Question about Panasonic CT-24SX12 24" TV
Tv is lock
What is unlock code
    Problem Solver:
  • 18 Answers
Try 8419..and hit me back with ur update
Posted on Dec 22, 2008
How to get child lock off of my daughters TV I forgot the code help!
The procedure to unlock the child lock to TVs will differ brand to brand. The general procedure to most TVs are:
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Check this. If you wish to get more details about unlock a TV, check the site linked here. Pull up older posts. Unlock procedure to many popular brand TVs are given in detail.
google.com/+GopakumarGopalan
Nov 25, 2013 | Televison & Video
How to unlock a jcv s1465 screen
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
Feb 26, 2013 | Insignia Televison & Video
Password for jvc tv v-chip
Jan 17, 2013 | Televison & Video
How to unlock the tv
Oct 22, 2012 | Sharp 14U-FM1 14" TV
My screen is all blue, no image and voice. a lock on the upper left corner
It sounds that your TV is locked by someway. Just unlock it. Proceed the following.
Many Jensen TVs have a parental lock that can be set to stop children from watching certain television shows or channels. In order to activate or deactivate the controls, you have to know the four-digit code or parental lock passcode. If you forget the passcode or if the lock gets set accidentally, you can still unlock the TV.
• Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
• Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
•Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
• Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
Sep 27, 2012 | Jensen Q2749J 27" TV
How to turn off clock on jvc tv
Sep 06, 2012 | JVC Televison & Video
Sep 06, 2012 | JVC AV-32260 32" TV
Remove the prerental block on a jvc tv
Apr 03, 2012 | JVC Televison & Video
My TV is on child lock how do I unlock please
  1. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
  2. Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
  3. Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Read more: How to Unlock the Child Lock on a TV ' eHow.com http://www.ehow.com/how_4510749_unlock-child-lock-tv.html#ixzz12VdKs6Bt
Oct 16, 2010 | Televison & Video
Sanyo tv kit 360 ch fit in my old tv & lock channel kindly solve problem to unlock tv channel
i am imran
and i have also buy sanyo tv kit 360 ch fit in my old bpl 20"tv and i know for unlock tv channel.
try this this code definetly is solve your problem.
1st go to the locked channel.
and then press menu>system>child lock
and then press and hold down tv/av key and press swap key.
and see locked channel is unlock.
i have coming soon post for service code menu in short coming days.
please reply me to imr4@in.com
Aug 12, 2008 | Sanyo DS24205 24" TV
Panasonic CT-24SX12 24" TV Logo
54 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
