Question about Sub-Zero 632 / S
Seals are hot
Seals to both the refrigerator door and freezer door are hot.
  • Roberta Smith
    Roberta Smith May 11, 2010
    first what is the inside temperature of the freezer and fridge.... second... any smoke ?
    Robert
  • Anonymous Mar 29, 2014
    freezer door seal not working
  • 943 Answers
HI iF YOUR FRIDGE AND FREEZER ARE COLD AND TEMP IS OK THEN ITS FINE oN FRIDGES THERESHEATERS THATGO AROUND THE DOOR TO KEEP THE CABINET WARM TO STOP CONDENTION SO THIS IS NORMAL THANKS FOR THE QUESTION THE APPLIANCE DOC
Posted on Sep 12, 2008
  • 1462 Answers
SOURCE: Whirlpool Refrigerator Door Seal surface is HOT.
transom between fridge and freezer is usually haeted to stop condensation when you open freezer door. suspect you have no fault
Posted on Jul 14, 2008
  • 87 Answers
SOURCE: Delfield Refrigerator/Freezer Condensation forming outside door seals
I would expect at the very least a heater circuit around the freezer door. Some of the commercial units also have sprung doors to keep the doors firmly shut which you could check by opening the doors. Door heater circuits are normally very reliable and it would be worth checking the voltage is getting to them, they are also a pain to change out. Hope this helps.
Posted on Aug 26, 2007
fridgetech
  • 473 Answers
SOURCE: Warm to Hot molding that seals the doors
Either the fan motor has gone bad or the coils under the fridge are too dirty. Both will cause a no cool situation and cause this area to become too hot. Part of the coil runs thru the cabinet in this area to prevent sweating. This is a good indication of dirty coils or a bad/weak fan motor. If your fan was noisy I would replace it before it goes out completely. This excessive heat will lead to premature compressor failure.
Posted on Nov 11, 2007
  • 4 Answers
SOURCE: The refrigerator and freezer rubber door seals are
Pull fridge out and clean the grill on the back , its a hot pipe running around the door for condensation , if the grill on the back is clogged with dust it will get very hot , see how that goes enjoy
Posted on Mar 05, 2009
Krazytech
  • 725 Answers
SOURCE: center divider between refrigerator and freezer
check the fan in the machine compartment...if the fan is not turning when the compressor is running you have a bad fan motor. this caused the youder loop to over heat trying to cool the condencer...hope it helps
Posted on Sep 19, 2009
Why is there ice in the bottom of the crisper?
Freezer /fridge water/ice in fridge
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Sep 07, 2014 | Samsung RF217ABPN Bottom Freezer French...
Freezer too warm, and i feel heat on the door seals
The door seals warm is from the mullion heater that minimizes moisture from forming in that area, under working conditions. You need to provide more information.... What did you see that made you defrost it 3 weeks ago..
Nov 27, 2013 | Kenmore 53542 / 53544 Side by Side...
When you open the freezer door the metal in hot to the touch
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Aug 29, 2011 | Kenmore Top Freezer Refrigerator
Refrigerator cools poorly but freezer is OK, what's the solution?
There are various reasons which can cause this. They are
  1. Interior sweating.
  2. Bad door seals.
  3. Excessive door openings during hot humid weather.
  4. Storage of excessive uncovered liquids especially if they are inserted into refrigerator while warm.
  5. Void in insulation.
  6. Overcharged.
  7. Bad door seals.
  8. Condenser fan not running.
Jun 21, 2010 | AEG SK71840-4i Top Freezer Refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Outside freezer hot and seals
Fridge has either mullion heaters around door or most likely steel pipes just inside the skin of the perimeter of the door, this is to stop ice or condensation forming around the door seals, mainly the freezer, they are part of the condenser circuit ( hot part of the refrigeration system).
It is normal for these to get hot, but in your case may be hotter than usual because of the constant running, the running may be caused by hot ambient temperatures, system being slightly short of refrigerant, faulty thermostat or in-efficient compressor.
I suggest if temp is ok inside fridge dont worry too much, if you notice fridge starts loosing its capacity to refrigerate, have a refrigeration tech look at it.
Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
Freezer side is hot outside
There is no problem at all. The outside of the freezer is hot because it is rejecting heat from the inside of freezer compartment to the outside surroundings, this is a normal refrigeration cycle. As for the seals being hot, this may be to prevent the door from freezing shut. i know that commercial and industrial freezers have heated seals for this reason.
Sub-Zero 632 / S Logo
512 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
