnected some of the speakers, and sometimes have to put the working speakers into a drawer to lower the sound.
May 29, 2006 | GPX DV7500 System
Progressive Scan Mode Resetting
Hi, Open the CD and press return on the remote to reset it back to Interlace mode. Thanks Annarr
Jan 14, 2006 | GPX DV7500 System
GPX DV7500 System Logo
147 people viewed this question
Top GPX Audio Players & Recorders Experts
Steve Allison
Steve Allison
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
