Plantronics - Bluetooth Headset Plus Base & Headset Logo
Posted on Sep 12, 2008
Plantronics p590 + BB Pearl
I have a lovely new P590 stereo bluetooth headset. Discovery & pairing is successful - phone works great. Can't get my music from my BB onto the headset. Ideas?
Thanks!
Jason [email protected]
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 24, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
340
Points
Pearl 8100 can not output media audio to Bluetooth. Another BB might.
Hello I am trying to install a new headset to my CS70 desk phone. The ruber earpiece on mine broke. How can I pair the new earpiece?.
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone, PC or other device for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your other device to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
10helpful
Plantronics 925 Discovery won't connect with Droid 2
  • Turn on Bluetooth within your phone - Consult phone instruction booklet
  • Put phone into pairing mode - Consult phone instruction booklet
  • Put headset into pairing mode - With headset off, press and hold Call Control Button
    until the headset begins to flash red and blue.
  • Select "Add new device" on your phone.
  • Select the Plantronics headset when prompted. Enter "0000" as passcode.
  • Your 925 headset will now have a continuous blue light blinking.
  • Choose "Yes" if your phones asks if you want to bond to the 925 headset.
  • Your phone is now paired with the Plantronics 925 headset and ready for use.
  • Please leave me a good rating!
    CAN'T GET MY BLACKBERRY 8330 TO PAIR WITH MY
    Did you do the steps listed here?
    This is the Plantronics information.
    Your new headset includes Plantronics QuickPair technology to simplify
    the Bluetooth setup process. The rst time you turn your headset on, your
    headset automatically enters pairing mode for 10 minutes. Once paired
    successfully, your headset stays on for instant use.
    If not sucessfully paired after 10 minutes, your headset automatically
    powers o. When you turn the headset on again, it automatically goes
    into pairing mode until successfully paired with a Bluetooth phone.
    To pair your headset for the rst time:
    Turn ON the Bluetooth feature on your phone.
    TIP: For most phones, select Settings/Tools > Connections > Bluetooth > On.
    See your phone’s user guide for more information.
    Press and hold the call control button to turn on your headset. (The indicator
    ashes red/blue to show that the headset is on and in pairing mode.)
    TIP: If you don’t see the red/blue ash, press and hold the call control button to
    turn your headset o, and then press and hold the call control button again until
    you see the red/blue ash.
    Use the commands on your phone to locate your headset.
    Search > 520Plantronics. See your phone’s user guide for more information.
    When prompted for the passkey, enter 0000.
    When pairing is successful, the indicator on your headset ashes blue. Your
    headset is now connected and ready to use.
    I am trying to pair my Plantronics Explorer 330 headset to my new phone, an HTC Eris. the phone does not recognize the device. Do you have any ideas?
    When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
    3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
    How do i connect plantronics 330 to my new phone? i have the bluetooth connection on on my phone but it doesn't seem to read it. Its a Sony Ericson W980
    1helpful
    2answers
    Winamp/bluetooth/plantronics p590
    I have found that winamp doesn't automatically output through any hands-free headphones, therefore you need to go into Preferences on Winamp (Ctrl+P), go to:
    -Plugins/Output
    -select Nullsoft DirectSound Output -->configure
    -select Device tab
    -select 02: Bluetooth Hands-Free Audio
    -click apply
    If music is already playing, click STOP then PLAY, pause will not do it.
    I have been looking for this fix all day on the internet, but finally worked it out myself.
    Hopefully this post will make someone else's day less stressful!
    How do I listen to Itunes from my MacBook Pro on plantronics p590 headset
    http://macapper.com/2007/10/31/hidden-leopard-gem-stereo-bluetooth-support/
    39helpful
    4answers
    Settin up bluetooth
    Turn headset off.
    Hold down the "phone" button on the headset.
    Turn headset on.
    Release "phone" button.
    LED ring should be alternately flashing red/blue.
    Voila.
    33helpful
    4answers
    Plantronics Bluetooth Headset P590
    This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
    1. Plug in the USB charging cable to a laptop or computer that is powered on.
    2. Connect the USB charging cable to the headphones
    3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
    4. Plug the other end of the 3.5mm cable into the P590 input.
    The headphones should start charging.
    Carlos (New Zealand)
    Top Plantronics Radio Communications Experts
     Grubhead
    Grubhead
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
