Question about Nokia 3100
Coffee damage to a Nokia 3100
Today my child split a cup of coffee on my phone. Unfortunaetly this was not cleaned up straight away. I think my phone spent around 3 hours at most in a small puddle of coffee. Please can someone give me some advice as I can get my phone to turn on but I cannot get some of the buttons to work. Any advice? Thanks
  • 513 Answers
Have you wronged this child in any way? not only s/he kills it with coffee, but s/he just leaves it there??? ;] my sympathy. I posted a while back an answer to a very similar problem, hope you manage improving it - http://www.fixya.com/problems-solutions/t102667,p97334/Samsung-12-Button-LCD-Prostar-DCS-Phone.aspx The most important thing to spend time and money on is your SIM, with all the memories. Take it out ASAP and if it doesn't work on another phone find a lab that will work on it, give it a chem bath, anything. The 3100 sells here for 50 Euro or less, so its not that tragic. it's just a shame to loose all the numbers. Good luck!
Posted on May 04, 2006
SOURCE:
Is it bad to use heated water inside of a Keurig coffee brewer..?
I had to take the cover of the K-cup cover, this is done by removing the 2 screws out under the cover while the handle is in the open position and then snapping it off. Pull the hose off the k- cup puncturer and clean it out from the top down this will clear out all the packed coffee ground in it. You may be able to clean it from the point up if you can find a very small pipe clean or something like that but I didn't have one so I pulled off the cover and went from the top down. I'd love to know how many people threw away these coffee makers because off this repair, I know my mom did before she talked to me. Good luck people.
Jul 17, 2012 | Keurig B30 Mini Coffee Maker
HOW DO I CLEAN THIS COFFEE POT
I suggest you use vinegar acid.
You need a solution with half part water and half part vinegar acid.
1) pour 4 cups of water into your coffee machines water tank.
2) pour 4 cups of vinegar acid into your coffee machines water tank.
3) turn on your coffee machine to decalc.
4) refill tank with clean cold water and let it run through ( 2 times)
REMEMBER !!! ALWAYS POUR ACID into WATER !!!! AND NOT THE OPPOSITE !!!
If you pour water into acid it can explode and make terrible damages and cause chemical burns!!!
Hope this will help ypu
Jun 28, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
What can I use to clean my Mr. Coffee 12-cup coffee maker?
The standard way to clean a coffeemaker is t run white vinegar through it then run straight water through it. That is one of the few things that will clean without leaving a residue. Good luck.
Jan 05, 2010 | Mr. Coffee FTX24 12-Cup Coffee Maker
I have Mr. Coffee 12 cup programmable coffee maker. Clean light came on --- clean with vinegar/water mixture. Light came on to clean... ran through with water again... Light still on. What's up with that
I didn't think the D-link router actually had a clean light. ;)
my coffee pot flashes its light to let me know it needs cleaning. I just unplug it for a few seconds and the cleaning reminder goes away.
Nov 07, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
MR COFFEE FTX49. Brewing starts, then stops
Mine just started to do the exact same thing. So I decided to clean it using the "Clean" program and just water. I put the brewer through the cleaning program 3 times - each time it would brew water from 12 cups to 8 cups, I'd tap the brewer on the countertop, it would brew from 8 cups to 4 cups, tap it again, and it would brew the remaining cups. So, I called the Mr. Coffee help line (800-672-6333). The most-likely problem is that the hose is no longer attached in the water reservoir. The help line suggested that I take it in to a service center. I live in Urbana, IL and the closest service center is in Oak Lawn, IL - 2 hours away from me!!
Here is my solution:
1) Buy another coffee brewer.
or
2) Smash your current Mr. Coffee brewer into a million pieces (this relieves stress) and go buy another coffee brewer (probably stay away from Mr. Coffee products).
Hope this helps.
Frustrated in Urbana
Oct 11, 2009 | Mr. Coffee 12-Cup Programmable Coffeemaker
When I turn the switch the lights come on but nothing else happen
Depending on how old your unit is and the availability of replacement parts I would suggest looking into a new coffee maker. The control panel is malfunctioning and by the time you spend on replacing just that part you could pay for a new one. They're quite affordable now.
Sep 21, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
After using coffee that was too small, I can't make coffee with one of the filters
I'm not sure you can. I did exactly the same thing, the very first time I used it -- I phoned Breville support and they told me to try soaking the filter in 2 tsp of baking soda dissolved in a cup of warm water. Which kinda seemed to work, although it was bit occasionally reluctant to give me my damned coffee.
I struggled on with it for maybe a year, but then the rubber seal around the bit the filter connects to blew out (with rather dramatic results). I think the extra pressure of the blocked filter did more damage that I suspected.
I got it serviced and they replaced both the seal and the filter. Worked great after that...
...until last week, when water started pouring out where no water should pour. Turns out that the black lock block that the filter holder goes into has developed a crack.
Looks like another trip to the service agent for me.
In short, you could try cleaning the 1-cup filter, but I would reccommend giving it up as a bad job and just buying another.
Before It Is Too Late.
(Signed, The Harbinger of Doom. Sorry about that.)
Apr 10, 2007 | Breville ESP8XL Espresso Machine
Nokia 3100 Logo
67 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
ASHRAF CA
ASHRAF CA
